Welcome to the North American Subaru Impreza Owners Club Saturday November 16, 2019
Old 10-02-2019, 01:39 AM   #1
mik_sti
Member#: 470125
2005 Impreza
Candy Blue
Default Insanely high injector duty cycle HELP!!!
Hey subaru folks, looking for some technical advice. Ive been seeing some crazy high injector duty cycles lately for eg while revving under no load at 5-6k rpm ill see figues of about 150%. Sometimes i would also get a really lean break up and hesitation whilst driving also, lean as in off my wide band lean and wont cross 2k rpm, but doesnt happen all the time. I only started to notice this problem after i installed a 10 gallon fuel cell with a gravity fed 044 pump that is hardwired. But im not entirely sure what could be the problem, i suspect the pump may be trash or i may have a wiring issue on the engine harness side. But im not sure, the fuel pressure reg seems to be working and i cleaned my injectors recently too. Any thoughts?
Mods:
044 300lph pump hardwired (10an gravity fed, 6an to engine)
10 gal fuel cell
Rc750cc injectors
Tomei fuel pressure reg type s with rails in parallel
Tomei M7960 turbo
Tial 38mm Ewg with 14psi spring
mik_sti is offline   Reply With Quote
Old 10-02-2019, 02:51 AM   #2
mik_sti
Member#: 470125
2005 Impreza
Candy Blue
Ignore my afr correction, only reason it’s so high I because I turned up the base pressure a little to see if it would lower the injector duty
Old 10-02-2019, 08:23 AM   #3
rtv900
Member#: 428511
2016 STI
You must be in a time vortex or something if you injector is operating 50% more time than exists
either that or the data is simply incorrect
rtv900 is offline   Reply With Quote
Old 10-02-2019, 12:01 PM   #4
mik_sti
Member#: 470125
2005 Impreza
Candy Blue
���������� I really hope I’m not in a time vortex. I’m certainly not the tuner, but I could post the injector data on the map, if you want ?
Old 10-02-2019, 01:08 PM   #5
rtv900
Member#: 428511
2016 STI
^all I mean is a 100% duty cycle means that the injector is 'open' (spraying) 100% of the time.
So it can't really be spraying fuel 150% of the time right? If that were the case it would be spraying fuel 3 seconds out of every 2 seconds of real time, hence the time vortex comment.
Something is borked with your data
Old 10-02-2019, 01:10 PM   #6
mik_sti
Member#: 470125
2005 Impreza
Candy Blue
what youre saying makes sense, I appreciate that you took the time to reply.
This is the injector data ive got
Here is the manufacturer data https://www.rcfuelinjection.com/Port...tency_Time.pdf
dead times on my map:
6.5V= 3.20ms
9.0V=1.13ms
11.5V=0.80ms
14.0v=0.62ms
16.5v=0.46ms
flow rate = 750.09cc
Old 10-02-2019, 01:32 PM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
6.5V= 3.20ms
9.0V=1.13ms
11.5V=0.80ms
14.0v=0.62ms
16.5v=0.46ms
something isnt right on your data. I would point to the latency or scaling as being off, just fyi the numbers they injector copanies give arent always right.. I had to adjust mine for my ID's to make the car run
subaru_gc8 is offline   Reply With Quote
Old 10-11-2019, 09:31 AM   #8
subaruandmr2
Member#: 472573
2003 Impreza WRX
IDC can go well past 100% as seen before with others logging and pushing the stock injectors (although 150% is a bit high). So the issue could be with your logging but if you're experiencing lean conditions on your wideband then thats indicitive of your fuel pump failing.
If your fuel pump can't maintain proper pressure, the injectors would need to stay open much longer to get the same amount of fuel in. This is why increasing your fuel pressure is equivalent to increasing injector size.
Go borrow a fuel pressure test kit from Autozone. The loan them out for free, although they will put a $150 charge on a credit card that you get back when you return the kit. With the kit you can check your fuel pressure at idle. It should be roughly 43.5 psi. I suspect you're going to see like 10psi of pressure when you go to check.
subaruandmr2 is offline   Reply With Quote
Old 10-16-2019, 12:30 AM   #9
mik_sti
Member#: 470125
2005 Impreza
Candy Blue
i really appreciate your feedback, im currently setting up a new fuel pump, seems i was experiencing premature pump failure due to the foam in the fuel cell breaking down and getting trapped in the pump.
Old 10-16-2019, 10:21 AM   #10
rtv900
Member#: 428511
2016 STI
ok, then the figure is not actually duty cycle, it is another factor of some kind and they're just using the term duty cycle
duty cycle is run time out of actual time
nothing can run more than 100% of the time
Old 10-17-2019, 01:13 AM   #11
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
The logger lists injector duty, but the readings and the way he revved it correspond with MAP in kPa units.
Check your data channels in the display.
mrsaturn7085 is offline   Reply With Quote
Old 10-31-2019, 11:30 PM   #12
mik_sti
Member#: 470125
2005 Impreza
Candy Blue
i borrowed the laptop i was using and was in a mild rush, i installed a fresh new aem pump and redid the wiring, and have been logging different parameters for the past few days, however my injector duty is still pretty high like 102%. I should mention that my maf scaling wasnt completed when tuning due to the high idc, so i dont know if that is contributing to the issue. Im gonna try throwing in another fpr, try some wrx decaps and check my engine harness later in the week.
