Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 06-13-2018, 10:45 AM   #1
wangmauler
Member#: 454822
2013 WRX Hatch
Default 2013 wrx clutch pedal squeak
Hey all, this sound started happening randomly a few weeks ago or so, mainly after it had just rained. Now it's happening more and more often, took a vid. Seems to be just when I press down the clutch. I should add that the I can feel the squeaking in my foot as I press down too. Feels like whatever grease was there has been washed away basically. I checked the spot welds, which look to be fine, and the break pedal does not move at all when I press down the clutch too. Suggestions? Thanks all.
PS
In case you were wondering, size 14 wide feet, and yes I wear old man sandals. Comfy AF!
wangmauler is offline   Reply With Quote
Old 07-03-2018, 01:32 PM   #2
kingsalami
Member#: 206257
2009 WRX 5-door
Try spraying white lithium grease on the pivots & return spring.
kingsalami is offline   Reply With Quote
Old 07-03-2018, 01:34 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
That does not tend to migrate into the bad spot, it's more of a surface lube.
Silicone or 3in1 is better.
Charlie-III is online now   Reply With Quote
