Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 10-17-2019, 12:34 AM   #1
Grinder_1
Member#: 507481
Default New and confused
I signed up to try get help with a problem on an 09 Impreza. It is a problem that has come up so many times, that I am actually afraid to ask it. It seems it doesn't matter though because I can't post till I have three legitimate replies. I have researched this problem online, and have even contacted a Subaru person locally.
How should I obtain my other two replies so I can post this question?
The test connectors were hooked up under dash. CEL started flashing, and fans started kicking on and off constantly. Upon reading codes.
4 came up as set, and then the same 4 came up as pending. I cleared them. They immediately returned..but only one set this time. I thought the connectors had been disconnected at the time. Had them disconnect the green connectors, and cleared codes again. At this point everything I have been told, or read says everything should have returned to normal. Still CEL, and same 4 codes. Why with the connectors separated, is clearing the codes not resetting the CEL?
Grinder_1 is offline   Reply With Quote
Old 10-17-2019, 01:22 AM   #2
snow_bound26
Member#: 395793
2005 92x Aero
What are the codes?
snow_bound26 is offline   Reply With Quote
Old 10-17-2019, 02:42 PM   #3
Fndragn
Member#: 470845
2011 Sti
If they come back right away there’s probably more to it and a simple reset isn’t going to do it. That’s just a guess tho.
Fndragn is offline   Reply With Quote
Old 10-17-2019, 03:31 PM   #4
Jack
Add Lightness
Member#: 13699
not my president
(From General)
They're not staying reset because the ecu is detecting the issue is still there. List what codes you're seeing.
Old 10-20-2019, 11:53 AM   #5
Koulbreeze
Member#: 499465
2011 STI
WR Blue
Use imgur to host your pictures if you're going to post pics.
Koulbreeze is offline   Reply With Quote
