Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 10-17-2019, 10:41 PM   #1
U.P. Forester XT
Member#: 507217
Default Valve lash just got more expensive
I went down to the Subaru dealership today and bought the last couple of buckets for my engine, I felt pretty irritated about having to spend 24.00 ea for mine and then the parts guy made me feel alot better about my situation he showed me the new valve lash caps they are literally the size of my pinky finger nail and they are 40.00 each
U.P. Forester XT is offline   Reply With Quote
Old 10-17-2019, 10:42 PM   #2
U.P. Forester XT
Member#: 507217
I was going to add a picture but it's not letting me
Old 10-18-2019, 08:01 AM   #3
bp05obxt
Member#: 459799
Are you bench setting lash or doing it on an engine that the heads have already been put on?
bp05obxt is offline   Reply With Quote
Old 10-19-2019, 01:15 PM   #4
U.P. Forester XT
Member#: 507217
I put the heads on and torqued everything down, I was going to just do it on the bench but I heard there was a difference, I had originally started doing it on the bench then I went and installed them on the engine and rechecked the valves I already measured and it turns out there was about .001 difference between in stalled and uninstalled heads
Old 10-19-2019, 04:35 PM   #5
awfulwaffle
Member#: 409332
2013 WRX
PBP
Timing belt install will shift your clearances as well. At least, it did mine.
Also, FYI:
https://legacygt.com/forums/showthre....html?t=279743
Maybe I should make a thread for this here on NASIOC too.
awfulwaffle is offline   Reply With Quote
Old 10-20-2019, 10:05 PM   #6
U.P. Forester XT
Member#: 507217
Thanks for that link that is definitely good to have, do you think that you may of had excessive camshaft journal clearance to cause valve lash to change? I mean that would really ****ing suck to have to install the timing belt to get the clearance right, it would be nice if someone else could give some insight on that.....
Old 10-20-2019, 11:05 PM   #7
awfulwaffle
Member#: 409332
2013 WRX
PBP
Well, at least for the LGT, the factory service manual states that clearances should be checked with the belt installed. I only thought to check after seeing another user on legacygt.com report a shift when they measured theirs out.
My approach was to set my bench clearances 2-3 sizes looser than nominal, to end up with nominal clearances when torqued and belt installed. Worked pretty well, except for one intake valve which ended up one size under nominal.
I also can't stress enough the need to have a micrometer on hand to measure out actual bucket thicknesses. I haven't encountered a single bucket from a motor with more than 50k on it that measured the same as the size it was marked. Worst one I saw was 6 sizes under the marked value.
Old 10-21-2019, 07:52 PM   #8
U.P. Forester XT
Member#: 507217
Thanks for your insight
