03-21-2005, 09:23 PM | #1 |
Member#: 74129
Vehicle:2003 Evo AS |
what mods for a wrx to pull on an sti.
i am going to be purchasing an 02 wrx and my goal is to keep it stock appearing but have enough power to be able to pull a stock sti in a straight line, from any speed. my first planes are a cobb catless turbo back and programe w/up. what else should i start looking at? also with those mods would i benefit from any fuel upgrades, like sti pinks, or a pump? cause i will be doing a vf39 off my buddies sti, or possably a vf22 but it would be a lot more cost efficiant if i could do the fuel system piece by piece.
03-21-2005, 09:28 PM | #2 |
Member#: 51745
NWIC
Vehicle:LIKE A BOSS |
Turbo upgrade = fuel upgrade.
You should have just bought an STI. |
03-21-2005, 09:29 PM | #3 |
Member#: 74129
cant afford it plus the insurance is a bit more.
03-21-2005, 09:30 PM | #4 |
Member#: 35269
Vehicle:2011 WRX |
From any speed?
A bigger motor. |
03-21-2005, 09:31 PM | #5 |
Member#: 51018
BAIC
Vehicle:2005 Legacy Silver |
Search please, wow.
03-21-2005, 09:45 PM | #6 | |
Member#: 83395
Vehicle:2005 Subaru WRX STi Silver Metallic |
03-21-2005, 09:48 PM | #7 |
Member#: 62197
South East
Vehicle:2008 WRX DGM |
You can hang with cobb stg2 but if both drivers are equal he will beat you. Get a VF turbo then you can pull a stock sti...but again he is stock and u got an upgraded turbo.
03-21-2005, 09:49 PM | #8 |
Member#: 40702
South East
Vehicle:2002 Wagon stg 3.5 WRB |
I dont know if from any speed. But I pulled on an STi, Im betting it was the driver that couldnt drive We were going about 30, she might have been in second I was still in first. I pulled pretty easy, but again I think it was the girl driver. Not that girls cant drive. We all know subie gal can probably drive circles around us I havee all the basic bolt ons, VF39,Sti injectors and a utec.
03-21-2005, 09:52 PM | #9 |
Member#: 35269
Vehicle:2011 WRX |
I've taken more then a few STi's(modded(stage2) and stock)) at the track.
But from any speed? That's a whole different story. You would need alot more torque. |
03-21-2005, 09:55 PM | #10 |
Member#: 24447
SWIC
Vehicle:2016 Mustang GT w/PP Red |
Just buy an STI, in the long run it will be cheaper.
Ryan |
03-21-2005, 10:04 PM | #11 |
Member#: 23676
NESIC
Vehicle:. |
if you upgrade your motor enough to reliably, every time, pullon an STI, you will be replacing your shortblock within 50,000 miles. Sooner if the tune isnt VERY good.
remember, regardless of the fairy tales you hear from stage 2 owners, they cannot run a 12.9 And an STI can. |
03-22-2005, 12:10 AM | #12 |
Member#: 57809
or you could do a 95 WRX type RA swap and boost at 16 psi and youll have him.
3 more days |
03-22-2005, 12:14 AM | #13 | |
Member#: 51745
NWIC
03-22-2005, 12:45 AM | #14 |
Member#: 57809
yes shinsain, you are 100% right about that..But I think I can get that worked out.LOL haha ahh geez this whole swap thing has gave me gray hair and I am only 18.
03-22-2005, 07:11 AM | #15 | |
Member#: 31162
SCIC
Vehicle:2005 STi |
Pull on an STi, I know the shop I used (aerosim) had/has a special for about $2200 was offering a VF34 with fuel upgrades (I think injector and pump) and an Cobb Accessport installed. So add about $2200 plus tax (if you can get as good of a deal)to the cost of your TBE(new is listed a little more than a $1000)+labor and you are looking at around $3200-$3500 after tax and labor. Sounds like its getting expensive? Well maybe you can cut corners on the tbe. I hear you can actually go stg 2/vf34 with stock catback, you just need a dp. You can probably get a used one of a different brand for $150. Install it yourself or have someone do it (install and heatshield trimming for about $100, CEL fix not neccessary if you reflash). Granted, an AP VF34 map is tuned to their own TBE, you may compromise a little power or efficiency by saving some money. I don't know the actual results at the strip, but you will be right about level with an STi give or take. Want to really PULL on an STi? Its going to cost more money, and don't forget... when you get to the first turn you are still going to get burned. |
03-22-2005, 11:02 AM | #16 |
Member#: 74837
SWIC
Vehicle:2003 WRX SRP whore |
Just get an SRT4 and you'll be t3h f4st4r!!11!
03-22-2005, 11:07 AM | #17 |
Member#: 24038
South East
To hang with him, you'll have to have 225+ whp and be in the right gear. At higher speeds, STi's have more drag, so it will only get better for you. Problem is, their power bands are bigger than yours, so if your caught a little low in the revs, he'll be all over you. I don't think it takes a turbo though, you'll never have the low end, but you can match his peak power with EM/Exhaust
03-22-2005, 11:13 AM | #18 |
Member#: 31162
SCIC
Vehicle:2005 STi |
He said he wants to pull on an STi, correct me if I am wrong but I think that means he wants to be faster.
03-22-2005, 11:42 AM | #19 |
Member#: 23934
didn't you ask this before?
03-22-2005, 12:17 PM | #20 |
Member#: 31162
SCIC
Vehicle:2005 STi |
He started another thread about upgrading a WRX with an STi turbo, injectors and pump in 2.0L forum, but that thread was about beating a Mustang
03-24-2005, 05:40 PM | #21 |
Member#: 74129
my main concern is keeping up with jones's. my friend has an 02 gt mustang, and my other friend has a 04 sti and on the freeway they are very close, untill about 110mph and the sti slowly starts to pull...very slowly. they both said that if i get a wrx that i wont ever be able to keep up with them after about 40, unless i start doing internals. so basicly i just need to keep up after 40mph.
03-24-2005, 06:18 PM | #22 | |
Member#: 21999
Vehicle:2017 Wrx DGM |
BTW STi's also have way more torque. So basicaly you need about 300hp and 300 ft/tq. Fess |
03-24-2005, 06:21 PM | #23 |
Member#: 30766
Vehicle:2004 Impreza WRX Java Black Pearl |
um, you should get in the car with one of them..........cheapest solution ever.
03-24-2005, 06:29 PM | #24 | |
Member#: 81707
Vehicle:02 2.5RS Blue Ridge Pearl |
03-25-2005, 05:18 PM | #25 |
Member#: 79394
Vehicle:02 gda wrb |
to pull on an STi, it's going to cost at least $3k for parts and then you're going to need a good tune. If you don't have that kind of money, you're not going to keep up with them.
how many miles to expext on an sti? | SonicScooby27 | Newbies & FAQs | 3 | 12-13-2009 04:04 PM |
Is it worth it to go to 18" on an STi | ScoopSTi | Tire & Wheel | 2 | 02-15-2006 09:49 PM |
Looking for local shop to look over an STi I'd like to buy this weekend! | eshaun | Bay Area Impreza Club Forum -- BAIC | 10 | 04-25-2005 03:03 AM |
What should the factory installed boost gauge on an STi read? | SithSolo1 | Newbies & FAQs | 3 | 01-03-2005 02:54 PM |
is it redundant to get Cusco shifter bushings to put on an STi short shift kit? | monkeypizza | Transmission (AT/MT) & Driveline | 5 | 01-14-2004 06:21 PM |
