Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 10-19-2019, 11:18 PM   #1
apollo23
Member#: 499429
2007 WRX
UGM (45a)
Default 2007 WRX Secondary Air Injection system stuck CLOSED. Pull fuses and delete codes?
Hey all, I am the owner of a 2007 WRX with "Stage 3-ish" mods (vf39, STI top mount, catless turboback) and my secondary air injection system has been giving me a really rough time. I'm throwing a few codes, specifically ones for the valves being stuck closed (bank 1 and 2), the air pump stuck on, air pump performance, and one other thing. Seeing as the valves are stuck closed, would it be okay to just pull the fuses and related relays, and just delete the codes until I can properly block them off? I've heard people have done that before without issues for years, (of course I don't plan to wait that long to block it off, however.)
Anyway let me know if you guys think it'd be okay to do that.
apollo23 is offline   Reply With Quote
Old 10-20-2019, 01:38 PM   #2
A.S.N.F.
Member#: 498940
2010 WRX
Lightning Red
Short term maybe, I have been told this can put it in limp in but I don't know what years will do this. But, time to do an air pump delete and then have a tuner like boosted performance turn it off while getting a good tune. Mechanical simplicity.
A.S.N.F. is offline   Reply With Quote
Old 10-20-2019, 04:00 PM   #3
Blktrax
Member#: 220971
2002 WRX 224K Mi.
Unless you have specifically turned off the codes in a tuning solution , every cold start will repost the codes.
Blktrax is offline   Reply With Quote
Old 10-20-2019, 11:01 PM   #4
apollo23
Member#: 499429
2007 WRX
UGM (45a)
I will have my tuner turn off all related codes for the time. My thoughts just are, we are having some troubles with my DAM numbers and a low boost, so I'm thinking the CEL's im throwing might be putting me in limp mode, so we are going to turn it all off so we can properly see if it's that or not.
