Welcome to the North American Subaru Impreza Owners Club Sunday November 17, 2019
View Poll Results: Do you want to see my car finished?
Yes. Don't give up now! 134 84.81%
Nah. It was doomed from the start. 5 3.16%
I really don't care either way. 4 2.53%
I'll give you $20 and some twizzlers for it. 15 9.49%
Voters: 158. You may not vote on this poll
Old 04-19-2005, 09:51 AM   #51
Slack
Member#: 17548
I'm pretty sure it runs sideways and they both end up dumping into one and then out the single outlet on the bottom.
Mick
Slack is offline   Reply With Quote
Old 04-21-2005, 08:29 PM   #52
Slack
Member#: 17548
Update:
Okay, I've now got the ECU and bulk wiring harness. I will be going to the dealership tomorrow to get final idea of what I'll need to start get the project started.
Mick
Old 04-22-2005, 12:18 PM   #53
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
[negitive again sorry]
you realize you will have to have a subaru select tool to register a RFID key befor you can start it right?
[/negitive again sorry]
Old 04-22-2005, 03:43 PM   #54
steve_d
Member#: 315
yep.
sjd
steve_d is offline   Reply With Quote
Old 04-24-2005, 09:04 AM   #55
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Any updates?
west_minist is offline   Reply With Quote
Old 04-25-2005, 01:06 AM   #56
97subGT
Member#: 41323
Sedona
Look folks, I am really tired of the negative comments. I don't really need to hear any more "it won't work" comments. If you don't have any technical info or help, then just don't bother posting. I'm trying something new and I will do whatever I can to make it work. Period.
Doesn't it just p*ss you off so bad when everybody starts to tell that there is no way in hell this will work? I mean I would understand if this was just an idea and you haven't spent money on it yet but you got what at least a couple grand in it. And now all of a sudden people are telling you these holes in your idea like this swap has been unsuccessfully done before. Just wait you'll see before you know it u will be coming home from your emmissions test ready to rub it in every persons face that not only doubted you would get the car running but also pass emmissions.
Good luck with the swap can't wait to see that beast road worthy
P.S. oh yeah by the way getting your local sub dealship to program a key won't be hard. if they tell you no at first ask to talk to the subaru tech and tell him that you will pay an extra 1/2 hour (40 bucks est.) for labor charges to do it.
97subGT is offline   Reply With Quote
Old 04-25-2005, 09:32 AM   #57
Slack
Member#: 17548
I'm not looking to rub anyone's nose in anything. I'll just be happy when it is completed and can help others to do the same swap with my experience and knowledge gained from this project.
Mick
Old 04-26-2005, 12:25 AM   #58
Slack
Member#: 17548
Okay, we went by the dealership today and found out some additional parts that will be needed:
Radiator (from previous H6)
Radiator overflow tank
Even though the bolts for the fans are different, we might be making a custom bracket to fit my fans to the H6 radiator.
Powersteering pump & reservoir (the reservoir is connected remotely to pump)
Alternator...we might be able to use the one I have, but the pulley will be needed b/c it is 6 tooth and mine is 5.
A/C pump will most likely have to be from the new H6, because the brackets on mine are completely different. Also, newer A/C pumps are made by Denso as opposed to the older Calsonic ones.
Idler pulleys that go with the accessories. (all one belt *see pic below*)
The new H6 uses a returnless fuel rail design, so I will need the Fuel Pressure Regulator setup from the newer car. We might have to rig up a place to put the fuel filter, because the new H6's filter is in the tank.
We're also looking into what pedal assembly we'll have to use. From the searching I've done, there is a difference between the Legacy, Forester, and STi TBW pedels. I don't know if the plugs are different (if so, we'll use the Legacy pedal) or if the fitment is different (FXT or STi would be more likely to fit).
That's all I've got for now. I will post updates as they come.
Mick
Old 04-27-2005, 08:12 PM   #59
Arkash
Member#: 85519
Default Damn, someone beat me to it..... :-/
Nice work so far. I'm a bit dissappointed, since I wanted to be the "first" to do this kind of swap on a daily-driver (which is why I'm not counting the Lina Racing guys). T
hen again, essentially everything has been done under the sun, so I'm just happy to be seeing it done, and hopefully what you've learned will help me when my turn comes to do my thing. :-)
By the way, I'm planning to do this to my (GC8) '99 Impreza 2.5 RS
[C]
Arkash is offline   Reply With Quote
Old 04-27-2005, 08:20 PM   #60
Slack
Member#: 17548
I'm glad others want to do this swap. Like I mentioned earlier, we'll be documenting things very closely so that we can assist others who would like to follow in my footsteps. Having smooth, reliable power without a turbo is my goal and this engine will be perfect.
Mick
Old 04-28-2005, 03:13 AM   #61
Arkash
Member#: 85519
Mick
That is pretty much my goal. I'm currently working on teaching myself ECU/EFI theory, so i can create and modify my own custom fuel maps for whatever engine. It's a *lot* of work, but the experience and knowledge will be worth it in the long run.
If you would, keep me updated on your progress, as I'm very interested to see how it all goes.
[C]
Old 04-28-2005, 10:24 PM   #62
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You turkey Mick! Good luck on the swap. Harness shmarness! Make your own.
You need anything, let me know.
Tim Sanderson is offline   Reply With Quote
Old 04-28-2005, 10:32 PM   #63
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Did you try swapping alt. pulleys?
Old 04-29-2005, 12:03 AM   #64
mykrrrr
Member#: 733
'18 WRX
Silvery bluishy
Good luck Mick.
-mykr.
mykrrrr is offline   Reply With Quote
Old 04-29-2005, 12:25 AM   #65
Slack
Member#: 17548
I've been looking at pictures of the older H6 vs. the newer one and the accessories (A/C, P/S, ALT) are setup very similar, if not exactly the same. If that is so, it would be likely that I could get those parts from junkyards and have them bolt up just fine. I might run by the dealership (again) tomorrow and check it out for myself. If the older accessories will work, it will save a lot of money and/or effort.
Mick
Old 04-29-2005, 08:04 PM   #66
Slack
Member#: 17548
Well, I got all these parts ordered today:
From 05 H6:
Denso Fuel Pressure Regulator
MAF sensor
Idler pulleys
and V-belt
From previous H6 (02):
Alternator
Power Steering pump & reservoir
A/C compressor
This project should be a "Go" very soon. Stay tuned to this thread for more updates.
Mick
mykr- Thanks, dude. I'm finally starting to get excited.
Old 04-29-2005, 08:57 PM   #67
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Me too
Old 05-02-2005, 04:19 PM   #68
raydadick
Guest
Member#:
wow!!
Old 05-03-2005, 08:00 PM   #69
Slack
Member#: 17548
Okay, I got all the parts listed above. I am ordering an XT/STi throttle-by-wire pedal tomorrow and then we should be good to go. I'm hoping to start the project by Friday.
Mick
Old 05-04-2005, 01:49 AM   #70
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Sounds like a big list of parts you now have there...
kgb is offline   Reply With Quote
Old 05-04-2005, 08:20 AM   #71
Slack
Member#: 17548
Yes. My apartment is getting harder to navigate due to the ever increasing number of parts.
Mick
Old 05-04-2005, 12:21 PM   #72
Slack
Member#: 17548
Default Parts List (so far)
JDM Legacy 3.0R:
EZ30-R longblock + engine mounts
05 Outback H6:
ECU
Wiring harness
Idler pulleys (for V-belt)
V-belt
MAF sensor
01~04 Outback H6:
Alternator
A/C compressor
Radiator
EJ22/25:
Exedy street clutch kit
Still looking for:
STi or Forester XT throttle-by-wire gas pedal (will have by Friday)
Mick
Old 05-04-2005, 03:23 PM   #73
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Reach the 10K mark on part cost yet? Or just over 5K for all that?
Old 05-04-2005, 03:52 PM   #74
Slack
Member#: 17548
Actually, I'm right under 4k. I still have to purchase exhaust materials(pipes, flanges, resonators, high-flow cat, muffler, etc), intake materials (tubing, filter, maf adapter), but I think I should still be able to keep it under 5k total. It hasn't been easy keeping the cost down, but thanks to discounts and thrifty shopping I am not completely broke.
Mick
Old 05-04-2005, 04:12 PM   #75
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
how much is the MAF for that engine....I know those are generally $250-350
EJ22 to EJ25 Swap Questions. TooManySubies Subaru Conversions 9 02-03-2007 03:50 PM
It has begun: Rimmer SC in '95l Matt Monson Normally Aspirated with bolt-on Forced Induction Powertrain 48 08-23-2006 04:37 PM
OK, where's the GC4 EJ22 to EZ30R thread? Patrick Olsen Subaru Conversions 6 07-14-2006 11:32 AM
Ej22 to Ej20g swap, difficult? d4d4d4d4 Subaru Conversions 3 03-28-2004 02:59 PM
