Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 03-26-2017, 12:52 PM   #1
adam sti
Member#: 457414
2004 STi
Default Better method of checking oil?
There has to be another way to check the oil level rather than the dipstick. I believe that it is inaccurate. I park my car in my garage every night and check the oil every morning and you would think it would be the same, but no. Sometimes it reads over what it did the day before and some days it reads under. Recently after driving for a hour or two i came home and checked it and it was a little under the F (this was while the motor was warm). After letting it sit overnight I checked it again in the morning and it was a little over the F and under the notch. what???
I recently did an oil change on an audi and there was no dipstick but there was an electronic oil gauge that reads when the car is warm and turned off. would it be possible to install something like that ?
adam sti is offline   Reply With Quote
Old 03-26-2017, 12:59 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
If the engine was recently running, let it sit OFF for 5 or more minutes to allow all the oil to drain back into the pan.
Yes, warm oil will show a bit higher than really cold oil, but the draining is more important.
Using an electronic gauge is for 2 basic reasons.
-people don't check oil, so the OEM designs for careless people.
-some engines have so many covers under the hood, it's a PITA to get to the dipstick.
So no, there is really no better way. Try to check in a common parking spot that is close to level and after the engine has been off a bit.
Old 03-26-2017, 07:47 PM   #3
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
you can remove the o-ring on the dip stick. it gets rid of the suction of a tight seal. then slip it back on after checking. there is a company selling dipsticks with a pressure release just like removing the o-ring for like 70 bucks.
424wrx is offline   Reply With Quote
Old 03-26-2017, 10:52 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
His issue is not pulling the dipstick, it's the inconsistent readings.
Old 03-26-2017, 11:20 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2013 Audi
A6 3.0T
The method used in motors for over 80 years isn't good enough?
Old 03-26-2017, 11:33 PM   #6
Blktrax
Member#: 220971
2002 WRX 224K Mi.
Between the low and the full mark when oil is cold, is the Operating Zone. OCD much, oh wait I do that too. Dukes
Blktrax is offline   Reply With Quote
Old 03-26-2017, 11:33 PM   #7
motorbykemike
Member#: 273868
removing the oil fill cap is free
motorbykemike is offline   Reply With Quote
Old 03-27-2017, 05:40 PM   #8
ALOKIN
Member#: 348177
2002 Bugeye
Haltech GTX3584RS
In consistent readings are caused by the oring.
www.superstik.com
ALOKIN is offline   Reply With Quote
Old 03-27-2017, 05:50 PM   #9
mishapopa
Member#: 393629
i've had no issues with these:
1. stop checking every day
2. take 3 readings
3. check when engine is cold and been sitting for at least an hour
and yes the ej25 is kind of a pain to check the oil on
mishapopa is offline   Reply With Quote
Old 03-27-2017, 10:52 PM   #10
carlos.danger
Member#: 363268
2015 WRX STi
Over/under a few mm's wont hurt a thing. Edging toward the low is what youre looking for mostly.
Your engine has some range when it comes to the amount of oil in the system. Youre looking for massive fluctuations, not inconsequential differences.
I check it every two fill ups. And i try to pay attention when backing out of parking spaces to make sure im not dumping oil somewhere.
You can sweat the small stuff, i get it, but this really isnt something to get your panties in a bunch over.
carlos.danger is offline   Reply With Quote
Old 03-27-2017, 11:40 PM   #11
grovlet
Member#: 372889
2005 Legacy GT
FYI - I also have an Audi - and guess what the most recommended 1st purchase is? YUP - Oil Dipstick!!
Why - because the Electronic tracking is somewhat unreliable and makes checking the oil level complicated....
So go with the dipstick - Oil should be checked about 5 minutes or so after driving - flat level ground - and I typically check it 3x over to confirm findings.
grovlet is offline   Reply With Quote
Old 03-28-2017, 12:56 AM   #12
jersdunz
Member#: 426081
Just check your oil in the same spot wether it be at your favorite gas pump in your driveway etc.. Get scientific same spot every time, all ya need
jersdunz is offline   Reply With Quote
Old 03-28-2017, 01:11 AM   #13
OrphenCB
Member#: 407127
2013 WRX Limited
WR Blue
Isn't it a time honored Subaru tradition to be checking your oil at every fill up? As others have said, if it's at or below the low level, add oil. Otherwise, you're good to go.
OrphenCB is offline   Reply With Quote
Old 03-28-2017, 09:59 PM   #14
adam sti
Member#: 457414
2004 STi
thank you everyone for the information
Old 03-28-2017, 10:45 PM   #15
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Buy a new BMW.
No dipstick and you rely on a computer to estimate how much oil remains in the oil-pan.
Then at the OCI, you drain the oil and fill it back up per the manual and that's it.
Old 03-29-2017, 09:59 AM   #16
adam sti
Member#: 457414
2004 STi
Originally Posted by Big-E View Post
Buy a new BMW.
Haha no.
My issue was checking the oil so frequently
Old 03-29-2017, 10:53 AM   #17
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
gsrcrxsi is offline   Reply With Quote
Old 04-02-2017, 08:50 PM   #18
ALOKIN
Member#: 348177
2002 Bugeye
Haltech GTX3584RS
Doesnt work. The oil fill tube sits ontop of the rocker cover to the driver side head. The suction created by the oring is strongest at the tube inlet near the oil fill line in the pan.
Easy to experiment yourself. Open the fill tube, check oil. Then remove oring and check oil, it will change.
Old 04-03-2017, 09:48 PM   #19
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
exactly. i wasnt gonna argue anymore over this. the oil cap has nothing to do with the dipstick tube pressure.
Old 04-03-2017, 10:31 PM   #20
No Go
Member#: 38928
2004 153 MPH STI
I can't believe there is a thread on this...
No Go is offline   Reply With Quote
Old 04-07-2017, 01:54 AM   #21
notacarguy
Member#: 462586
2006 wrx
wrb
Be cool if it was like a motorcycle with the little window showing you where your oil is at
notacarguy is offline   Reply With Quote
Old 04-07-2017, 09:59 AM   #22
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
So you crawl under the car to see the window? Or lay in the snow, on wet ground?
Old 04-07-2017, 10:01 AM   #23
the_saintusa
Member#: 171486
2004 WRX STI
That sounds infinitely easier than using a dipstick.
the_saintusa is offline   Reply With Quote
Old 11-10-2017, 03:54 AM   #24
subarumod
Member#: 468745
06 wrx
black as your girls soul.
ive been kinda mowing over this issue.. As my oil disapears on a daily, Ive become best friends with my dipstick.. and Ive realized I dont know a whole lot about it. I mean I get it but I feel like I should know more...
I actually read the cars manual and it says nothing about reading your oil while its cold.. It says you can add oil while its cold but to keep it under the F line...
Which leads me to my question of when you get a cold reading, besides it alerting that you have no oil, what eaxctly is that reading telling you?
I get to operating temps, stop and wait some minutes and check and ill be close to F, let it sit hours and it drops back down to halfish where it starts at cold
subarumod is offline   Reply With Quote
Old 11-10-2017, 09:21 AM   #25
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Most fluids expand when heated, so when it's 20*F out and the car has been sitting for hours, the oil will read lower than a few minutes after shutting the engine off.
Think about the oil temp, then compare to where it is between the dots. You don't want to be low when the oil is warm/hot, you don't likely want it near the top when really cold.
The upper notch is the max hot spot.
