Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 10-08-2019, 07:48 PM   #2801
Damonr
Member#: 334319
04 Subaru STU
Default Reverse Intake
Great tread indeed. Anyone comment on the "tuning" aspect of this mod? How does it effect "wall wetting"? Thanks!
Damonr is offline   Reply With Quote
Old 10-14-2019, 03:46 AM   #2802
binny
Member#: 198108
MY98 WRX
Originally Posted by Scargod View Post
Nice! Clean. I see only one pic.
Did you use my idler and small alternator idea?
Funny how the radiator tank can go just about anywhere.
What small alternator did you use? I'm looking for a small alternator at the moment I was thinking of a Suzuki K class (660 cc engine) but was wondering what is the smallest size around
binny is offline   Reply With Quote
Old 10-14-2019, 10:16 AM   #2803
Scargod
Member#: 260314
2007 STI
silver gray metallic
Default Small alternator solution
Called a "15576", it is a common 50 amp alternator. I bought a connector plug for it and wired it in. I modified the alternator stand and ordered tensioner parts from McMaster Carr. The PS tensioner is a modified idler from the timing belt circuit.
My application is pure track car. I do not have headlights, but this does fine when paired with an 11 pound, 18 Ah, 310 CCA, sealed battery. I run my radiator fans on a dedicated switch for manual operation. This has worked fine for years. May not be adequate for all cars.
I can upload more detailed photos of the mods and process if you PM me here or glyn churchman on FB.
Scargod is offline   Reply With Quote
Old 10-14-2019, 04:33 PM   #2804
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
For people having issues clearing their alternator has anyone considered modifying the crank pully to have a stator/rectifier as to do away with the alternator all together? My dad did it on his old hot rods and I was debating doing it sense that is the only pulley left on my car just cuz.
Scuby04STi is offline   Reply With Quote
Old 10-14-2019, 09:25 PM   #2805
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Old hot rods also didn't have all the modern onboard electronics to run. I guess it depends on what your base current draw is ten figure out if your battery would ever charge with just an magneto
Old 10-17-2019, 07:59 AM   #2806
Scargod
Member#: 260314
2007 STI
For people having issues clearing their alternator has anyone considered modifying the crank pulley to have a stator/rectifier as to do away with the alternator all together? My dad did it on his old hot rods and I was debating doing it sense that is the only pulley left on my car just cuz.
I think it would be impractical for most cars. It's not that hard to relocate an alternator. Certainly with my reversed NA intake it wasn't. It was mostly just modifying the alternator/AC bracket. The real issue is retaining an AC compressor.
Old 10-17-2019, 09:39 AM   #2807
vicious_fishes
Member#: 158864
2003 SOHC destroker
just out of curiosity does anyone have a before & after a manifold flip? I mean simple intuition tells you it'll improve things, but i'm curious to see back to back tests proving by how much.
vicious_fishes is offline   Reply With Quote
Old 10-22-2019, 05:05 PM   #2808
Scargod
Member#: 260314
2007 STI
Probably won't happen. How many do just that and nothing else? I did a ton of things differently when I went from built block and stock intake.
Might try searching it.
I understand that the NA manifold has the injectors pointed at too much of an angle for a big power engine. Perhaps that implies that part of the problem lies in the spacers most people use. Spacers position the injectors abnormally high and they hit the spacer or the roof of the hear's passage, where the fuel gets washed down the wall and not drawn into the air flow as efficiently as it could be. Still, I manage 470 HP with 13mm spacers. My next engine, that I am building, with a NA intake will not have spacers.
As an aside, I have four NA's in my basement on top of the one that I've ready for my next big build.
Old 10-22-2019, 05:12 PM   #2809
PDXREALTOR
Member#: 468393
2017 STI
I decided to not use the 19mm spacers this time around due to injector height. Mine were from ks tech and are shaped nicely to accommodate the head port profile. But still that's a lot of height ,19mm, and while I didn't see anything in the logs I can't help but wonder what effect of any the added height has.
I am now using 8mm spacers and 3/8" manifold to tgv spacers.
PDXREALTOR is offline   Reply With Quote
Old 10-22-2019, 06:37 PM   #2810
Scargod
Member#: 260314
2007 STI
PDXREALTOR, And the AVCS are clearing the fuel rails? Did you clock them as I suggested?
Old 10-22-2019, 06:47 PM   #2811
PDXREALTOR
Member#: 468393
2017 STI
What avcs? The lines or?
The only clearance issues I had was the back of the pass. Side fuel rail barely kissed my turbo inlet coupler.
Old 10-22-2019, 09:22 PM   #2812
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Which NA manifold are you referring to, obviously not the one the White Bullet used to run a 7, right? I'm not running spacers, not need for them with no avcs, of course my manifold wont' be forward facing either.
2slofouru is offline   Reply With Quote
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 02:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 06:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 03:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 09:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 11:58 AM
