Welcome to the North American Subaru Impreza Owners Club Thursday November 21, 2019
Old 06-16-2017, 09:30 AM   #776
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Another company(s) do use a inconel up pipe and maybe that's where the confusion came from.
Old 06-16-2017, 09:37 AM   #777
vicious_fishes
Member#: 158864
2003 SOHC destroker
I imagine an inconel welder would demand a pretty penny for their services
vicious_fishes is offline   Reply With Quote
Old 06-16-2017, 09:51 AM   #778
AtomicRacer
Member#: 84586
1995 FRANKNTURD
2012 Tundra DC 5.7L
Originally Posted by Paul View Post
Another company(s) do use an inconel up pipe and maybe that's where the confusion came from.
That was Cobb. Very limited run and impossible to find now.
-Paul
AtomicRacer is offline   Reply With Quote
Old 06-16-2017, 10:53 AM   #779
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The process is not much different. We've done some small stuff here. It's 8X material cost that gets you.
KillerBMotorsport is offline   Reply With Quote
Old 06-16-2017, 11:08 AM   #780
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
back on topic a bit.
I'm really looking forward to trying this setup soon.
spoolinator w/ gen2 GTX3071. want 400+ on pump gas, stock heads and cams (built block)
my only problem is that i currently dont have an EWG up-pipe. I have a KB header/vband up-pipe, so i'll have to pull the up-pipe, weld on an EWG stub, then re-install. makes for a bit more work unfortunately.
does anyone know if there are any GTX turbine housings with v-band inlet, that also have a EWG port on the turbine housing? that would eliminate the need to have an EWG on the up-pipe itself. just thinking out loud.
gsrcrxsi is offline   Reply With Quote
Old 06-16-2017, 11:37 AM   #781
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
That should do the trick
If you can be down for a bit, we've done this before; adding an EWG to our up-pipe. The downside is the downtime.
No there are not. You really don't want the EWG port that close to the turbine wheel anyway. It can induce funky turbulence into the volute and cause a decent hit to performance. Ideal EWG port location is at least 6" from the entry to the wheel and not further than 9" or so inches. This is what I'd consider the sweet spot for maximizing turbine performance.
Old 06-16-2017, 02:19 PM   #782
wrxhard
Member#: 108091
Why no more than 9"?
wrxhard is offline   Reply With Quote
Old 06-17-2017, 10:05 PM   #783
vicious_fishes
Member#: 158864
2003 SOHC destroker
9's pretty impressive, I'm only 7.5.
Old 06-18-2017, 09:53 AM   #784
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Anything above 9" is far too emasculating
Old 06-18-2017, 10:44 AM   #785
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Possibly because the further away you put it the larger volume of gases that will still have inertia to continue spinning the wheel after the gate is opened? I'm curious as to how that range is the sweet spot. What happens when it's closer or further from the turbine?
2slofouru is offline   Reply With Quote
Old 06-18-2017, 01:31 PM   #786
wrxhard
Member#: 108091
Closer he specifically calls out turbulence induced by the gate. Doesn't mention the reason for no more than 9".
Old 06-18-2017, 05:03 PM   #787
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Ordered the 3576r gen2 kit, can't wait to get this up and running. I'm really curious what it will do on pump fuel as well as e once it's dialed in, with my setup.
Old 06-18-2017, 05:56 PM   #788
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Retuning my gen 1 tomorrow
MazNJ is offline   Reply With Quote
Old 06-18-2017, 06:22 PM   #789
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Cool deal, what are your changes since the previous tune? Is it for the supertrapp removal?
Old 06-18-2017, 06:40 PM   #790
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Supertrapp removal, installation of radium dual hanger. Also installing an ID F750 fuel filter but doubt that requires adjustment for.
Old 09-13-2018, 08:42 AM   #791
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Been getting questions on the Spoolinator a lot lately. Bump to raise awareness
Old 09-13-2018, 08:57 AM   #792
kevmo11
Member#: 403684
2006 sti
cgm
Iím so ready to have my spoolinator/ e85 combo tunes!
kevmo11 is offline   Reply With Quote
Old 09-13-2018, 09:03 PM   #793
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Are you all together and waiting for a tune date?
Old 09-13-2018, 09:09 PM   #794
kevmo11
Member#: 403684
2006 sti
cgm
Yes, I had a Wiring slip up last go round on the dyno and panicked. Itís all squared away now! Running p and l twin fuel pump hanger!
Old 09-14-2018, 08:32 AM   #795
eaglehunter
Member#: 216747
2009 STi
Dark Grey Metallic
Hi Chris, i saw a while ago that you were/ are working on additional spoolinator kits using the new garrett series turbos... how is that coming along and any updates worthwhile sharing?
eaglehunter is offline   Reply With Quote
Old 09-14-2018, 02:20 PM   #796
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sweet!
Slow, but I am coming back around to it soon. I have all the turbo CAD models finally and will be doing some layouts to see feasibility. Based on the stuff I'm doing on other platforms with the G-Series, there's a relatively high probability of success.
Old 09-15-2018, 11:29 PM   #797
eaglehunter
Member#: 216747
2009 STi
Dark Grey Metallic
Nice! Looking forward to it.... at this point I am still set on the 3576 but am willing to wait to see what the G series will offer... I wont make a final decision before april next year anyway and if I am lucky, you may have more information by then.
Old 09-16-2018, 03:13 AM   #798
subaru_gc8
Member#: 29292
2004 WRX wagon
there is a guy that dynoed his with a 2.35 and it wasnt bad.
here it is
https://forums.nasioc.com/forums/sho....php?t=2883288
subaru_gc8 is offline   Reply With Quote
Old 09-16-2018, 09:00 AM   #799
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
here it is
Not really a decent comparison since it's on a different kit and a stroker engine. Nice looking plot though.
This would be great to compare the G-Series with a GTX before plot to go with it patience
Old 09-16-2018, 10:57 AM   #800
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Think its a de-stroked motor, 2.35 regardless that changes a LOT.
Scuby04STi is offline   Reply With Quote
