01-17-2007, 03:08 PM | #1 |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
Question for Network people - Netmask for multiple adapters
I have a server with 2 adapters.
One adapter needs to access 192.168.0.0 to 192.168.3.255 The other one needs to access 192.168.20.* Which netmask value should I use for each adapter? I had 255.255.0.0 on adapter A. Adapter B couldnt see the network it needed to see. So I know I need to play with values so that both adapters see their networks without blocking each other. ib something ot something work blah
01-17-2007, 03:09 PM | #2 |
Member#: 15571
Vehicle:2006 06 Forester XT Silver |
taking a guess here: 255.255.0.0
01-17-2007, 03:10 PM | #3 |
Member#: 10251
SCIC
Vehicle:If I was a weapon, I'd still be the bomb. |
What are the netmasks of the other computers on the network that it needs to access?
01-17-2007, 03:11 PM | #4 |
Member#: 76596
NESIC
Vehicle:2012 |
Do you need both adapters to see every block? If so, then cwb's answer works. If not, then the second adapter needs 255.255.255.0, and the 1st needs 255.255.252.0
01-17-2007, 03:13 PM | #5 |
Member#: 15571
I sort of assumed that, and gave a one size fits all answer. It would likely work, but not be within policies in place or something.
01-17-2007, 03:15 PM | #6 |
Member#: 12391
NESIC
Vehicle:I did her 5 times then 7 times, then 5 more |
Are all the other computers using the same subnets?
01-17-2007, 03:15 PM | #7 |
Member#: 66341
South East
255.255.252.0 for the first and 24bit for the second
01-17-2007, 03:16 PM | #8 |
Member#: 76596
NESIC
Vehicle:2012 |
The only other issue is that the adapters would have trouble talking to 192.168.21.x to 192.168.254.x, if it's on a different router. The mask helps decides what's on your local subnet, and what gets sent to the gateway router.
01-17-2007, 03:19 PM | #9 |
Member#: 21356
NESIC
on adapter A, 192.168.0.252, 255.255.0.0 is the current. It needs to see up to .3.*
Computers on that side have 255.255.0.0 for netmask On adapter B, 192.168.20.17, the set mask is 255.255.255.0. It just needs to see .20.* 255.255.0.0 works on adapter B but then I cant see anything though adapter A. So looking around, a good mask for adapter A would be 255.255.252.0 and for B 255.255.224.0. But I can only see either outside of A or B. |
01-17-2007, 03:23 PM | #10 | |
Member#: 76596
NESIC
Vehicle:2012 |
01-17-2007, 03:30 PM | #11 |
Member#: 21356
NESIC
and the winning numbers for the lottery are:
255.255.254.0 for A 255.255.255.0 for B Congrats to the winner |
01-17-2007, 03:32 PM | #12 | |
Member#: 21356
NESIC
255.255.255.0 worked on it, i guess |
01-17-2007, 03:33 PM | #13 |
Member#: 76596
NESIC
Vehicle:2012 |
01-17-2007, 03:35 PM | #14 | |
Member#: 7121
A should be 255.255.252.0. 255.255.254.0 would give you 192.168.0.1-192.168.1.254 while 255.255.252.0 would give you 192.168.0.1-192.168.3.254. |
01-17-2007, 03:37 PM | #15 |
Member#: 66341
South East
01-17-2007, 03:38 PM | #16 |
Member#: 7121
This is impossible to do when A needs to see 192.168.0.1-192.168.3.255 since you'd need a subnet of 255.255.0.0 (or 255.255.128.0 would work too, but would still include your .0.1-.3.255 network) to see .20.* and .127.* on the other one. In that case, you should probably just create a virtual interface on that card and make its IP 192.168.127.(whatever) and make its subnet mask 255.255.255.0 as well. And then leave adapter A's subnet mask 255.255.252.0.
01-17-2007, 03:50 PM | #17 | |
Member#: 21356
NESIC
Based on the current settings suggested here, I cant see .3.* Its going though the adapter B, when it should go through A. Works for 2 servers but the 3rd one needs this .3.* network |
01-17-2007, 03:51 PM | #18 |
Member#: 66341
South East
01-17-2007, 03:55 PM | #19 |
Member#: 21356
NESIC
where is that FAIL pic when you need it
edit: here we go |
01-17-2007, 03:56 PM | #20 |
Member#: 7121
No, I know I'm right. Follow my directions exactly and it will work. It is the only way it will work.
01-17-2007, 03:57 PM | #21 |
Member#: 66341
South East
01-17-2007, 11:55 PM | #22 | |
Member#: 664
Vehicle:2020 Legacy Sliver |
192.168.20.0 should have a subnet mask of 255.255.255.0 and an address from this range. this would allow the server to see all addresses in this range. You didn't really go into if either network is connected to any thing else but to get beyond the 2 networks you defined in your question at least on of the adpters would also need to be configured with a subnet mask. So did you get a A+ on your homework? If this is for your work you really need a better understanding of how subnet masking works. |
01-18-2007, 09:46 AM | #23 | |
Member#: 7121
01-18-2007, 10:30 AM | #24 |
Member#: 7719
Vehicle:99 F-150 crew cab with illegals in bed |
01-18-2007, 10:51 AM | #25 |
Member#: 7121
I'm assuming he followed my advice and it worked since he never came back to the thread after that.
Q for Networking and power protection people | STiTuner | Off-Topic | 1 | 01-03-2007 11:00 AM |
Dish Network people | tommy2hotty | Off-Topic | 4 | 01-05-2006 03:28 PM |
Network people - how to get multiple machines to see a Firewire drive? | RaceCarRiot | Off-Topic | 2 | 11-03-2005 03:18 PM |
networking people help! | MrBlue | Off-Topic | 20 | 05-18-2005 10:43 PM |
Sys Admin people, DNS and multiple website setup question. | Mancini | Off-Topic | 14 | 03-17-2005 05:31 PM |
