Welcome to the North American Subaru Impreza Owners Club Tuesday November 12, 2019
Old 06-24-2017, 05:50 PM   #1
PanteraSti
Member#: 451970
2015 Sti
Default Car stuck on code P2109, Throttle and pedal have no communication.
So here's an update of my situation.
I really really really need someone's help.
I have a 2015 Sti:
I bought it on june 2016 imported from the US like this:
FluidAmpr crank pulley
5 inches Tmic
Cobb downpipe
Cobb intake
Invidia q300
Turbosmart blow off.
It showed like it had an Accesport cause it had the AP mount but no AP on it.
I Haven't done any engine mods whatsoever.
Only exterior cosmetic mods.
So here's forward to now....
On June 6 it went on limp mode, but not the actual limp mode, it just lost all communication in the "throttle with pedal" department, then came two times back randomly and then it stayed with no communication at all.
So the car turns on, but doesn't open the throttle, does not pass 5 mph and doesn't pass the 1,600 rev mark. On the center console shows the percentage of acceleration when you press the pedal but no action on the throttle.
Also, when it started to fail it showed two codes, first it was "P2101", then shut off that code and showed "P2109"and it has been showing that only code ever since it first started with the problem.
It also turned the check engine light, traction control light, abs light, "S" mode blinking on dash panel.
Since June 6 they've checked all plugs and harness, all of them showed signal of communicating with each other.
Exchange throttle with another and it did the same, same with the pedal.
BUT! only the two wires that tell the throttle to open and close weren't communicating, ones that go to the ECU.
But they measured the signals from wires to Ecu and wires are ok.
So next was to use a Cobb Accesport I bought 3 months ago that I never got to use for downloading data to the car, only to use it as a read out display to keep on check the temperature, knock, etc etc.
To reflash the ecu thinking the possibility that the old data that was before may be corrupted.
But guess what?
Accesport couldn't communicate and download any data whatsoever, just read.
So I thought "I got punked and they sold me a married AP."
But then we tried an unmarried AP and it happened the same thing.
So now the last and final effort is to change the cars Ecu with another same model and year STI. Will it work? We don't know.
It's been 18 days of extensive and exhausting work trying to find the problem and I guess we're close, but apart from all of this "hitting dead ends" I don't know what else to think off.
I really need your help.
I would appreciate all internet trolls to stay out of this one.
As a favor.
For real.
PanteraSti is offline   Reply With Quote
Old 06-24-2017, 06:32 PM   #2
Blktrax
Member#: 220971
2002 WRX 224K Mi.
Blktrax is offline   Reply With Quote
Old 06-24-2017, 11:24 PM   #3
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Did you ever physically look and see if thr butterfly moves or try to swap the throttle body? My car had the same issue and once I plugged in a spare TB everything was fine.
Scuby04STi is offline   Reply With Quote
Old 06-24-2017, 11:49 PM   #4
PanteraSti
Member#: 451970
2015 Sti
Originally Posted by Blktrax View Post
You can try a NEW ECM and have it programmed to the Car.
You CANNOT swap an ECM from another running vehicle.
The ECM has to be regisited with the VIN, along with "C.A.N bus" handshakes to the BIU (Body Integrated Unit) and Gauge Cluster. That way Immoblizer will allow the car to start.
If you simply swap ECM's you run the risk of Bricking another ECM, as it will think it is a Theft attempt.
If the Wires check good, and the pedal didn't fix it, you likely have a bad ECM.
We changed the ecm and it started fine, but it was throwing the same code.
Old 06-24-2017, 11:51 PM   #5
PanteraSti
Member#: 451970
2015 Sti
We did check the throttle body and changed for other. But nothing. The same.
Old 10-14-2019, 08:58 PM   #6
bigjohnsieper
Member#: 492638
2012 WRX Hatch
I know this is old but did you ever figure it out? My 2019 is doing the same thing..
bigjohnsieper is offline   Reply With Quote
Old 10-15-2019, 06:48 AM   #7
hoang5659
Member#: 416298
2015 STI Limited
Galaxy/Lapis Blue
if you have a 2019 i would take it into the dealer to diagnose... if anything is wrong, they can fix it under warranty.
hoang5659 is offline   Reply With Quote
Old 10-15-2019, 11:00 AM   #8
bigjohnsieper
Member#: 492638
2012 WRX Hatch
Yeah it's at the dealer, I actually work here. The techs have done everything the original poster did, still no luck.
