Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 07-15-2019, 03:44 PM   #1
Alfred_Buchi
Member#: 382022
2003 WRX
Default EGT Code but no EGT present & Cobb AP Installed
After filling up (CA 91 premium, usual Shell station) and driving about 12 miles in ~80 degree ambient temp, I noticed some trouble accelerating in 4th on the freeway @ 70mph.
I pulled off the freeway and hooked up my AP. No CEL codes showed up on my dash but checking the AP code reader it showed "P1544 - Exhaust Gas Temperature Too HighĒ - This is odd because my up pipe is a grim speed unit with no EGT. Iíve never seen this code on my car in 3 years of using this AP. Also my DTC dropped to zero, I was in full limp mode, no boost, fine knock learn hitting Ė11.XX at 50% throttle, car was barely moving, but no feedback knock, and my AF learning numbers were normal -1.xx to +4.xx.
After pulling over and looking for anything obvious, nothing seemed out of place. So I reset the ECU with the AP, and things went back to relatively normal. AP no longer shows the code, most of my numbers seem fine, I can build some boost again but I am scared to push it hard (only hit maybe 8psi so far) or do a data log with the DAM still only reaching 15 instead of usual 16.
Any ideas here guys? Would you think itís safe to perform a full throttle data log with this situation? Or would a lower throttle log be beneficial?
Should I consider unpairing and re-pairing the AP?
Car: 2003 wrx
Mods: Grimspeed up pipe, cobb catted down pipe, cobb cat back exhaust
Tune: Cobb AP Stage 2 (CA/AZ 91 map)
Alfred_Buchi is offline   Reply With Quote
Old 07-21-2019, 12:20 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
heres the problem with cobb stuff, if you now are getting a code for some reason it has un defeated itself. so with cobb there is no way to look into the tunes to see if it turned off inless you go to a certified cobb specialist. in other words pay for someone to look into it.
Old 07-23-2019, 08:18 PM   #3
Alfred_Buchi
Member#: 382022
2003 WRX
I'm not sure I understand your complaint with Cobb GC8 - I've been emailing them with logs and going back and fourth with ideas and they've been extremely helpful.
I did not have a CEL actually come on my dash, the car did go into limp mode, and the AP did show a EGT code.
However, I am coming to the conclusion that when the car is in limp mode, the accessport can view the code that it usually suppresses.
The more important question is becoming, why is the car entering limp mode?
After a week and a fresh tank of fuel, my DAM has returned to 16 where it should be, but during a 3rd gear pull yesterday to get a data log, I had a boost spike to 20 psi! Usual is 15.5 ish in 3rd.
So this makes me think that potentially, during my 4th gear cruising at 70, the shift to 5th also prompted a boost spike which may have been more extreme causing limp mode to come into play.
I'm going to drive the same road tonight and see if I can replicate this again.
EBCS? I'm on the original from 2003 - I may pull it and clean/test tonight.
This is so frustrating - I was ready to sell this car last month and these little stupid issues keep popping up.
Old 07-23-2019, 09:39 PM   #4
Brandon Tchida
Member#: 379963
2002 TS Wagon
Dark Blue
Iíve had issues similar, mine was a boost leak which caused it to run lean and give a high EGT code.
It may be worth looking at hoses/gaskets for leaks. 🤷🏼*♂️
Brandon Tchida is offline   Reply With Quote
Old 07-23-2019, 10:00 PM   #5
Aurielo24
Member#: 502816
+1
Aurielo24 is offline   Reply With Quote
