Welcome to the North American Subaru Impreza Owners Club Friday November 22, 2019
Old 10-15-2014, 09:27 PM   #251
mofoSTI
Member#: 236252
08 STi
P&L advertises their heads as the best flowing of all aftermarket heads. 3 grand with core exchange ain't bad. They will be on my next build. I'm willing to bet they don't flow more than Cosworth heads. What do you think they do to make their heads flow better?
mofoSTI is offline   Reply With Quote
Old 10-20-2014, 11:29 AM   #252
charliew
Member#: 125304
Default flowing heads
I would read up on flowbenches so you are aware of the ways porters rate their heads on airflow. Flowbenches are like gun barrels they all are a little different. The only way to know how much improvement a specific port is improved is to flow it on the same bench before and after the porting on the same day. Check how much is lost on na flow at low lift and how much is gained at high lift. Low lift on na is whats important before boost comes up for street use. Boost really just pushes through a bigger port but that is still important as pushing through a smaller port makes more heat. Only flowing the two competing ports on the same bench will show whats really what. All intake ports need to be as close to each other as possible, that's the same with exhaust ports. The exhaust are the hardest to equalize on the suby. When ports are of different flows the af ratio will vary and it will be harder to tune each cylinder as usually only the exhaust temp on each port is available to monitor.
charliew is offline   Reply With Quote
Old 10-24-2014, 01:09 AM   #253
rek888v2
Member#: 71287
S202 #387, Type RA
#169 and an 04 STi
Originally Posted by FuJi K View Post
USDM WRX D25 vs JDM STI Ver5
The USDM is the smaller wound and taller valve spring.
Do you know what the open and seat pressure difference is?
rek888v2 is offline   Reply With Quote
Old 10-24-2014, 01:13 AM   #254
rek888v2
Member#: 71287
S202 #387, Type RA
#169 and an 04 STi
If you could find out the CSA's you might be able to calculate what CFM the heads flow after porting and also are we talking hand porting or CNC? Also, air isn't pushed, the turbo compresses the molecules making the air more dense. A ported head allows more air to be able to be sucked into the cylinder while the valves are open.
Old 10-27-2014, 10:33 AM   #255
charliew
Member#: 125304
funny you start out showing what you have read but then mention sucked. Air is moved by flowing from a higher pressure area to a lower pressure area not from being sucked from what I have read. Also cnc is not a science it is just doing a machining operation from a program and yes it does all the same heads pretty much exactly the same but that only means they are the same, and maybe not ported the best. Cnc does not guarantee the ports will be equal in flow. And I know from the little porting my son and I have done and flow tested that the low rpm and low lift flowing is better on a smaller port.
Old 10-30-2015, 11:11 PM   #256
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I came across these unexpectedly.
Mission to replicate: success.
FuJi K is offline   Reply With Quote
Old 11-01-2015, 10:19 AM   #257
wrxhard
Member#: 108091
I have no idea what the significance is of the upper picture. Please excuse my ignorance and the elaborate Fuji
wrxhard is offline   Reply With Quote
Old 11-01-2015, 02:23 PM   #258
jville1982
Member#: 300881
Looks like he deshrouded the bowl a bit to match?
jville1982 is offline   Reply With Quote
Old 12-15-2015, 10:59 PM   #259
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
They aren't the head casting. Top picture is that one particular head with that port style. The bottom is a small port slightly enlarged to match. You can see the left port of the bottom head that I didn't work on yet.
Old 03-13-2018, 10:56 AM   #260
mekilljoydammit
Member#: 258151
Dragging this back up from the dead a little - but got what is allegedly a JDM non-AVCS EJ205 and the ports aren't like what I've seen before.
USDM EJ205 with 3/4" socket
JDM EJ205(?) with same socket
No socket. Port divider definitely doesn't extent up the port like the USDM 205s that I've seen, obviously ports are bigger too. No AVCS, came with coil-on-plug. Anyone seen one of these before?
mekilljoydammit is offline   Reply With Quote
Old 03-14-2018, 11:02 PM   #261
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
What is the casting code? Usually a single letter (S, W, B, D, Z, etc) and two digits for displacement (20 = 2.0L, 25 = 2.5L, etc).
Also emailed you about the cam profiles.
Old 03-15-2018, 02:58 PM   #262
mekilljoydammit
Member#: 258151
Heh, we keep pinging each other in different threads. Emailed you back about a couple things.
I'll look more closely but the "LH B" was the only one I saw quickly.
Old 03-15-2018, 08:24 PM   #263
mekilljoydammit
Member#: 258151
Yeah, literally just "LH B" and "RH B".
Old 03-25-2018, 08:15 PM   #264
mekilljoydammit
Member#: 258151
More weirdness - shimmed buckets. I wonder what the heck this came out of.
Old 09-07-2018, 07:20 PM   #265
mekilljoydammit
Member#: 258151
Thought I had the other day - I wonder how much meat there is around the ports on an S20 head.
WIP
Old 08-30-2019, 12:07 PM   #266
Shylight
Member#: 209812
2003 WRX
Platinum Silver Metalic
Can somebody tell me if these are so called big port JDM heads?
Taken out of GC8 not sure which year EJ207 non-AVCS engine.
Shylight is offline   Reply With Quote
Old 08-30-2019, 01:10 PM   #267
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Yes. Difference is no AVCS.
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 01:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 07:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 10:47 PM
throttle body & head porting? JST Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-23-2002 09:24 AM
