Welcome to the North American Subaru Impreza Owners Club Sunday August 18, 2019
Old 07-20-2019, 08:06 PM   #1
vectese
Member#: 504460
Default 2004 WRX Wagon--rear right passenger window goes down, but not up?
Hi guys,
As the title suggests. I've looked at other threads and my problem seems to be a bit more unique in the sense that both the driver control panel and the rear right passenger control panel both allow the window to roll down, but not up.
At first the rear right passenger control panel was able to roll the window up, albeit slowly, but now it just doesn't work at all. All my other windows and their respective control panels seem to work perfectly, so I'm not really sure where to start. Plus, this is my first car so I'm just getting into DIY work.
Any suggestions would be greatly appreciated
vectese is offline   Reply With Quote
Old 07-25-2019, 11:40 PM   #2
Bikelok
Member#: 254851
2002 WRX wagon 5mt
It would be coincidence but both the switches can be corroded. Itís a easy fix and couldnít hurt to try.
How to fix a window switch
http://forums.nasioc.com/forums/show...php?p=44430449
Bikelok is offline   Reply With Quote
Old 07-26-2019, 01:09 AM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Check voltage at the motor.
Good ground for negative, then check voltage at both wires in both up and down.
FWIW, I had a Caprice (one of those 2012ish Holden POSs) that I stripped, window wouldn't do anything from the master switch, and only went down from the right rear switch. It had a grip of broken/breaking wires in the driver's door jamb.
CosmoTheCat is offline   Reply With Quote
