Welcome to the North American Subaru Impreza Owners Club Friday April 23, 2021
Old 11-13-2013, 09:44 AM   #1
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Default 0.004" Block Flatness Warrants Decking?? - Blown HG aftermath
Factory Service Manual calls warping limit of 0.00098" (0.025 mm), using high precision Starrett straight edge I am at 0.004" (0.1016 mm), a difference of only 0.003" (0.0767 mm)
Does 0.003" warrant for a block deck machining? The heads have being decked and are within spec. I will be using Subaru OEM MLS replacement gaskets.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 11-13-2013, 10:29 AM   #2
bjohnson_55
Member#: 216580
If you want to do it right, yes. If not, no.
bjohnson_55 is offline   Reply With Quote
Old 11-13-2013, 11:19 AM   #3
Rally2
Member#: 132023
2005 STI
blue
One way to look at this is yeah it's only 0.003" out. Another perspective is it's 4x the allowable limit.
Rally2 is offline   Reply With Quote
Old 11-13-2013, 11:27 AM   #4
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Well I want to do it right, problem is I do not trust local machinist, I am afraid the 0.003" may turn into 0.03" or worst so just trying to ascertain if I wing it or take the chance with the local red neck "V8 iron block" familiar machine shop.
Old 11-13-2013, 11:58 AM   #5
cowboy_Rob
Member#: 194062
2003 Impreza WRX
4x the spec I would definitely want it fixed. If you have to just ship ship the block to a machine shop that knows subarus. Bare block halves really aren't very heavy I can't see shipping costing very much
cowboy_Rob is offline   Reply With Quote
Old 11-13-2013, 12:42 PM   #6
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Maximum out is .002 allowable by most standards with deck flatness.
fastblueufo is offline   Reply With Quote
Old 11-13-2013, 01:29 PM   #7
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^I don't follow you, I know what the spec is: Factory Service Manual calls warping limit of 0.00098"
Are you saying that a machine shop would only guarantee 0.002"?
Old 11-14-2013, 12:16 AM   #8
300zxturboftw
Member#: 325461
2003 WRX
WRB Rotated 35r
Take it to a machine shop with a cnc machine that can laser it out perfectly. Will cost the same as another machine shop who cuts it a different/less technological way and your deck will be almost perfectly flat/square.
300zxturboftw is offline   Reply With Quote
