Welcome to the North American Subaru Impreza Owners Club Thursday April 2, 2020
Old 07-18-2019, 02:03 PM   #8851
TDagen
Member#: 163648
V9 6mt R180 Brembos
Originally Posted by no694terry View Post
ya and it could actually go up a bit as you get closer to e85 in the tank (probably never get higher than e80 though from pump). Flex fuel tunes are a blend of two maps. at e70, the volumns only up like 85%
FWIW the good E85 pumps in MN have E85 over 80%. Xluben posted a photo of 83-84% reading on his accessport. IMO you gotta find the right stations.
https://www.instagram.com/p/BheIos-FYE-/
TDagen is offline   Reply With Quote
Old 07-18-2019, 04:25 PM   #8852
StiLimited
Member#: 121212
2007 Sti Limited
Urban Gray Metallic
I have to drive into Vegas to get my E85 so I buy 50-100 gallons at a time and keep it in my shed. When I buy it it tests about 80-85% but after sitting in my shed for 6 months it's now 90%. So for some reason the gasoline is evaporating and the ethanol is staying behind. (best guess) I'm storing the fuel in High-density polyethylene jerry cans. (https://www.uline.com/Product/Detail...Gallon-Natural) I've tested this for 3 years now and it's always the same results. I also use the stabil for ethanol fuel stabilizer if that has any effect I don't know. Next time I'll test before and after mixing.
I like the jugs cause they can stack 3 even 4 high when full. :-)
StiLimited is offline   Reply With Quote
Old 07-18-2019, 09:53 PM   #8853
HuckFinn
Member#: 298502
2011 WRX sedan
This got me curious about how FlexFuel sensors actually work. This is what I found...
Typical sensors used for FlexFuel setups determine ethanol concentration by measuring the relative permittivity of what's flowing through the sensor. Gasoline has a lower relative permittivity then ethanol. Water has a higher relative permittivity then ethanol. Keep in mind ethanol is hydrophilic (water loving), so it will absorb water vapor in the air over time.
What's most likely happening in your case; the E85 is slowly absorbing water vapor in the air, which will cause a FlexFuel sensor to read higher concentrations of ethanol then actual. The Stabil may also be throwing off the readings. You could test the later by running E85 through a FlexFuel sensor without Stabil, adding some Stabil to your tank and then seeing what the sensor shows after driving around for a bit to mix it in the fuel. See the below links for more info:
https://cecas.clemson.edu/cvel/auto/...el-sensor.html
HuckFinn is offline   Reply With Quote
Old 07-19-2019, 02:10 AM   #8854
StiLimited
Member#: 121212
2007 Sti Limited
Urban Gray Metallic
actually I'm not using a sensor. I'm using the Quick Fuel Test Tube
https://www.amazon.com/Quick-Fuel-Te.../dp/B007ZJ749O
I definitely will test next time before and after stabil.
But I doubt it's much water being absorbed. I live in a very dry area of So. Nevada, typical humidity is single digits. The fuel is kept in the HDPE containers tight, and they are in a vented shed. Not saying impossible, but if it is, I can't imagine it being much.
Old 07-19-2019, 08:22 AM   #8855
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
I have a theory on this, I actually asked Bisimoto about this once on one of his life chat things and he didnt understand the question I dont think.
First to understand my theory you gotta understand that a GM ethanol sensor is actually just a ohm meter. It test the resistance of the fuel at certain temps, that is why it also has a temp gauge built into it. It knows the conductivity (ability for electricity to pass through it) for both fuels. Gasoline is pretty much di-electric, electricity can barely pass through it. Ethanol, allows a little more flow but still not enough to go shorting out your fuel pump and making you explode.
Second, you need to remember that alcohol is VERY hydroscopic, it absorbs water. WATER lets electricity flow right on through it. As ethanol sits it absorbs the water in the air and as it absorbs water, I believe that throws off the conductivity reading of the sensor.
My fuel tank is pretty vented, i have no evap or anything. I can fill up today with e75 and in a week it will be reading closer to e80 with Pittsburgh humidity
no694terry is offline   Reply With Quote
Old 12-08-2019, 12:06 AM   #8856
albersondh
Member#: 196882
08 WRX
The quick fuel tube is a great no nonsense device that takes water absorption out of the equation. I was using one back when E85 started being readily available in MI (2008). Such a PIA to use compared to just watching a gauge though.... Using a Zietronix now and tuning for flex fuel. Unfortunately the days of year-round E85 in MI are over. Seasonal blend I'm getting E75.... Hunted around for any hold out stations that may still run E85 all year, haven't found a single one (Detroit area).
albersondh is offline   Reply With Quote
Old 12-08-2019, 04:33 PM   #8857
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
...But I doubt it's much water being absorbed. I live in a very dry area of So. Nevada, typical humidity is single digits. The fuel is kept in the HDPE containers tight, and they are in a vented shed. Not saying impossible, but if it is, I can't imagine it being much.
I would say it's probably a little of both. If the gasoline vapor can evaporate out, then it's getting out of the can. And, if gasoline vapor can get out, then air can get back in if the air gets cooler. It might be "dry" air, but it still contains some water vapor.
Dave D. is offline   Reply With Quote
Old 02-13-2020, 10:55 PM   #8858
Azerpm1
Member#: 455380
2004 WRX STI
Twinscroll Ej207 VF37
Recently fixed a worn wastegate actuator and injector leak. Pretty happy with the results, but wish there was more top end. Any suggestion on how to get up to 350-400hp? Thinking turbo, headstuds and decat?
Also, I've noticed the car is very hard to restart once warmed up. It'll spit fuel out the exhaust while cranking, then fire up after a few tries while holding throttle open 50%. Cold starts are fine.
https://i.imgur.com/6dPM2KK.jpg
https://i.imgur.com/xZmeHpD.jpg
https://i.imgur.com/nGpBe70.jpg
Final Tune - Hub Dyno:
Ambient: 86F
Humidity: 70%
Elevation: 101ft
308hp
330ftlb
2004 WRX STI(ADM) Twinscroll on E85
Stock Version 8 Ej207 swap(30,000miles)
Stock VF37 turbo
Stock Twinscroll Headers/Up-pipe
Raceworks 1000cc Injectors(Bosch)
DW300 Fuel Pump
Stock STI TMIC
AVO Turbo Inlet
Process West CAI
Turbosmart 15lb IWG75
Turbosmart Kompact Dualport BOV
MAC 3 port
AVO 3" Downpipe(160cell cat - 5", open bell)
Blitz Nur Spec Catback
Azerpm1 is offline   Reply With Quote
Old 02-14-2020, 12:01 AM   #8859
rexblake
Member#: 178426
2010 S4
Gray
Ambient: 86F
Humidity: 70%
Elevation: 101ft
308hp
330ftlb
Stock VF37 turbo
DW300 Fuel Pump
Stock STI TMIC
AVO Turbo Inlet
Process West CAI
MAC 3 port
Definitely a bigger turbo. Something GT30 sized would be good.
A fmic would help too.
rexblake is offline   Reply With Quote
Old 02-14-2020, 01:54 AM   #8860
subaru_gc8
Member#: 29292
2004 WRX wagon
Ambient: 86F
Humidity: 70%
Elevation: 101ft
308hp
330ftlb
Stock VF37 turbo
DW300 Fuel Pump
Stock STI TMIC
AVO Turbo Inlet
Process West CAI
MAC 3 port
I have a gtx 3067 and runnign v9 heads with cams on pump and Im close to the 400 range
subaru_gc8 is offline   Reply With Quote
Old 03-03-2020, 12:21 PM   #8861
chrisroug
Member#: 443156
2015 STI
Pearl White
Starting my closed deck on my 15 STI. Hoping for over 400 when done. I have the full cobb flex kit with 1050x's, Cobb FMIC, full Invidia Exhaust, TiAL EWG, and will have the Cobb 20g. We'll see in the coming months what she puts down.
chrisroug is offline   Reply With Quote
Old 03-25-2020, 09:07 PM   #8862
Okie Sandcar
Member#: 487484
Default E85 in the plans
I am in a different game than the posts I read here, but I am working on a Subaru project that I will be running E85, or at least whatever the pumps give me. Not a drag racer or street racer, but a sandcar. No high dollar motor, but a stock 2.5 n/a with added turbo. Still working on the conversion, so no numbers yet. The Corona virus has shut my tuner/dyno guy's business down until this stuff clears up. Major set back.
Okie Sandcar is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
