Welcome to the North American Subaru Impreza Owners Club Monday November 18, 2019
Old 03-06-2017, 05:50 PM   #126
Roland3
Member#: 404510
2005 wrx hatchback
white 169K & counting
i am trying this now on a 2005 impreza wrx, its the grey connector with only some of them labeled, I have tried 1 pin in every port and no blinking abs light, any ideas? there is no clear 6 terminal only a 3 and 4 marked but not clear what terminal they are.
Roland3 is offline   Reply With Quote
Old 12-19-2017, 07:58 AM   #127
socalssti05
Member#: 399219
2005 WRX STi
Obsidian Black Pearl
Default Wish me luck
Originally Posted by jamesohoh7 View Post
Yes, I checked the level.
I also started getting the DCCD blinking, the cruise-light blinking, and the speedo stopped working intermittently while on a test-drive yesterday.
My dash looks like it's putting on a freakin' rave show... the only gauges that were working reliably are tach, fuel and temp.
I tried the dccd-code-read test procedure (key on, dccd-manual-open, gas pedal, roll from open to lock many times)... and that produced code 25. I can't find any docs that reference 25 for dccd codes, they seem to stop at 24?..
If anyone has seen issues like this and can steer me in the right direction, that'd be great.
Oh, I hooked up my laptop and ran LearningView on it, and it said I had -no- codes.
So, I'm totally lost now.... car is acting up, ecu claims no stored codes.
2005 STI. Same thing is happening to me. When the car is just on acc/on I have control of the DCCD. Once it starts up, ABS on and then once I get in reverse the DCCD resorts to the flashing green light at the bottom, lose all control of it and the brake light stays on after the E-brake is released.Plus at times my Speedo does the jumping around rave thing too! Checked the connectors/fuses under the hood all look good. Going to check the fuses and connectors under the dash in a few hours. See if it's simply a reverse fuse or if I'll have to go through the process to read these codes.
Great write up, great support from everyone. Trying to avoid a $600 shop visit replacing something I might not even have to. Post back soon.
socalssti05 is offline   Reply With Quote
Old 12-21-2017, 01:44 PM   #128
socalssti05
Member#: 399219
2005 WRX STi
Default Success!
I lucked out, went and checked the fuses inside the car. What do you know... The fuse labeled (Back) that's a 15 was blown. Replaced it and no more panic at the Disco on the dash, DCCD was fully functional, e brake light distinguished when disengaged and I drove two hours and the speedo didn't do anything crazy! Thanks again!
Old 05-05-2018, 02:15 PM   #129
mr_thulium
Member#: 485581
I just read the airbag codes on my 2004 WRX. For the record, the pin diagram for the diagnostic connector posted at the beginning of this thread did not match mine. The pin to connect the black/red wire to was the top left (as oriented in the diagram), not the bottom right.
I don't know if this is a model year difference or if the diagram is just incorrect.
mr_thulium is offline   Reply With Quote
Old 07-29-2018, 08:37 AM   #130
cardocm
Member#: 359856
2001 Outback VDC
Supercharged
Default ABS Fault Codes 34 & 41; All Module codes apply
Not all errors lead to a certainty in repair. I'm a large proponent for checking your electrical supply and grounding, and it doesn't only apply to Subarus or a specific type or generation. Its all makes/models.
So rather than retype it all, I will refer readers to this thread's post where I originally put it.
https://www.subaruoutback.org/forums...5-post684.html
cardocm is offline   Reply With Quote
Old 02-13-2019, 03:12 AM   #131
kentmartin99
Member#: 494748
HI,
I can't find the connector described in my Forester 04.
The only extra jumper leads are attached to the cable that goes to the ABS diag interface for the SSM. The other connectors do not match what is in the photos.
kentmartin99 is offline   Reply With Quote
Old 02-17-2019, 02:22 PM   #132
Gerbil1028
Member#: 497892
Default Abs issue sorry for dragging up old thread.
Any one actually have a pic of the diagnostic port I have found the earth pins but not the port itself
All I can find is 2 back 2 green and a yellow/orange one.
Gerbil1028 is offline   Reply With Quote
Old 10-21-2019, 09:33 AM   #133
cknowlen
Member#: 189077
2011 STI limited
Ok, I am going to have to thread resurrect here...
O have been diagnosing an ABS issue on a 1999 2.5 rs. I have replaced three sensors (FL, RR, and RL) as well as the FL ABS tone ring. I am still getting ABS codes:
Abnormal ABS sensor, open circuit or voltage too high
23 – front left ABS sensor
Abnormal ABS sensor, abnormal ABS sensor signal
26 – rear right ABS sensor
28 – rear left ABS sensor
I am not sure what else to check at this point since the sensors are new, and the tone rings are intact. Is it possible that the surface rust that has collected on the tone rings is causing this issue?
cknowlen is offline   Reply With Quote
Old 10-21-2019, 03:21 PM   #134
Bunniefluf
Member#: 16924
Midnight Black Pearl
Question Resurrection #2
Hey Y'all!
I need to resurrect this post too. I've read my ABS code with a Snap On scanner. I'm getting the C0036 Rear Right Pressure Reducing Valve Fault.
But I don't know what this means. I've searched online; it hasn't been much help. I also called the dealer and got the typical "bring it in so we can look at it" answer.
Hoping someone here can help me out. What does this code mean and what parts should I start looking to test/replace?
(This is for a 2002 WRX.)
Thanks bunches! Angie
Bunniefluf is offline   Reply With Quote
Old 11-04-2019, 11:28 AM   #135
cknowlen
Member#: 189077
2011 STI limited
Nobody can help with this ABS issue?
Battery voltage tested good.
Next step I am going to try is ensuring the poles of each sensor don't have any debris magnetized to them, clean the tone rings of any surface rust, and make sure the tone ring to sensor gap clearance is in spec.
any way to read ABS codes on an 08 w/o a select monitor? zmw Texas Impreza Club Forum -- TXIC 0 12-27-2009 03:11 PM
How to pull abs codes from 96 impreza? simpreza2 Brakes, Steering & Suspension 0 09-04-2004 02:21 PM
How to read Bearing codes? sponaugle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-19-2003 07:31 PM
How to read CEL code? MrZone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-08-2002 04:55 PM
How to pull a trouble code? Help plz AcIdRoX Normally Aspirated Powertrain 1 08-07-2001 09:55 AM
