Welcome to the North American Subaru Impreza Owners Club Saturday February 22, 2020
Mid Atlantic Impreza Club
Old 12-10-2014, 11:33 PM   #8901
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Originally Posted by no694terry View Post
McKamish has always tried to be slightly above the average on benefits.
Lol. That's what they all tell you. My company has been acquired 3 times in 4 years. That's the company line every time it gets worse. Even the controller at the small company they were for 30 years would use that line. That's code for: "if we could pay less we would, but we'll keep trying"
isis is offline   Reply With Quote
Old 12-11-2014, 03:48 PM   #8902
reide181
Member#: 276915
2011 WRX Limited
Satin White Pearl
For sale if anyone is interested in a local sale!
http://forums.nasioc.com/forums/show....php?t=2687040
reide181 is offline   Reply With Quote
Old 12-11-2014, 05:13 PM   #8903
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Love em. Wish I had the dough to buy a car and put them on it.
Old 12-11-2014, 09:24 PM   #8904
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Who bores blocks?
no694terry is offline   Reply With Quote
Old 12-12-2014, 01:00 AM   #8905
Moore Performance
Member#: 231489
Who bores blocks?
Might know a guy who does that.
Moore Performance is offline   Reply With Quote
Old 12-12-2014, 08:37 AM   #8906
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Figured you guys might. I dug out my almost completely rebuilt 2.5 heads yesterday to finish them, need to adjust shims. I'll need my other 2.2 block bored to match some Wiseco K601M975 pistons on sti rods.
Old 12-12-2014, 08:47 PM   #8907
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Gonna call u Frank for all the unconventional combinations.
Old 12-13-2014, 01:51 AM   #8908
MRF582
Member#: 48219
. Always drive
the race line .
Generally speaking, you can put a smaller combustion chamber diameter head on a larger bore but not the other way around... Are you aware of this and have verified it won't be a problem?
MRF582 is offline   Reply With Quote
Old 12-13-2014, 09:40 AM   #8909
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
I have 99mm bore heads on a 97mm bore and 100mm head gaskets right now making 330whp. BUT its been cutting up at high rpms over 20psi and cant rule out the mushroom as a cause. It runs well at 16psi i just want to build a spare block. I prefer 2.2. My spare heads are from a ej25de and have the cloverleaf chambers that fit inside even the 2.0 bore, but to put them on a 2.2 block i need deeper pistons. The wisecos are 24cc or something and should give me an 8.5:1 ratio and i can go back to a 2.2 head gasket. Im looking for 400whp.
Thats the beauty with phase one stuff. Trial and error is cheap. Just gotta keep the AAA plus renewed
Old 12-13-2014, 01:32 PM   #8910
garagedefeat
Member#: 101399
2001 Forester L
Are you running the clovers now?
Can you post up your dyno graph? I wanna check it ahhht.
garagedefeat is offline   Reply With Quote
Old 12-13-2014, 02:28 PM   #8911
Josh R.
Member#: 351365
2018 Subaru-less
1997 Integra GS-R
Haha DYNO graph! noDYNO4terry! ; )
Josh R. is offline   Reply With Quote
Old 12-13-2014, 04:52 PM   #8912
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
lol.. well... a fellow member once told me not to waste money of dynos for my budget builds and that virtual dyno was good enough so thats what i use. take it as you will. default corrected dynojet. pentroof hla heads on stock 2.2 block
october 31st 245/45/18 summer tires
November 18th 215/60/16 snow tires, start of my afr issues
Old 12-13-2014, 08:20 PM   #8913
MRF582
Member#: 48219
. Always drive
the race line .
What did you change in the map between those two runs? Can you post screenshots of before/after?
Old 12-14-2014, 10:14 AM   #8914
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Thats when the weather changed and i started getting compressor surge that screws with my maf volts and it turn screws with my fueling. I dont think the weather had much to do with it but i ran that psi no problem until it got cold out, now i cant go over 15 without surge. Cant figure it out
Old 12-14-2014, 03:44 PM   #8915
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Why does it take till after 4k to hit full boost? Is that normal for that turbo/engine combo?
Old 12-14-2014, 04:18 PM   #8916
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Not sure, its always been a slow spooler. i just thought it was from the big fmic and 2.5" piping on a 2.2L. I also have a small 1.625 ID uppipe, huge intake ports and valves, NA cams, many factors i guess
Old 12-14-2014, 05:46 PM   #8917
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Not always a bad thing or a problem. The power curves look pretty good.
Old 12-14-2014, 05:54 PM   #8918
MRF582
Member#: 48219
. Always drive
the race line .
Why didn't you mention the uppipe gasket leak you found?
Old 12-14-2014, 08:42 PM   #8919
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Ya that too. I installed a new gasket in it to no avail, must have warped flange. I going to be converting it to a Saturn downpipe 3 bolt gasket/flange once i pick up a gasket and burn some flanges
Old 12-18-2014, 08:38 AM   #8920
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Finally blew it up this morning. I suspect a piston. Its still running but smoking like crazy. I dont think its the turbo because its misfiring, no knocking, good oil pressure, at least until its empty.
Old 12-18-2014, 09:31 AM   #8921
Josh R.
Member#: 351365
2018 Subaru-less
1997 Integra GS-R
Sure you didn't just blow a seal?
Everybody know that joke or should I explain?
Old 12-18-2014, 09:42 AM   #8922
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
It maybe could be a head gasket but I don't think they leak oil into the cylinders too often. Im pretty sure I have a significant gap between a piston and a wall in one or more of the bores. It wasnt running right all morning then a forth gear pull did her in. I dont mind, I have more blocks. I was just hoping to finish my next build first, now im going to be rushed which means cut corners.
Old 12-18-2014, 12:07 PM   #8923
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Hey guys, anyone looking for back to stock exhaust parts?
I have a complete stock 07 wrx exhaust if someome is looking to trade. Im looking for a catless up pipe, catless down pipe and cat back. Has to fit 02-07 wrx.
slowgenius is offline   Reply With Quote
Old 12-18-2014, 12:09 PM   #8924
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
how about an 07 block?
Old 12-18-2014, 12:13 PM   #8925
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I have an 07 long block with a broken cam gear, i planned on using it with a spare set of heads i have. We could work something out since i have to pull it and split it anyway.
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 07:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 11:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 04:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 10:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 08:23 PM
