Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 07-03-2015, 09:42 AM   #326
quazimoto
Member#: 70395
The big issue is if it repeatable or not and if the knock is clustered around an area and not random.
Old 07-03-2015, 02:06 PM   #327
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
You should run an analysis of you hour+ log and see if all the reported knocks are clustered around a particular load/rpm. There is a spreadsheet in rr to do this. Then play with timing in that area to see if you can reduce it
Bad Noodle is offline   Reply With Quote
Old 07-03-2015, 04:20 PM   #328
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
A couple more thoughts:
First make sure the knock is real. The stock sensor can interpret certain engine noise as knock. Easiest way to do this is to make yourself a auditory knock sensor. The. You can listen to the engine and see if you hear it knock when the ecu reports a knock.
Make sure you don't have a bolt laying on the block that you dropped in there and that nothing is loose and tapping the block.
Finally if you find where your knock is concentrated and verify that it's real, make small adjustments to you timing to see if things get better.
Old 07-03-2015, 04:54 PM   #329
jblocka
Member#: 414762
06 Wrx sti
Blllllack
Bump so I cAn follow
jblocka is offline   Reply With Quote
Old 06-04-2017, 12:55 PM   #330
primalis
Member#: 468766
1998 impreza wagon
green
Subaru Stars
So just to clear things up for me as I'm new to the opensource tuning world, would you be able to do an N/A to turbo conversion on the stock ecu (obviously other supporting mods would be needed) so long as you had the knowledge to tune the computer properly?
primalis is offline   Reply With Quote
My Swap: 1999RS to 2002WRX. Complete Wiring Guide Inside 99 rs Subaru Conversions 240 11-09-2018 10:37 AM
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 02:17 AM
Complete open source tuning guide shutupnshift04 Commercial ECU Reflashes 19 05-10-2007 06:16 PM
Updated StreetTUNER Tuning Guide and Tuning Guide Worksheets... Christian. AccessPort 0 04-17-2007 06:24 PM
Complete Price Guide. Diabolical1 CC Canada Region Forum 0 06-20-2006 03:40 AM
