Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 10-15-2019, 09:36 PM   #1
20scoob04
Member#: 370742
Default 2.5GT heads on EJ257 compatibly
I have a 1998 legacy 2.5 GT, I just started to get rod knock, I have an ej257 block with aftermarket pistons already installed.
Will these heads work on this block?
Sorry if this has been answered, I work on the Great Lakes on a tugboat, donít have access to a computer to do in-depth searching on the forums.
Cell phone only goes so far.
Any information is greatly appreciated.
20scoob04 is offline   Reply With Quote
Old 10-16-2019, 03:24 AM   #2
SlammedSix
Member#: 419926
Yes
2 "Issues"
1- Compression will be low for NA, probably around 8.5:1
2- There is a crankcase vent off the top of the block and your coolant crossover pipe will hit it. You can modify it but its not ideal.
SlammedSix is offline   Reply With Quote
Old 10-16-2019, 03:49 AM   #3
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
Static compression for NA should be closer to 10:1...at least what I remember from my 2011 EJ253.
EJ257 is 8.2 or 8.3. EJ255 is 8.5, iirc.
viper_crazy is offline   Reply With Quote
Old 10-16-2019, 08:53 AM   #4
20scoob04
Member#: 370742
Awesome, well I have intention of doing forced injection on it.
I just already had the block on the side to eventually put into it any way.
And any parts I have donít have to purchase twice is perfect
I imagine Iíll have to basically piece this motor back together?
Sti/wrx intake manifold
Fuel injector assembly
Header/UP/Exhaust setup
Edit:
On the fozzy forum some people suggest sticking with the plastic intake manifold, better with heat dissipation and such being the reasoning opposed to the wrinkle red, could I use that intake manifold thatís already on there? Wrapped in heat tape.
