Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 06-08-2018, 08:58 AM   #1
silverscooby
Member#: 15060
2015 WRX
MAPerformance Stage1+ E30
Default 2015 WRX 6MT - Locked out of 2,4,6
This happened yesterday on the way home from work. Was cruising on the highway and needed to downshift due to heavy traffic and found out I could not shift into 2nd or 4th nor could I shift back to 6th.
1,3,5th all worked fine. No grinding noises or anything odd other than simply not being able to get the car in 2,4,6.
When I came home, I let the car sit for 10 mins then tried it again and everything is back to normal.
Everything still seems fine now. The car is stock aside from a E-30 MAPerformaqnce tune (no shifter modifications, stock clutch, etc.). 56k miles.
Anyone else have this issue? I'm thinking maybe a shifter linkage or bracket may be loose and temporarily misaligned causing the lockout?
silverscooby is offline   Reply With Quote
Old 06-08-2018, 02:09 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Cool
OK, so 2015 WRX 6MT, stock.
How many miles? (Never mind, reread, 56K miles......).
Crap that fell into the shift boot?
Accident?
Any other work done recently?
Stock shifter (yes, you said stock, but asking).
Edit, OK, I have no clue, but your answers may help others......
Charlie-III is online now   Reply With Quote
Old 06-08-2018, 05:40 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Check the clip on the side of the trans that holds the cable.
Turn in Concepts is online now   Reply With Quote
Old 06-09-2018, 09:41 AM   #4
silverscooby
Member#: 15060
2015 WRX
Thanks, will do. I'll post here once I check it.
Charlie, no other work done recently.
Old 06-13-2018, 12:26 PM   #5
silverscooby
Member#: 15060
2015 WRX
The clip seemed normal, nothing looked out of place. The car has not done this since. So weird....
Old 06-13-2018, 06:41 PM   #6
killadawg
Member#: 424203
2016 WRX stage 3
STI Drivetrain swap GM
It's one of the cables on the shifter! Had this off and on, it can slip out.. I used a tie down to keep it snug, pain to do but worked for the month I needed before my Sti swap.. so no more cables on mine, yet this did happen to me in the past..
killadawg is offline   Reply With Quote
Old 06-15-2018, 10:19 AM   #7
silverscooby
Member#: 15060
2015 WRX
Hmmmm thanks for the heads up. I'll take a look tonight.
