Welcome to the North American Subaru Impreza Owners Club Friday November 22, 2019
Old 10-18-2019, 04:12 PM   #1
SightsSetStudios
Member#: 499997
2001 Impreza OBS
Default Adding Hood Struts
Tired of my janky hood prop. Has anyone added gas struts to their impreza? Seems simple but I couldn't find anything with Google or searching here.
SightsSetStudios is offline   Reply With Quote
Old 10-21-2019, 02:37 PM   #2
mj213
Member#: 252218
2002 Forester
I made some brackets for my 2002 forester. I used aluminum angle bracket 1/8" thick, drilled out holes to match the 2 bolts on the hood hinge, then drilled a hole on the side for the strut to mount in. Once you prop the hood up in the proper location, you'll be able to tell where you need to drill in the fender seam to bolt the end of the strut in place. Here's a pic on the net of what mine looks like (not mine, but the same).
mj213 is offline   Reply With Quote
Old 10-29-2019, 04:20 PM   #3
SightsSetStudios
Member#: 499997
2001 Impreza OBS
Thanks!
Old 10-29-2019, 07:40 PM   #4
Billybob97
Member#: 507707
Thanks for the help I have been interested in good struts of my prop for a while
Billybob97 is offline   Reply With Quote
Old 10-29-2019, 09:10 PM   #5
KC
Member#: 442
17 Imp Spurt
00 S2k
Why do you want hood struts? Want it to open more upright?
Move it to the lower hole in the hood which will have the hood more upright, or relocate the base of the prop into the hole/arch (that seemingly odd placed tab with a hole in it on the pass side strut tower.) It just pops right out.
--kC
KC is offline   Reply With Quote
Old 10-29-2019, 10:02 PM   #6
KC
Member#: 442
17 Imp Spurt
00 S2k
FYI, newer models don't have that tab, but have an actual hole in the strut tower, for the same purpose of relocating the support.
Old 11-19-2019, 03:41 AM   #7
Savagewrx
Member#: 508504
Anybody happen to have hood struts on a 06?
Savagewrx is offline   Reply With Quote
Old 11-20-2019, 10:44 AM   #8
vintage42
Member#: 505426
2016 Impreza 2.0 CVT
I put these struts on my '08 Forester:
https://www.subtle-solutions.com/pro...products_id=85
Here is their page for Imprezas:
https://www.subtle-solutions.com/ind...7338f600ed19ba
vintage42 is offline   Reply With Quote
