Welcome to the North American Subaru Impreza Owners Club Wednesday November 20, 2019
Old 11-23-2018, 06:14 PM   #176
HooptieDoodle
Member#: 494401
2001 Forester
crust
I got this idea from someone else in one of these forums, so not original to me, but for the rear endlinks on some of the early 2000s Subarus, you can swap in endlinks off the front of some Audis and VW Passat. I was able to pick up a pair from a junkyard for $10. I made a video of it here:
It's a fantastic deal as these are high-end aluminum endlinks. I have been running them on my car for over a year without any issues.
HooptieDoodle is offline   Reply With Quote
Old 02-18-2019, 03:57 AM   #177
HerBluePearlWRX
Member#: 497923
Default Howdy
Good reading all this info! Can't wait to start playing with the suspension on my car
HerBluePearlWRX is offline   Reply With Quote
Old 02-21-2019, 08:42 PM   #178
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Anyone have issues with aftermarket front swaybars and 2015+ Endlinks?
The bolts on my Type-RA endlinks are larger in diameter than my Superpro front swaybar. I got the corresponding Superpro endlinks, but it doesn't have two different sizes just the smaller diameter bolts.
Did front endlinks change size at some point?
Old 02-27-2019, 04:04 PM   #179
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
This is excellent reading. Now to just wait till the wife won't balk at spending $460+ on suspension and tranny mount mods .
I'm sort of torn between a 22mm adjustable and 24mm adjustable. I'm leaning towards a 22mm adjustable set to middle for daily, stiff for track, and soft for winter.
Is Cygnus still on here and active?
SirBrass is offline   Reply With Quote
Old 02-27-2019, 04:37 PM   #180
Boggie1688
Member#: 165955
2015 WRX Base
New VA chassis have a 12mm bolt up front instead of a 10mm. This is because the bar is significantly bigger than previous years, 21mm to 24mm.
Boggie1688 is offline   Reply With Quote
Old 02-27-2019, 05:02 PM   #181
jamal
Member#: 71875
Superpro doesn't seem to list a front endlink for the 2015+ in their catalog btw.
Whiteline, kartboy, etc have different part numbers for the front bars and links. So, no, you shouldn't have issues unless you order parts for an 08-14. I suppose that doesn't prevent vendors from listing things incorrectly.
jamal is offline   Reply With Quote
Old 04-26-2019, 06:40 PM   #182
Gonzii
Member#: 500855
I知 new to The 2018 Subaru WRX STI, I got mine last year. This is my first Subaru. After reading the article above; is all I need for the rear and front
The sway bar of my choice
End links
New bushings
Is there anything else? Does the sway bar kit com with everything else? I知 looking at Whiteline.
Gonzii is offline   Reply With Quote
Old 05-07-2019, 01:41 PM   #183
mdean12
Member#: 331255
2017 WRX
CBS
End links
New bushings
Whiteline's sway bar kits will most likely come with everything you need, including the sway bar mount bushings.
You will have to buy end links separately.
mdean12 is offline   Reply With Quote
Old 05-12-2019, 11:38 AM   #184
Gonzii
Member#: 500855
Default Swaybars & Endlinks - Impreza/WRX/STi Version
Thank you! I知 looking at adjustable Whiteline 22mm front 24mm in the back. Not sure what to get for endlinks.
Old 06-05-2019, 12:56 AM   #185
nemos_black_wrx
Member#: 372679
2012 impreza
DGM/plylon orange stains
does any one know what size the fb20 impreza front sway bars are? and what would be a good front back combo for it with 8k coilovers as a daily and autocross car?
nemos_black_wrx is offline   Reply With Quote
Old 06-18-2019, 11:20 PM   #186
jake14001
Member#: 471479
Anyone have an estimation on how hard the plastic stock endlinks on an 06 2.5i can be pushed when used with a 24mm Whiteline rear bar? I致e had it on for a while but I want to make sure everything will be alright.
jake14001 is offline   Reply With Quote
Old 06-21-2019, 12:04 PM   #187
Wild_bill_
Member#: 471864
oringal sticky says ball links are the best of both worlds, there a link to any of those?
Wild_bill_ is offline   Reply With Quote
