Welcome to the North American Subaru Impreza Owners Club Thursday May 22, 2025
Old 02-17-2025, 04:48 AM   #1
Katabothron
Member#: 540160
2019 Impreza Manual
Default Can You Deactivate Traction Control?
I pressed the button that turns on the skidding tire icon on the dash with "off". But when I spin the tires, I get an identical pop-up in another part of the dash with the same icon. Anyway to completely turn off traction/stability control?
Katabothron is offline   Reply With Quote
Old 02-17-2025, 08:26 AM   #2
Nerdelectric
Member#: 477540
2015 WRX Premium
Check if your owner's manual instructs how to turn it off completely. Owner's manuals can be surprisenly helpful sometimes.
Not sure about your '19 Imprezza, but in my '15 WRX I hold the traction control button as it cycles through trac mode, until it sayf off, then I release the button.
Nerdelectric is offline   Reply With Quote
Old 02-17-2025, 09:32 AM   #3
rtv900
Member#: 428511
2016 STI
usually traction control and stability control are two different things controlled by the same button.
I can't remember how my STI worked but my other two cars that have it both need you to push and hold that button.
Initially just one turns off, but if you hold it down after a few seconds the 2nd one will turn off also
rtv900 is offline   Reply With Quote
Old 02-17-2025, 04:15 PM   #4
Gixhost
Member#: 180111
* 2004.114.3 STi
What is this magic you speak of???
Gixhost is offline   Reply With Quote
Old 04-11-2025, 12:05 AM   #5
ShermSMASH
Member#: 540789
Default Yes, but there are 3 modes
In my 2015 WRX,to deactivate traction control, you press the button without holding it down. The skiddy mark will come up on the dash with another light in green that reads Trac Mode. This mode is like 90% traction control off. The second mode of turning it off is by holding it down for 5 seconds. In this mode it turns the traction control COMPLETELY off and you won't hear any brakes dragging while doing skids. I hope this helps.
Last edited by ShermSMASH; 04-11-2025 at 12:06 AM. Reason: Forgot to specify my car type
ShermSMASH is offline   Reply With Quote
