Welcome to the North American Subaru Impreza Owners Club Sunday November 17, 2019
Old 08-26-2015, 02:00 PM   #51
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Originally Posted by Uncle Scotty View Post
new gas cap???
How was purgatory? Did you see Sam and Dean?
Gallo2011 is offline   Reply With Quote
Old 08-26-2015, 02:35 PM   #52
SJSC1608NJ
Member#: 388567
2014 WRX Hatch
ISM
Awesome write up! thank you for taking the time to help out!
SJSC1608NJ is offline   Reply With Quote
Old 09-01-2015, 08:50 AM   #53
Sid03SVT
Member#: 183032
OLD Family Wagon
This is soooo timely; I've got around 100,500 as of this morning, I just did a clutch job (and group N trans mount & bushings) and checked a bunch of crap while I was under there, but not everything. I'll be giving this a thorough read and crawling back under the car this weekend. Thanks for posting, and I agree, 100k is mid-life not end times. Timing belt looks like a cake walk after the clutch job I just did.
Sid03SVT is offline   Reply With Quote
Old 09-01-2015, 09:49 AM   #54
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Got me a new boost control solenoid, maf sensor on the way, oring and screws, wheels at the repair and paint shop....shes gonna be all purdy and smooth. Turbo inlet after I see how shes doing with the other two parts, one at a time of course.
left footed whooten is offline   Reply With Quote
Old 09-01-2015, 10:38 AM   #55
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
my PS was all jjuuddeerryy.....and stuff---reservoir full of foaming bubbles ....pulled the hoses off the reservoir, cut ~3/4 inch off each one....put them back on, worm gear clamps...refilled the reservoir and after a couple days of letting all the air out...
but...it needs a new axle, now and...moar...stuffs and stuff
Old 09-01-2015, 11:59 AM   #56
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
also check the o-ring on the hose adpatoer on top of the PS pump - on my 03 Outback AND my WRX - the o-ring were like plastic.
1 Lucky Texan is offline   Reply With Quote
Old 09-01-2015, 04:06 PM   #57
Uncle Scotty
Member#: 16200
OK buy Nates beans
yeah...that is #2 on the check list for this issue....after the hoses to the reservoir.
that o ring is a bastard to find....its a 13x1.9mm and you can get one from Honda....pn 91345-RDA-A01 for cheeeeap
Old 09-02-2015, 11:16 AM   #58
mrtouchdown
Member#: 258082
2010 WRX STI
Had my timing belt done no issues. They found my oil cooler O ring torn so they replaced that and all my oil lines. Now i hope no more oil leaking!! Midlife maintenance all done at 113000 km
mrtouchdown is offline   Reply With Quote
Old 09-02-2015, 12:16 PM   #59
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
200,000 miles this past saturday. Mid-life it is Hell it took 150,000 to need a clutch! Cant wait for my booty to show up, she needs a reward. Turned her to 200k in Yosemite. Perfect.
Old 09-02-2015, 05:30 PM   #60
mrtouchdown
Member#: 258082
2010 WRX STI
i wanted to post some pics of the work i got done but i have no idea how lol.
Old 09-04-2015, 02:58 PM   #61
reaganchung
Member#: 416769
2003 WRX vf48
When do you guys recommend having an O2 sensor replaced?
reaganchung is offline   Reply With Quote
Old 09-04-2015, 03:31 PM   #62
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
Bosch recommends replacing unheated one- or two-wire O2 sensors on 1976 through early 1990s applications every 30,000 to 50,000 miles. Heated three and four-wire O2 sensors on mid-1980s through mid-1990s applications should be changed every 60,000 miles. And on 1996 and newer OBD II-equipped vehicles, the recommended replacement interval is 100,000 miles.
Here.
oaklandish_WRX is offline   Reply With Quote
Old 09-04-2015, 03:37 PM   #63
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Our O2 sensors will let you know. Sadly, the front one is kinda pricey so it can be a kick in the teeth, but I wouldn't say there's a need per say to replace just for fun as even with a 100% jank one, your car will still get you to work. No code/no horrendous MPG....no worry say I, but others have other opinions.
Old 09-04-2015, 05:33 PM   #64
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I've had an o2 sensor go out on me that never told me it was broken, they are on their last leg once you pass 100k/miles. No it’s not a “leave you stranded on the side of the highway” type of thing but it will fail.
Also I would clean the iacv, too many people don't even know, or forgotten what their car is supposed to sound like when its idling.
2gnt2wrx is offline   Reply With Quote
Old 09-06-2015, 10:51 PM   #65
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
fuel filter and fuel pump should be mentioned
good stuff as always duder!
Titter is offline   Reply With Quote
Old 09-06-2015, 11:35 PM   #66
El Wray
Member#: 303030
2009 STI
Just stumbled in here for the first time. Great post. Unfortunately a reminder for me that it may be time to part ways soon. Made me sad in the wallet.
El Wray is offline   Reply With Quote
Old 09-25-2015, 09:27 PM   #67
TristanWu
Member#: 430279
1996 1.8 brighton
Green
Going spending lot of time in this thread. Thanks!
TristanWu is offline   Reply With Quote
Old 09-25-2015, 10:15 PM   #68
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
New MAF sensor and boost control solenoid perked her right up! Noticeable difference. Motor mounts and turbo inlet next. Switched back to a regular air filter too, no more K&N.
Old 09-28-2015, 02:04 PM   #69
my name is joe
Member#: 171412
I think this thread needs specifics including oem part# to those who don't know what they're reading.
stickies should be spoon fed so we dont have the annoying question of which bushing should i change and what kind?
theres more to it than rubbers
my name is joe is offline   Reply With Quote
Old 09-28-2015, 02:10 PM   #70
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Really? I mean we all have internet and a subaru parts dept, I was able to take what I found from this thread and with little to no effort, get my parts online and from the local dealer parts dept. You can do it. Driving the car itself takes the same amount of effort and know-how.
If part #'s are spooned out, then people will start blaming the spoon-feeders for misinformation, blah blah blah.
Old 09-29-2015, 05:21 PM   #71
evil girl
Member#: 61196
2017 fozzie xt
bluetastic
for those in the salt belt:
don't forget to check control arms, front sub-frame and rear crossmember for rust.
Calipers and brake lines, hard lines especially.
my 02 is at 165k and the salt is brutal here and hasn't been kind, replacing all of the above items were done with the help of a bottle of Jack, map gas and a voodoo witch.
evil girl is offline   Reply With Quote
Old 09-29-2015, 05:45 PM   #72
coalslaw
Member#: 324808
2006 IWL Stg2
ya rear lateral arms getting seized can be a pretty common issue too @ 125k miles
coalslaw is offline   Reply With Quote
Old 09-29-2015, 08:23 PM   #73
methaddict
Member#: 159738
2004 WRB STi 620awhp
OFCD V3, FR TS, BW8374EFR
Another area easily looked over is the engine harness. Heat reeks havoc on wire split loom and electrical tape. When I had mine off I replaced all the old tape, broken split loom, covered exposed wire, retaped soldered and heat shrink and reinforced with new zip ties.
methaddict is offline   Reply With Quote
Old 09-30-2015, 12:45 AM   #74
Scubydoo17
Member#: 422590
2008 2.5i
grey
Wow crazy good write up needs a stickie
Scubydoo17 is offline   Reply With Quote
Old 09-30-2015, 11:40 AM   #75
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Great writeup, Ron.
You should add http://parts.subaru.com/ to the OP. This site contains all the exploded drawings for Subaru vehicles and their respective part numbers. This site is actually better than most of the "catalogs" available on vendor sites.
bicycle_wreck is offline   Reply With Quote
