Welcome to the North American Subaru Impreza Owners Club Wednesday November 20, 2019
Old 10-13-2019, 06:38 AM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
Default Blouch manufacturing defect
Upon inspecting my 1.5 TS XTR I found two tiny holes under the coolant ports, which are clearly result of machining error when they were making holes for the oil drain adapter, they went too far and penetrated the cartridge housing
I would not care, if it wasn't in the oil drain section, and this is the cause the turbo and surroundings was all black from oil vapor, I also wonder if it was the case of my mysterious oil disappearance
I feel welding this might be troublesome, because its iron that has been sitting in oily environment and sucked it in good
Would JB welding be ok for this? Don't know how hot this area gets
Hyper is offline   Reply With Quote
Old 10-13-2019, 01:54 PM   #2
stu
Member#: 25768
2003 GEN2 GTX35 40++
SL performance, 2.34 LR
Has it been leaking?
stu is offline   Reply With Quote
Old 10-13-2019, 03:06 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
upon further inspection turns out it doesn't connect to the oil galley, so I am not even going to bother with it
Old 10-13-2019, 03:42 PM   #4
Subie_
Member#: 419354
2007 STI
Crystal gray metallic
Porosity is a common defect in casting processes. Yours appears to be aesthetic.
I always put a note on my drawings instructing the foundry to fill non-structural voids with metal putty to keep our incoming inspection from quarantining my parts for visual defects.
Subie_ is offline   Reply With Quote
Old 10-13-2019, 04:02 PM   #5
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
A bit off topic, but how have you liked the turbo? I've seen very little feedback on the twin scroll version.
I'm debating on going this route when I finally start modding the engine. My car is a daily driver so I don't care about huge power figures, but would prefer the responsiveness and efficiency of a twin scroll setup. In all likelihood, I'd even keep the stock intake & catback since I'm in California and they're efficient enough.
  • OEM JDM TS header & uppipe
  • TS catted downpipe - probably the dual cat HKS version & OEM for smog
  • Blouch DOM 1.5 XTR TS
  • Cobb flex fuel kit - because 91 in California is terrible
I'm hoping that the EJ257's extra displacement combined with TS, aftermarket downpipe & ethanol should make for a nice & responsive daily driver. I have no power goal in mind, but I expect in the range of 350-400 whp with a nice torque curve on E85.
I looked into obtaining an S series turbo for its size and OEM reliability, but they're very cost prohibitive.
I found a VF58 (ST14411ZR010) for the low price of $3,380 plus shipping.. I believe this was the turbo used on the S206 & S206 NBR.
http://www.jp-carparts.com/subaru/pa...e=ST14411ZR010
Another option is from Tomei called the T380B-EJTS. This turbo is the result of collaboration between IHI & Tomei aiming to improve the top end of the standard turbo. It's rumored that this is the same turbo used on the S207. This is around $2.5k + shipping.
http://www.tomei-p.co.jp/catalogue/t380b-ejts/
WRXnick16 is offline   Reply With Quote
Old 10-13-2019, 05:20 PM   #6
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
best TS bolt on turbo on the market, period
I have tried PE, HKS, Tomei, all crap
This baby really delivers, especially after I ported it
I only wish build quality was higher
Old 10-13-2019, 05:34 PM   #7
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
I only with build quality was higher
Thanks for the feedback!
