Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 04-26-2017, 06:52 PM   #276
mikeyPSF
Member#: 236475
If those buttons are grayed out in EcuFlash, then EcuFlash isn't detecting the Openport. That problem is independent of the OBD2 port. You could be sitting inside your house far from the car with Openport only connected to the laptop via USB and you should see those buttons active.
What does it say in the lower right hand corner of EcuFlash? It should say "Openport 2.0 USB" but if it says "no vehicle interface" then you need to work on that. It could be an issue with the install of the Windows device driver or could be even simpler, a bad USB cable. If you have another mini-USB cable handy, try that first as it only takes a few seconds. If you need help troubleshooting the Windows device driver, just make sure you're using the current version of EcuFlash and if you are, then send me an email to support at tactrix . com
By the way, Java is needed by RomRaider but EcuFlash doesn't use it at all.
-Mike
Tactrix
mikeyPSF is offline   Reply With Quote
Old 04-29-2017, 10:52 PM   #277
Ghostdriver22
Member#: 376197
2014 WRX
Pearl white
Default 1.3u communicating with laptop
-Mike
Tactrix
--Thank you for reply, Mike! I sent an email to "[email protected]"
Bottom right of ecuflash displays [No vehicle selected] OpenPort 1.3 Universal
Ghostdriver22 is offline   Reply With Quote
Old 05-01-2017, 10:08 AM   #278
superevilkeith
Member#: 455950
2005 OBXT L
I'm just finishing up a build on an OBXT. I have a Tactrix open port 2.0. Can anyone refer some E tuners? I have been poking around and it seems everyone wants a COBB. I would like to avoid buying one if I can.
superevilkeith is offline   Reply With Quote
Old 05-01-2017, 12:51 PM   #279
mikeyPSF
Member#: 236475
Sounds good. Monday are my busy days so it might not be until late today before I get back to you but I will.
I'm a little hesitant to weigh in here as there are just so many tuners to choose from but Cameron Dawes is a popular one that does e-tunes for what seems to be a really reasonable rate. camtuning.com
-Mike
Tactrix
Old 05-17-2017, 01:58 PM   #280
Ghostdriver22
Member#: 376197
2014 WRX
Pearl white
-Mike
Tactrix
Thanks Mike. Im all set now and have been experimenting with the tables. I have been previously tuned my Wingz in AZ when I owned an Evo8 and will probably stick with him or the folks over at STM tuned. Thanks again for your help!
-F
Ghost
Old 08-15-2017, 11:50 PM   #281
Black94Snake
Member#: 274499
1994 5.8T Cobra
755rwhp @ 16psi
Hi! Trying to get ecuflash to communicate with 06 wrx. Previous owner had removed obd2 from dash location, possibly to connect aftermarket system or tuner. I have some experianc using ecuflash and evoscan on previous car"evo8". Current problem is my ecuflash will not display the *read, write,test write to ecu. I have java, I have reloaded ecuflash, and I have tried different laptop. Anyone ready to kick my ecu in the toosh and help me pull the
Gonna bump this up, because I just had the same issue.
You need to go in the device manager and update the driver for the OP2.0. Windows assigns it as a "Vehicle Pass Through" and ECUFlash won't work with it.
You need to update the driver with the FTDIBUS driver in the ECUFlash folder. Once I did this, it was assigned as a comm port, and immediately worked.
Black94Snake is offline   Reply With Quote
Old 09-03-2017, 12:21 PM   #282
GioB18
Member#: 456767
Hi guys, have a question about the cable. To read/write ecu roms is it mandatory to use tactrix openport or any other obd cable will do the job?
GioB18 is offline   Reply With Quote
Old 09-03-2017, 12:23 PM   #283
Black94Snake
Member#: 274499
1994 5.8T Cobra
755rwhp @ 16psi
I managed with a $10 Vag-Com cable off eBay. Now I have the OP2.0.
It's a small price to pay, to ensure you actually get something that works right out of the box.
Old 09-03-2017, 01:13 PM   #284
GioB18
Member#: 456767
Thanks Black94Snake
The fact is that this flashing is a one off episode, i've not the knowledge for build my custom rom but have received one from a friend and want to try without going to the tuner, given that there are no code issues. But for 160$ or so i think it's better to go for the safety of a tuner
Old 09-03-2017, 01:14 PM   #285
Black94Snake
Member#: 274499
1994 5.8T Cobra
755rwhp @ 16psi
If you have no intentions to use the device on a regular basis, go see a tuner.
Old 03-10-2018, 04:43 PM   #286
SubeN'Siren
Member#: 151171
02 Subaru WRX
Default Bad connection, or bad o2 sensor
First time trying to log with Openport 2.0
appears to connect, but stops at densoO2_bootloader_cmd_start
Tries 5 times, then,
kernal get version
followed by,
interface close
interface close.
I have other reasons to suspect the O2 sensor is bad, is that the issue, is the connection bad, or am I doing it wrong?
SubeN'Siren is offline   Reply With Quote
Old 05-11-2018, 02:45 PM   #287
tsilo
Member#: 485842
cant find ecu map for 2.0 2004 n/a. is it possable to remap this engine ? jdm ej20
tsilo is offline   Reply With Quote
Old 10-27-2018, 08:16 PM   #288
ubareddition
Member#: 265374
2003 2.5x
pacifica blue pearl
Apologize for apparently being an idiot but I bought a open port 2.0 installed ECU flash and rom raider. I believe I downloaded the proper definitions. Running on Windows 8. ECU flash I get an error j2534 err timeout.
I can't get ROM raider to work at all but then again I have no idea even where to start. Any quick tips to at least get me started so I can try to learn how to use it?
ubareddition is offline   Reply With Quote
Old 11-19-2018, 12:49 PM   #289
Smurftastic
Member#: 243697
Stg2 +ECUtuned 02WRX
BLOD Cofounder|TopScoob31
Honestly, best bet is to find someone who successfully set everything up and ask they setup your stuff -- it can be really finicky.
Smurftastic is offline   Reply With Quote
romraider/ecuflash? weaponstroop Open Source Reflashes 12 04-08-2018 04:49 AM
reading logs - FAQ or getting started guide? jmc9809 Newbies & FAQs 2 08-05-2005 07:40 PM
I want to get started racing! Where to start? wayne_rx Motorsports 27 12-23-2004 04:00 AM
Auto-Xing Newbe, How to get started? Ed_RS New England Impreza Club Forum -- NESIC 7 01-31-2001 12:34 PM
how to get started jjp New England Impreza Club Forum -- NESIC 5 11-09-2000 07:26 AM
