Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 09-11-2009, 02:04 PM   #26
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Originally Posted by sniper512 View Post
Thanks for that Rob.
I will try the 4.7v diode and see how she is. If not the defencer is goin in haha. I will try pushing the boost up till I see some knock then cut it back a bit.
You are a braver soul than I.
I predict if you push it past 18/19 psi you will run with the MAF pegged at 5v which could eventually lead to leaning out to the point that you melt a hole in your piston....all without an indication of knock.
But feel free to prove me wrong!
-Rob
rob is offline   Reply With Quote
Old 09-12-2009, 12:25 PM   #27
sniper512
Member#: 189923
1993 JDM WRX
-Rob
Well someone must find out right. I will probably just run it peaking to 19psi and tappering to like 17psi.
I tried the diode yesterday, but the guy at the electronics store gave me the wrong diode that only produced an engine light. I will try ordering one of the net and see what happens. If not I'll pick up a defencer.
sniper512 is offline   Reply With Quote
Old 09-12-2009, 11:48 PM   #28
1995REX
Member#: 201655
2001 TT Legacy GT-B
im thinking ill run mine at 17-17.5 and leave just a small spot for error and spike in mine
1995REX is offline   Reply With Quote
Old 09-13-2009, 02:35 AM   #29
sniper512
Member#: 189923
1993 JDM WRX
Yuppers that's where I was trying to get mine or a tiny bit more and I hit cut in 4th and above randomly. Soon to be fixed though.
Old 09-17-2009, 01:08 AM   #30
1995REX
Member#: 201655
2001 TT Legacy GT-B
keep us up to date on your solution and how far you take
Old 09-17-2009, 11:10 AM   #31
sniper512
Member#: 189923
1993 JDM WRX
I am just waiting on the diode. I have found the right one when it comes in I will try that then turn her up a bit more.
Old 09-17-2009, 05:56 PM   #32
sniper512
Member#: 189923
1993 JDM WRX
Diode is in. Boost is creeping towards 19psi up high and tapers back to 18psi right away. Tapering to 15psi by Redline. Much better. Has anyone ever used a zener diode before? Make sure you ground the negative end to the body and just tap the signal wire.
Old 09-17-2009, 10:10 PM   #33
1995REX
Member#: 201655
2001 TT Legacy GT-B
I cant wait to get home and do my install
Old 09-18-2009, 12:13 AM   #34
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
how dramatic is the power from stock i have ej20g with td05 front mount catless 3" blitz turbo back, gredyy type rs bov blitz intake on stock Z4 ecu and stock boost
GregBolby is offline   Reply With Quote
Old 09-18-2009, 02:37 AM   #35
sniper512
Member#: 189923
1993 JDM WRX
Well lets say its not even comparible. I would bet an extra 60-80chp from where you are now maybe a bit less. Like leaving you in the dust different I don't know its hard to judge. I do know that when I had Rob's 440 tune I race my exact same car but stock and it was a beating.
Old 09-20-2009, 01:39 AM   #36
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
damn im deff gona have to step up, what all do i need, robs eprom carl davy injector adapters some 550 injectors and a boost controller yeah?
Old 09-20-2009, 02:00 AM   #37
sniper512
Member#: 189923
1993 JDM WRX
I would recommend a TBE and a better IC for the 550 tune and this much boost. Other than those yes Phase 1 to Phase 2 injector collars, 550s and a MBC with Robs 550 tune.
Old 09-22-2009, 12:50 AM   #38
1995REX
Member#: 201655
2001 TT Legacy GT-B
Sniper do you think my ARC TMIC is going to be enough for the boost we are talking about or do have to step to a FMIC right away its in the works but in a few months let me know your opinion
10 days and i am home to do my swap
Old 09-22-2009, 10:54 AM   #39
sniper512
Member#: 189923
1993 JDM WRX
It should be good. I am running a 02+ USDM TMIC on mine which is barely enough yours should be better than that.
Old 10-26-2009, 11:20 AM   #40
1995REX
Member#: 201655
2001 TT Legacy GT-B
My ECU worked like a charm this time rob your customer service it top notch and I want to thank you for your work and help on this. My car runs great now its nice having and extra 4-8 PSI of boost. before I was running like 10 PSI on Low and 13.5 on High now im running 14 on low and 17.5 on high. My best mileage to date is 21.5 but the newness of the tuning is still fun to play with. O yeah and the EVO X that I had to school is currently thinking twice before picking on a old looking cars from this point on.
THANKS AGAIN YOUR CUSTOMER SERVICE IS TOP NOTCH DO NOT KNOW WHAT ELSE TO SAY ABOUT IT!!!!!
Old 10-26-2009, 12:00 PM   #41
sniper512
Member#: 189923
1993 JDM WRX
Mine is running strong as ever. It is starting to cool down to -10 C in the mornings here and all is well also. I may turn the boost down for winter though as in the snow traction is hopeless making this much power
Old 10-26-2009, 06:05 PM   #42
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
ej25d fuel rails also work if you dont want to wait for fecker collars
JDMFLCL is offline   Reply With Quote
Old 10-26-2009, 07:58 PM   #43
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What the hell does that have to do with anything?
Old 10-26-2009, 08:06 PM   #44
1995REX
Member#: 201655
2001 TT Legacy GT-B
on the ej20G you need the collars to put in the 550CC STi injectors or those fuel rails instead of collars what ever way you chose to go with. Someone above asked the required parts list for this type of tune and he was told to use the collars but it was also being pointed out that you can just use those fuel rails instead of the collar kit
Old 10-26-2009, 08:07 PM   #45
JDMFLCL
Member#: 180513
Baby Baby C'mon!
my words
they have been stolen
Old 10-26-2009, 08:20 PM   #46
1995REX
Member#: 201655
2001 TT Legacy GT-B
thats what im here for bro also you can get collars and injectors from
http://www.deatschwerks.com/catalog/...php?cPath=0_21
They also have great customer service
Old 10-26-2009, 10:24 PM   #47
Matt Monson
Member#: 832
99 2.5RS, '85 911
It was just totally out of left field. Noone has said anything about injectors in over a month. You updated how your tune was working for you and then there's a post about how you can use the Ej25D rails. It just seemed OT and out of place.
Old 10-26-2009, 11:49 PM   #48
1995REX
Member#: 201655
2001 TT Legacy GT-B
eh kinda i just re-read the hole post again before i put anything up keeps it fresh in my head thats probably why I saw the three posts or so above mine
Old 10-27-2009, 03:06 AM   #49
sniper512
Member#: 189923
1993 JDM WRX
Collars worked great for me. You don't even need the injector clips either as ours work fine.
Old 10-27-2009, 02:42 PM   #50
1995REX
Member#: 201655
2001 TT Legacy GT-B
I actually had to use the new clips with mine to get them to work
official Mark Jones Tuning review thread AWDshenanigans South West Impreza Club Forum -- SWIC 45 11-12-2010 01:59 PM
Rob's tune or PFC tune? JDMFLCL Pre-2002 Factory Turbo Powertrain 25 04-09-2010 07:04 PM
Defiant Autospeed tuning review. Richardcranium419 Texas Impreza Club Forum -- TXIC 13 11-21-2007 06:28 PM
Defiant Autospeed tuning review. Richardcranium419 UTEC 0 11-21-2007 01:56 PM
Tuning Day at Rob's (late pics) Revision Mid West Subaru Owners Club Forum -- MWSOC 13 02-19-2001 09:07 PM
