Welcome to the North American Subaru Impreza Owners Club Wednesday November 13, 2019
Old 08-23-2017, 06:19 PM   #151
point78
Member#: 344329
2008 Wrx, 6mt
Turned up the boost until it wouldn't turn up any more.
point78 is offline   Reply With Quote
Old 08-23-2017, 06:25 PM   #152
subarumod
Member#: 468745
06 wrx
black as your girls soul.
your power level must be over 9000 now?
subarumod is offline   Reply With Quote
Old 08-23-2017, 07:50 PM   #153
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Changed spark plugs, oil change, changed rear dif fluid. Washed the wrx and sti. One day off a week and I work on it.
Scorpius is offline   Reply With Quote
Old 08-23-2017, 09:07 PM   #154
point78
Member#: 344329
2008 Wrx, 6mt
Need more turbo!
Old 08-24-2017, 12:26 AM   #155
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
Installed a brand new, freshly painted WRB JDM V7 STi hood scoop and new GrimmSpeed matching splitter.
Found a replacement 4EAT TCU for my 1993 SS.
monkeyposeur is offline   Reply With Quote
Old 08-25-2017, 01:26 AM   #156
LibertyHoonigan
Member#: 448735
TGV deletes, modified factory injectors, fuel pump, timing belt, water pump, turbo inlet, intercooler hoses... busy day
LibertyHoonigan is offline   Reply With Quote
Old 08-25-2017, 01:51 AM   #157
91 RS RA
Member#: 457410
1991 Legacy RS RA
Is that busy day before the better half gets home to find out you have used the bench as a work surface!!
91 RS RA is offline   Reply With Quote
Old 08-25-2017, 01:52 AM   #158
LibertyHoonigan
Member#: 448735
It sat like that overnight last night, that's why all the things HAD to be done today.
Old 08-27-2017, 08:02 PM   #159
subarumod
Member#: 468745
06 wrx
oil/oil filter change. changed to a higher viscosity cause my tuner said so.. Was using 5w30 mobil and my car was eating it.. change to motul 5w40.. hopefully it works better as far as not disappearing
Old 08-27-2017, 11:22 PM   #160
subie.tony
Member#: 451532
2017 STi
CWP
Installed Group N trans mount and Whiteline positive shift kit. Man, what a positive difference and sweet but subtle trans whine sound.
subie.tony is offline   Reply With Quote
Old 08-27-2017, 11:48 PM   #161
91 RS RA
Member#: 457410
1991 Legacy RS RA
Found myself a temporary replacement gearbox to use while the original is being repaired. Cleaned up pretty well
And painted the front wheel wheels and started cleaning up the shocks for repainting
Old 08-28-2017, 12:15 AM   #162
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
^If you ever happen across a 4EAT JDM TCU for 90-94 WRX with 20G let me know!
I swapped in my replacement TCU. Still have 4EAT 16 flashes of death. Put the NA TCU back in, no flashes???
I had an annoying exhaust leak. Replaced exhaust manifold and and exhaust manifold to up pipe gaskets with GS gaskets. The fire ring is a lot thicker than OEM and has about twice as many MLS layers. However, after bolting them in I could see a gap due to the fire ring being so thick on some parts. I tried bolting everything shut in a few different sequences and still had a gap. Put the OEM gaskets in, no gap.
I discovered the exhaust leak was most likely due to me not torquing the exhaust manifold to the passenger side head correctly. I must have left it finger tight a few weeks back when I removed it to reseal the oil pan. I have since replaced the crossover pipe and drivers side gasket in an attempt to fix the leak, but never noticed the passenger side being loose. Duh.
Put the GS back in and decided to give them a shot even with the gaps. Worked perfectly!
Next I decided to tackle the leaky power steering line. It's the only damn thing that leaks on the SS now. I got out my spare return line and realized the guy who I got it from chopped the end off so it was useless. Ordered a new assembly from Subarugenuineparts. I'd build my own lines but school starts up again Monday. I wonder what it is like to not have a car that is always breaking...
Old 08-28-2017, 12:26 AM   #163
91 RS RA
Member#: 457410
1991 Legacy RS RA
Do you have a code number for the TCU?
I have a couple of places I can look to see whats around, but will need some info to make sure its right.
Old 08-29-2017, 09:12 AM   #164
Tys rex
Member#: 437561
Default That sucks man I hate to lose a good shoe
Originally Posted by krenberry View Post
Yesterday I got a razorblade stuck in my tire. Since it was a holiday and no dealership/tire shop was open I decided to put my winter wheels on until I bought new tires or found a used tire for sale. Upon installing my winter wheels I snapped a lug nut and now it wont come off. I'm beyond happy with how things are going lately.
Was at my buddy's house last week and picked up the biggest screw I've ever seen in my 2 week old michelen pilot supper sports.
Tys rex is offline   Reply With Quote
Old 08-29-2017, 10:42 AM   #165
cmiovino
Member#: 134005
2004 WRX Premium
WRX is sitting in my parents garage awaiting autox this Sunday for the first time in a month.
The borrowed Forester is getting some work in hauling things to my new apartment. On trip 4 or 5 now. Sucker fits a ton.
Old 08-31-2017, 01:31 AM   #166
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
Unfortunately no. I do have the trans code though: TZ102YB3AA. I also can't find any wiring diagrams in order to tease out any wiring differences between the early JDM and USDM 4EATs. It would be pretty cool to do a 93 JDM WRX EJ20G swap as it would almost be 100% plug and play.
At this point I am considering just doing a USDM WRX w/4EAT swap into my first gen turbo legacy SS or what you know as the Legacy RS . That would give me the ability to swap in a newer 4EAT and have tunability, and update all the crappy old wiring. But at least the SS is running like a champ right now so I don't have any rush.
Old 09-01-2017, 12:27 PM   #167
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
I live in South of Houston and the flood waters are coming my way so I took precautions. Our streets may flood, not sure yet. I live by Oyster creek and its projected to be full bank or possibly crest later today and into the evening.
ROTORCRAFT230 is offline   Reply With Quote
Old 09-01-2017, 12:31 PM   #168
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Pontoon it! It is worth the install!
terrainasaurus is offline   Reply With Quote
Old 09-02-2017, 11:24 AM   #169
RC Pilot
Member#: 459411
Finally got around to installing the trailer light harness.
RC Pilot is offline   Reply With Quote
Old 09-02-2017, 11:04 PM   #170
TEKNOSYS
Member#: 79839
2004 WRX Premium
Sedan; Aspen White
Replaced the front o2 sensor in my '04 WRX. Got rid of the P0031 CEL I've had for, oh I don't know, almost 10 years Seriously, I've had a CEL pretty much ever since I installed my TBE. I always assumed it was a minor CEL due to the cat situation. I don't really drive the car that much (~4000 miles a year), so it never really bothered me. The car drove fine except for kinda terrible gas mileage. Guess it's been running really rich. Now that I'm driving the car more these days, I've started to fix all the little issue and even gonna do the open source tune thing. Once I cheked out the CEL and figured what the issue was, I knew I had to replace the o2 sensor before I could start tuning.
Got a Denso sensor from Amazon and put that baby in. The install went off without a hitch, which is rare for me. I always seem to have bad luck with a stuck bolt or something silly like that and it ends up taking me two hours for an oil change or something dumb. Well, today everything went as smooth as silk
It's weird now when I catch my gauge cluster out of the corner of my eye and don't see the yellow CHECK ENGINE lit up anymore. I keep thinking somethings wrong because I don't see it anymore, lol
TEKNOSYS is offline   Reply With Quote
Old 09-03-2017, 01:10 PM   #171
LogieBuggy
Member#: 473899
Restored oxidized headlights
Taped up.
400 grit wet sand
600 grit wet sand
2000 grit wet sand
Taped up and plastic
Wiped with 91% alcohol and microfiber towel
Clear coat 4 times .. 5 minutes between coats.. vertically sprayed then horizontally
Gonna wait until tomorrow to let the Clear coat cure
Then wet sand with 3000 grit and wax/polish
LogieBuggy is offline   Reply With Quote
Old 09-03-2017, 10:43 PM   #172
f22boy
Member#: 464019
2017 Wrx
ISM
Not technically today, but since tuesday... soo many "just cuz" drives
f22boy is offline   Reply With Quote
Old 09-04-2017, 12:48 AM   #173
RallyBlueSubaru
Member#: 371569
2002 Impreza WRX
Put wrx seats in my 2.5rs
RallyBlueSubaru is offline   Reply With Quote
Old 09-04-2017, 09:15 PM   #174
TEKNOSYS
Member#: 79839
2004 WRX Premium
Sedan; Aspen White
Changed half the spark plugs in my '04 WRX (drivers side). Took an hour to do the one side because it was my first time and the rear coil pack bolt was fighting me the whole time. None of my sockets, extensions, swivel adapters could really get it (all 3/8, next time I'll be ready with 1/4). Ended up using a harbor freight bolt extractor socket and removed it by hand. Uggg. By the time I got both spark plugs swapped out, I lost the light outside so I figure the other two can wait until tomorrow.
Here's a pic of the factory plugs after 13 years and ~50k miles (sorry for the flash)
[IMG][/IMG]
Old 09-05-2017, 11:45 PM   #175
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
Installed new OEM power steering lines on the SS. What a pain in the ass. Took forever to get the new lines threaded on the hard lines of the steering rack. It would have been easier to install them when I replaced the steering rack a few weeks ago, oh well.
Steering feels great and for the first time in years there are no leaks whatsoever under the SS! When I did the head gaskets years ago a cam seal leaked, there was a cracked oil pan, cracked transmission fluid lines, the steering rack pissed fluid out of every seal...
