01-28-2007, 09:54 PM | #1 |
Member#: 132991
South East
Vehicle:05 sti/meth/works silver |
Big Problems With My 06 Sti
ok here i go,
bear with me because i am trying... about a week ago i was driving to go skate (fairly cold night high 50's) and while getting on the gas it sputtered really bad. so i parked and opened up the hood, and what did i find but my cobb intake seperated in the middle. that made me so very happy so i put it back together and drove on. from then on the car has not run right. i took the intercooler off and noticed that my tranny pitch mount (dogbone looking piece) was seperated in two. so i bought a new one and a day later only in first and second gear has been sputtering really bad but only when i really get on the gas (boosting). an engine code came up (p0301) missfire in cylinder 1. changed the spark plugs with NGK's and 2 new codes came up 1)p0244 and 2)p0245 the car still sputters and while driving if it boosts at all the CEL light flashes and the cruise control light flashes.............. HELP ME PLEASE!!!!VERY FRUSTRATED...DO YALL THINK ITS JUST THE BOOST SOLENOID??? checked hoses, went back to stock bov, and checked connection
01-28-2007, 10:54 PM | #2 |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
You have one of the early Cobb intakes. Contact them to let them know it came apart and they will replace it with a new one that is one-piece. In the meantime, I recommend using the stock airbox.
01-28-2007, 11:24 PM | #3 |
Member#: 103320
Vehicle:1998 swapped Forester L |
did you reset the battery? like nhluhr said install the stock intake and reset the ECU and see how it goes.
01-29-2007, 12:08 AM | #4 |
Member#: 132991
South East
i already got the new one and installed it. not that the car still give problems in first and second gear. i think i got it pegged cause my buddy just got back from vaca and he is going to find the problem fix and tune it. if anyone has any other thoughts or suggestions let me know
01-29-2007, 05:09 AM | #5 |
Member#: 119806
TXIC
Vehicle:2006 Subaru STi WRB |
i really dont have any suggestions but this same problem happened to me... all the way down to the tranny pitch mount snapping. (minus the cobb intake). I took it to my subaru dealer in hawaii. It spent about a month in the shop and they never could narrow the problem down. The Cel light would flash SOH (subaru of hawaii) said that was due to to misfiring. While in the shop they tried plugs, coil packs, and timing. Somehow they managed to "fix" the problem... they told me that a "valve cap" had expanded and stuck open causing the misfire. That's how it was explained to me, in the end the car ended up running fine for about 8 months... now the problem is back. Now im worried my car might never run right... i had planned on putting some money in it.. but why put money in something that doesnt work.. and when it does only for a couple months at a time.
01-29-2007, 03:57 PM | #6 |
Member#: 132991
South East
oh great...i can only imagine what im in for. i am taking it down to my buddy in sofla (a subaru tech) and he is going to go through the whole motor to figure it out. i have had a few people tell me that it is the boost solenoid but well see. ill keep yall posted
01-29-2007, 06:35 PM | #7 |
Member#: 103623
Vehicle:2005 STI Silver, wingless |
reset the ecu. you probably got a false reading from the air flow sensor
01-29-2007, 06:44 PM | #8 |
Member#: 81102
South East
bump for your help....
bad gas maybe....???????? |
01-29-2007, 08:02 PM | #9 |
Member#: 110648
PRSIC
Vehicle:2005 Hydramist 35R82 93oct 479whp 456tq |
could be a coil?
01-29-2007, 10:45 PM | #10 |
Member#: 96267
Vehicle:'06 20G-XT'd STI CGM & NT03+M |
Your MAF could be shot?
Try to clean it with crc electonics cleaner. I agree with stock box, hard reset |
01-30-2007, 01:26 PM | #11 |
Member#: 132991
South East
ok here is al that i did
1)changed out to new cobb intake from old alum. 2)changed from bad brealle battery 11.5 to 15 3)took off intercooler and checked all hoses (turbo, etc.) 4)took every electrical plug off and hit it with electrical contact cleaner 5)changed dog done pitch mount 6)checked and reset ecu with accessport back to stock ran and went back to stage 2 93octane and ran 7)ran till empty and filled up with the same gas i have always got since brand new (93 octane BP) 8)reset pulley because adjustment was loose 9)ran with stock airbox and cleaned MAF 10)changed spark plugs now i am not at all even close to a mechanic but i do believe i have done everything in my power. any suggestions experts? im open to all before i take it down to my friend |
01-30-2007, 04:54 PM | #12 |
Member#: 132991
South East
bump^^^^^^^^^^
01-30-2007, 08:36 PM | #13 |
Member#: 125292
TXIC
Vehicle:2006 STI FPgreen SGM |
Its the intake FOLKS, its leaking air in the middle bypassing the MAS and causing a heasitation because the engine is getting more air than it thinks. Call Cobb and tell them your intake is the old piece of sh@t and you want the new piece, its as easy as that. Intake air calb. is so important to our computers, it can **** up everything. done.
01-30-2007, 08:43 PM | #14 | |
Member#: 7327
NWIC
b) you dodged the swear filter and earned some infraction points. |
01-30-2007, 09:26 PM | #15 |
Member#: 125292
TXIC
thanks, I love nabisco
01-31-2007, 09:42 AM | #16 |
Member#: 132991
South East
anyone else want to take a guess... lets see who can guess it now.............thursday-tuesday i will update with what is actually wrong with it
01-31-2007, 10:45 PM | #17 |
Member#: 132991
South East
bump for some good guesses...maybe i should make a prize and get a pool going...............................
01-31-2007, 10:58 PM | #18 |
Member#: 48307
SCIC
Vehicle:02 bugeye hbspeed tuned 18g sleeper |
make sure your coil pack harnesses are plugged in tight. also, make sure they are plugged in the right locations. i'm not sure if it's the same as the wrx, but the black colored harnesses go in the rear and the white colored harnesses go in the front. your spark plug gaps may not be in spec either.
01-31-2007, 10:58 PM | #19 |
Member#: 115223
Vehicle:2005 Subaru STI silver |
try a boost leak test... and make sure that you "tug" on the vac lines to the fpr and in front of the mani (across the mani form the fpr). Those vac lines kept poping off of my intake mani, and would cause detonation. The boost would blow them off, and the instant vac would suck them back on. It was a mess untill I got it all figured out.
02-02-2007, 12:19 PM | #20 |
Member#: 132991
South East
the coil packs are getting changed tonight....well see what happens and then move forward from there
02-02-2007, 02:24 PM | #21 |
Member#: 89945
Vehicle:2005 STI pearl white |
Stop using BP fuel.
02-02-2007, 03:15 PM | #22 |
Member#: 38016
SCIC
Vehicle:2017 STI 2016 F-150 XLT |
Stop modding it or lemon law.....
02-02-2007, 03:34 PM | #23 |
Member#: 106050
Vehicle:- pm Josey Wales |
^^^lemon law FTW!!!.....well actually FTL good luck!!
02-02-2007, 03:44 PM | #24 |
Member#: 853
Vehicle:2011 STI Sedan Satin White Pearl |
check this,behind the battery there are 2 big connectors-black one and brown one-check the wires going into those connectors.sometimes when the pitching stopper breaks the left side of the motor will lift higher then normal and break some of those wires.i have seen this several times.
dave |
02-04-2007, 04:34 PM | #25 |
Member#: 132991
South East
i am going to try that....that is something very important to know....thank you very much
Big problem with my 07 sti swap into my 04 wrx...... | Samurai_jim | Subaru Conversions | 17 | 01-08-2009 06:36 PM |
fitment problem with the 06 sti and txs fmic | Smoke Show | Water/Methanol Injection, Nitrous & Intercooler Cooling | 0 | 08-12-2007 07:20 PM |
My first track event with my 06 STI | ORACLESTI | General Community | 22 | 11-17-2006 12:22 AM |
Anyone have this problem with an 06 STI? | altima04 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 48 | 11-06-2006 06:29 PM |
i got a problem with my jdm STI headlights o.O | d0gsoup | Electrical & Lighting | 7 | 10-22-2003 10:18 PM |
