Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 11-10-2015, 07:54 AM   #51
swp_wrx513
Member#: 433981
this build is ridiculously awesome!
keep up the good work.
swp_wrx513 is offline   Reply With Quote
Old 11-11-2015, 04:33 PM   #52
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Thanks for the kind words!
It between studying for finals I tacked up the second upright.
Teddy-2000RS is offline   Reply With Quote
Old 11-12-2015, 02:40 PM   #53
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Got the uprights welded in and test fit it on the factory subframe. Everything lines up so its time for bracing.
Old 11-14-2015, 07:11 PM   #54
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Motor mounts braced
Old 11-14-2015, 07:40 PM   #55
jpn6438
Member#: 410917
2005 Impreza RS
You have mad skills buddy!
jpn6438 is offline   Reply With Quote
Old 11-15-2015, 06:05 PM   #56
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Thanks!
And bolted to the engine
Old 11-16-2015, 11:40 AM   #57
06backxt
Member#: 397847
Wow v8 Subaru never thought I'd see the day haha
06backxt is offline   Reply With Quote
Old 11-19-2015, 05:47 PM   #58
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Its been done a handful of times but a lot rarer than some of the other lsx swapped cars out there.
06 sti control arms and solid end links showed up today.
Old 11-29-2015, 06:59 PM   #59
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Front side of the control arm mount drawn up and mocked up in cardboard. I'm boxing in the other side tomorrow. More goodies ship out Tuesday, and I'm ordering my chromoly at the end of this week.
Old 12-04-2015, 02:44 PM   #60
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
V9 STI front knuckles and hubs came in today.
Old 12-04-2015, 05:46 PM   #61
denis.drc
Member#: 404718
1997 Impreza Coupe
Thumbs up
This is an awesome project. I've seen a few on "norotors", but I love how each has its unique build qualities. I like your method. Very nice fab work. I also love your attempt to work on it in the school's parking lot. I got a similar warning from my dorm admin when I tried to do something similar back in college.
You planning to stick with that truck intake manifold?
Doing any motor work before you wrap it up?
denis.drc is offline   Reply With Quote
Old 12-07-2015, 02:57 PM   #62
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
opcorn:
Yep swapping out the truck mani for something more boost friendly like the holley hi-ram or fast lsx. And I'll be going full forged bottom, 243 heads,etc. All in preparation for boost.
And for the update
Lower coil mounts and new ball joints showed up so I put most of the front end together.
Old 12-14-2015, 10:15 AM   #63
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
This should make sheet metal work a breeze.
Old 12-22-2015, 12:28 PM   #64
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Should be enough to cover front and rear subframes, trans mount, and tunnel. Unfortunately I'm on Christmas break tomorrow until next year so progress will be stalled for the time being.
Old 01-05-2016, 03:06 PM   #65
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
4 mount tubes ready to be capped.
Old 03-07-2016, 08:20 PM   #66
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Control arm mounts are finished. I kind of dicked myself with a bunch of tight corners and grooves to weld in on this one. Alot of it I had to weld out of position to get everything covered. Definitely improving on my consistency around corners where I previously struggled.
Next up I'll be mounting my rack and deciding on a transmission mount.
Front half of the subframe is done and fits snug.
So in the quest for perfection I was not satisfied with the look of the transmission mount inside the car. So after much deliberation I decided to cut more of the floor out to make room for a frame rail connector. The transmissions mount ties both frame rails together eliminating any worry I had about twisting the original. I promise this will be the last one.
8.8 inches of Murica.
Old 03-08-2016, 07:51 PM   #67
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
And spare tire is gone. Rear differential mocked up. I'm not happy with any of my subframe designs so I can't move any further.
Old 03-10-2016, 10:18 PM   #68
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Rear tube of the subframe is cut and notched. Mehh quality photo thanks to my shoddy garage lights.
And my 1.5" notcher lost all its teeth. Time for another.
Old 03-11-2016, 05:09 PM   #69
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Rear diff support is tacked and fits good. I'll finish up cutting and tacking the remaining mounts together.
Old 03-12-2016, 02:55 PM   #70
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Gussets added. Don't mind the points, I'm going to contour them along the radius of the tube when I finish weld them. Now I'm waiting on finding hubs so I can sort my lateral link spacing and mounts.
Old 03-19-2016, 06:51 PM   #71
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Small update: tie rods showed up early so I got the old ones off and the new ones situated.
Took out the L dash beam and replaced it with the rs beam so I could bolt up my column.
Encountered my first problem with my lower engine placement. The steering joint comes up a slight bit short. Going to cut it at the welds and replace it with some extended one inch tubing.
And the differential fits snug and out of the way. The housing is to heavy to put in by myself so the cover will suffice for your viewing pleasure.
Filling up my argon Monday before class, and hopefully this guy with hubs gets back to me.
Old 03-21-2016, 10:57 PM   #72
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Picked up my argon this morning
And did some welding
Plan is to use stock steering rack mounts but I want stock style clamp mounts machined. The stock ones are beefy enough.
Old 03-31-2016, 07:29 PM   #73
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
Steering rack mounted with oem hardware.
All that's left is the column extension
Old 04-01-2016, 02:00 PM   #74
Teddy-2000RS
Member#: 360784
2000 Impreza RS
BRP
All work is done at my house, the dorms wouldn't have liked this kind of stuff.
Extended the steering joint today. Definitely want to make some tie rod spacers to help with future bump steer.
Old 04-01-2016, 05:33 PM   #75
amiexploited
Member#: 251061
18 Trek 6mt,
garage queen 15 WRX 6mt
subbing for RWB subie goodness
amiexploited is offline   Reply With Quote
