Welcome to the North American Subaru Impreza Owners Club Thursday April 22, 2021
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 11-10-2020, 05:47 PM   #1
joea99
Member#: 483823
Default 06 MT drive shaft
Manual trans. Got a bad drive shaft. The U-joint at the first joint coming out of the trans is part way out. Scary.
It seems like these joints are NOT serviceable, is that correct? The whole shaft must be replaced?
Also, the "rear" drive shaft, is, in fact, "the drive shaft" (aka propeller?) and is a two piece unit with a center bearing?
Am I likely to do OK with one from a salvage yard or better to bite the bullet and get a Dorman or something with replaceable joints?
joea99 is offline   Reply With Quote
Old 12-01-2020, 11:08 PM   #2
Morgynn96
Member#: 520567
Default Forester
You could get a salvage one but I would recommend the new option depending on.your budget at the moment
Morgynn96 is offline   Reply With Quote
Old 12-01-2020, 11:36 PM   #3
joea99
Member#: 483823
I went with a new Dorman unit with 3 replaceable u-joints. Fit fine, works fine. So far. Amazon was cheaper than RockAuto, when shipping was included. Their parts check claimed it did not fit. Part numbers were correct.
The salvage yards around here all wanted top dollar for units over 200,000 miles, or rusty crusty's with bad center bearings and suspiciously "loose" grease. One private seller claiming a low mileage unit, never found the time to bother pulling it after jerking me around for days.
