Welcome to the North American Subaru Impreza Owners Club Friday November 22, 2019
Old 06-12-2019, 03:12 PM   #51
Rs2.5wrx03
Member#: 503164
Default 2005 2.5rs ej20 jdm swap obd2 connection
Hey, guys new to the forums so I've been searching for something that relates to my current issue and was wondering if anyone can help me, I recently purchased a used Subaru 2.5rs that has an 03 wrx engine swap in it after pulling down the dash because I noticed a few loose wires I came to find that the backing retainer for the obd2 port was missing and one of the wires connected to it went to nothing does anyone have any idea what the pins order should be and what color wires should go where?
Rs2.5wrx03 is offline   Reply With Quote
Old 09-24-2019, 02:30 PM   #52
Ej-mikeylikey
Member#: 506737
Buy a bulkhead harbess 90% should hook up for about 250$ i bought a jdm ej205bwith avcs and i wanted the avcs.. So i bought a harness for my outback sport swap mostly everything hooks up a few grounds the ignition wires were so close to being identical have to pull those off the old harness .. Fuel pump wires pedel grounds ignition plug wires pretty much went a together still working on the fuel pump controller since the na 2.5 just came with a regular set of connector wires turbo charged engine has this controller set up .. If anybody knows anything about how to merge the controller i could use it!
Ej-mikeylikey is offline   Reply With Quote
Old 09-24-2019, 02:30 PM   #53
Ej-mikeylikey
Member#: 506737
Buy a bulkhead harness 90% should hook up for about 250$ i bought a jdm ej205 with avcs and i wanted the avcs.. So i bought a harness for my impreza outback sport swap mostly everything hooks up a few grounds the ignition wires were so close to being identical have to pull those off the old harness .. Fuel pump wires pedel grounds ignition plug wires pretty much went a together still working on the fuel pump controller since the na 2.5 just came with a regular set of connector wires turbo charged engine has this controller set up .. If anybody knows anything about how to merge the controller i could use it!
Old 11-02-2019, 09:30 PM   #54
Jetmech60
Member#: 507704
2016 Forester
Gold
Just my two cents I would use heat shrink tubing instead of electrical tape just remember to put it on the wires before you solder
Jetmech60 is offline   Reply With Quote
Old 11-04-2019, 05:09 PM   #55
CosmicChocolate
Member#: 508045
Post
you could just crimp the wires together not to expensive but it not them best thing to do for a wiring harnes i would recommend soldering like everybody else which is still not that hard or expensive
CosmicChocolate is offline   Reply With Quote
DIY MAF Wire Extension ( diy shielded sensor cable ) Bad Noodle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 04-13-2012 08:22 PM
For you Passport fans - DIY direct wire Smartcord cannibal869 Interior & Exterior Modification 1 11-22-2004 02:53 PM
? for DIY Grounding Wires gr8-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-31-2004 12:16 AM
questions about DIY 5-wire WB sensors Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-16-2003 11:26 PM
Stock Harness Wiring Diagram Nick Car Audio, Video & Security 2 07-18-2000 10:57 AM
