Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 10-15-2016, 04:45 PM   #651
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Default Killer B OEM-ish TURBO Kit GTX3067-R with Tial Turbine Housing 'The Spoolinator'
Ok, so lots of issues unfortunately on tune day.
FPR replaced (1 year old?)
Fuel Pump replaced (1 month old)
Rewiring on fuel pump assembly, possibly misconnected ground
Jr and Prime were stuck for 5? Hrs? On the Dyno I think :/
But my GTX 3576 finally got tuned:
MazNJ is offline   Reply With Quote
Old 10-15-2016, 04:53 PM   #652
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Old 10-15-2016, 05:19 PM   #653
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Final output:
Will admit I was expecting more since I thought I had significant advantages, especially in the heads.
Old 10-15-2016, 08:40 PM   #654
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Originally Posted by subaru_gc8 View Post
give me a few months I am building a 2.15, with v9 heads with working avcs and poncams. i just bought a gtx3067, so i can see who it does.
cool, my project wont begin until the spring anyways so thats lots of time
Titter is offline   Reply With Quote
Old 11-11-2016, 07:03 PM   #655
TeddyK
Member#: 404608
2010 WRX sedan
Just checked on my status with my mechanic and the GTX3076r is back from blueprinting; everything is within spec, which I later thought might happen. My car is going to be dropped off next week for install of the Spoolinator kit and my AWIC setup. Also, I bonded a copper/aluminum cold plate to the bottom of the reservoir and I am going to run liquid CO2 or NOS through it to chill the water via switch as an instantaneous option versus stopping and dumping ice in the reservoir.
TeddyK is offline   Reply With Quote
Old 11-11-2016, 07:57 PM   #656
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Good luck!
Old 11-11-2016, 11:18 PM   #657
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, UGM
Rotated EFR 6758
Where are you placing the res? Using that cold plate will cause a lot of condensation if you aren't in a very dry place. I get condensation just driving around on my res since the heat exchanger keeps the water so cool, then again, it's 80% humidity outside so that's a thing.
Krang is offline   Reply With Quote
Old 11-12-2016, 01:14 AM   #658
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
I'm assuming those graphs are pump and e85?
Both seem about normal to me number wise...what were you expecting?
Can you post a mod list?
Old 11-12-2016, 11:59 AM   #659
TeddyK
Member#: 404608
2010 WRX sedan
In the trunk, still trying to figure out to best insulate it. The cooling unit will only be used in a few weekend bursts, nothing regular. Condensation in the intake would not be good.
Old 11-12-2016, 08:17 PM   #660
motorbykemike
Member#: 273868
I think he meant
condensation on the reservoir
motorbykemike is offline   Reply With Quote
Old 11-12-2016, 08:18 PM   #661
motorbykemike
Member#: 273868
teddyk
'deets on the awic ?
Old 11-12-2016, 11:28 PM   #662
MazNJ
Member#: 388661
2013 WRX STI 5Dr
My mods are similar to Killer B's but with IAG Stage V heads, the 1.03 housing, and a bigger intercooler. Chris put down 600 so with superior heads and a larger housing, I was expecting to go over that.
Old 11-13-2016, 11:44 AM   #663
TeddyK
Member#: 404608
2010 WRX sedan
Originally Posted by motorbykemike View Post
teddyk
Back on page 26 of this thread; I will be posting Spoolinator tune stuff here and a complete one in the AWIC thread.
Old 11-15-2016, 11:21 AM   #664
kevmo11
Member#: 403684
2006 sti
cgm
What size injectors maz?
kevmo11 is offline   Reply With Quote
Old 11-15-2016, 11:22 AM   #665
MazNJ
Member#: 388661
2013 WRX STI 5Dr
ID1700s
Old 11-16-2016, 01:16 PM   #666
subaru_gc8
Member#: 29292
2004 WRX wagon
whats your idc?
subaru_gc8 is offline   Reply With Quote
Old 11-16-2016, 01:54 PM   #667
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Only 69.02 on e85
Old 11-16-2016, 04:47 PM   #668
subaru_gc8
Member#: 29292
2004 WRX wagon
Cool lots of headroom
Old 11-18-2016, 12:32 PM   #669
Paul
Member#: 56203
00 RSTI Coupe
I understand now and see why you expected that.
Unfortantly there could be lots of reasons why and I won't speculate too much...did you mention something to the tuner (Im assuming JR)?
All too often people take their cars to get tuned and never talk to the tuner about the cars uses, and goals. I can see him stopping where he did for a DD but if you asked for him to push it for a drag map I bet you'd make your 600+....if there's not a limitation somewhere.
Old 11-18-2016, 12:36 PM   #670
MazNJ
Member#: 388661
2013 WRX STI 5Dr
I totally understand that but I believe Chris and I both specified that it is a daily driver. Jr's response seemed to suggest he saw mine as more daily that Chris and sought to preserve it more. But Chris seemed to think the same for his. Either way, I've modified my driving method steadily with it and as long as it gets more rev it's fine though I miss the low end power.
Old 11-18-2016, 02:53 PM   #671
Paul
Member#: 56203
00 RSTI Coupe
When you shops post results take it with a grain of salt....even if it's not a shops car some make better power than others and others just seem down on power for no apparent reason.
Old 11-18-2016, 09:11 PM   #672
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
KBM2 has one map. The car is used as a daily driver, sometimes auto-X. There is no 'kill' map, but there is a baby seat in the back.
Without seeing the tunes side-by-side, there's no way to tell. While our setups are similar there are still many differences: Injectors, SB (crank, piston, sleeves, wrist pins...), oil pump, cat-back, head porting, vacuum A/O separator, intake, etc... What that all adds up to, or doesn't is anyone's guess.
KillerBMotorsport is offline   Reply With Quote
Old 11-25-2016, 12:23 PM   #673
Jermaine2011wrx
Member#: 280095
Any deals today on spoolinator kits?!?!
Jermaine2011wrx is offline   Reply With Quote
Old 11-25-2016, 01:35 PM   #674
subaru_gc8
Member#: 29292
2004 WRX wagon
Th motorsports has one
Old 11-25-2016, 03:44 PM   #675
Jermaine2011wrx
Member#: 280095
cool thx
