Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 09-12-2003, 07:32 PM   #1
03WRXMA
Member#: 35081
2012 WRX
Default What is the name of the type of clamp that holds the wastegate hose onto the turbo?
You know those small spring loaded clamps? One of mine took a hike some where, and I want to use more than a ziptie to hold it on. Worm gear clamps are too large.
Who knows? I was looking in http://www.mcmaster.com/ but they have TOO MUCH stuff! Thanks in advance.
03WRXMA is offline   Reply With Quote
Old 09-12-2003, 08:05 PM   #2
QA Guy
Member#: 6739
I don't know. I would replace any of those spring type that aren't working well with screw type ones, though.
QA Guy is offline   Reply With Quote
Old 09-12-2003, 08:17 PM   #3
boostaddict
Member#: 35871
2003 WRX Wagon MBP
Spun Bearing @ 176k
It's still called a hose clamp. Your local auto parts should have some, otherwise the dealer for sure.
boostaddict is offline   Reply With Quote
Old 09-12-2003, 08:39 PM   #4
03WRXMA
Member#: 35081
2012 WRX
The dealer dosent have them, they just replace them with worm gear clamps they tech told me.
I want the damn spring loaded clamp just for ease of the MBC install/removal.
Thanks though!
Old 09-12-2003, 09:15 PM   #5
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Home depot has them, plumbing area.
Wombat North is offline   Reply With Quote
Old 09-12-2003, 09:52 PM   #6
03WRXMA
Member#: 35081
2012 WRX
You the man! If they have them Ill buy you a beer!
Is there a Gran Turismo type of PC game? NITROS Off-Topic 17 08-29-2006 07:38 PM
what is his name? I need help TOUGEwrx Off-Topic 4 11-16-2005 08:27 PM
is there a brand or type of oil pressure gauge that I should avoid? nos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-03-2005 11:53 AM
What do NASIOCers' names make you think of part 2 Subi Chicky Off-Topic 34 05-22-2003 04:56 AM
That old "vacuum hose on the intake plenum" myth... 8Complex Technical Forum Archive 5 07-08-2000 11:20 AM
