08-07-2012, 09:33 PM | #451 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Well, they still include one feature that was on their older gaskets that ruins heads and causes leaks. Look at the extreme corners of the gasket in the PDF. See the little copper rivets? Those end up embossing their shape deeply into the head and the block meaning that the gasket no longer seals at the factory-recommended torque. Then, because they leave a dent, it's difficult to make other gaskets seal after you try to fix the ufcked up job left by the idiot that used felpro.
08-08-2012, 06:11 PM | #452 |
Member#: 211268
Vehicle:2006 Impreza AW |
2006 2.5i @ 52k miles for driver side and 62k miles on the passenger side. Lucky both were covered from SOA Certified pre-owned warranty. For some reason looks like the 06-07 are pretty terrible.
08-08-2012, 06:45 PM | #453 | |
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
08-08-2012, 10:07 PM | #454 |
Member#: 141373
E. Canada
Vehicle:2022 Crosstrek Sport 6MT |
Why not get the STi gaskets instead of trimming the Felpro ones?
08-08-2012, 11:15 PM | #455 |
Member#: 28685
08-08-2012, 11:19 PM | #456 |
Member#: 43038
Vehicle:2002 Forester S Black |
Ok...so the question is if it's an external leak does it really matter?
08-08-2012, 11:23 PM | #457 |
Member#: 71092
08-09-2012, 12:01 AM | #458 |
Member#: 43038
Well than how did some Subie owners get such high mileage? I'm feeling I got screwed on this head gasket deal : (
08-09-2012, 03:51 PM | #459 |
Member#: 328622
Vehicle:1999 Impreza 2.5 RS Aspen White |
I bought a 1999 2.5 rs a week ago, and the previous owner stopped driving it 3 years ago, saying that it had a blown head-gasket. I got the car at an absolute steal, and my mechanic then found out that the gasket was actually fine, and there was no crack in the cylinder head either. She has 108k miles and hasn't had a broken head gasket! Hooray!! got her for $1650. I am the luckiest person on planet earth you could say
08-10-2012, 04:01 AM | #460 | |
Member#: 253304
AKIC
Vehicle:2001 Impreza 2.5RS Plus MOAR |
I still can't believe my parent's legacy isn't even seeping yet. Once the odometer hit 80k I was like okay... Next oil change next oil change.. And it's been that way for the past 22k miles. Knock on wood though ;-) |
08-10-2012, 06:41 AM | #461 |
Member#: 174442
Vehicle:2007 SuperWagon I don't spell well |
I need to do a HG on a 99 forester. Thinking of just getting all the felpro stuff from autozone. Any objections?
08-10-2012, 07:03 AM | #462 |
Member#: 174442
Also, this might be useful:
It's a comparison of the torque spec and sequence for the oem composite gasket to the felpro mls gasket this might address the problem mentioned earlier about the felpro having the copper rivets on the corners. Those bolts are tightened less than the middle which should eliminate the problem of the rivet gouging the metal. I can see that happening if you use oem torquing instructions. |
09-11-2012, 07:38 PM | #463 |
Member#: 149448
mine are leaking on both sides, 2004 TS with 99k on it. anyone use the felrpo gaskets yet?
09-11-2012, 07:55 PM | #464 |
Member#: 232089
Vehicle:2007 Impreza 2.5i Crystal gray metallic |
Did mine today, 126k miles 07 2.5i. Motor goes back in tomorrow, used the 642 sti gaskets. well c if everything goes well.
09-11-2012, 08:15 PM | #465 |
Member#: 94299
Vehicle:2000 2.5 RS Sedan SRP |
58k on my 07 2.5i wagon and drivers side hg is leaking externally. doesn't see horrible yet but i am past the warranty date wise, from my research, it's crazy expensive to repair
09-12-2012, 12:11 AM | #466 |
Member#: 165749
09-12-2012, 09:35 AM | #467 |
Member#: 141373
E. Canada
09-13-2012, 10:01 AM | #468 |
Member#: 146216
South East
Vehicle:2007 Impreza 2.5i SE Newport Blue Metallic |
I'm now at 98000 miles on my 2007 Impreza and mine are leaking, also I have bubbles in the coolant reservoir. I will be taking mine to six star service in Atlanta for repair along with the timing belt and clutch.
For the record I did all the coolant changes myself, 30k miles interval, and 5k oil changes with synthetic. I also changed the PCV in case it might be a contributing factor but nope. They leak regardless of meticulous maintenance. |
09-13-2012, 01:09 PM | #469 | |
Member#: 244231
NESIC
Vehicle:2018 Crosstrek CVT DGM |
I have 90k on my 2006 and so far so good. |
09-13-2012, 04:36 PM | #470 |
Member#: 174442
I installed the feltpro gaskets and they looked really high quality. Their gasket set was sweet too. It came with everything needed+some extras and even some gasket maker
09-16-2012, 12:09 PM | #471 |
Member#: 146216
South East
John - I did use the coolant conditioner and subaru coolant at each change.
09-16-2012, 01:54 PM | #472 |
Member#: 28685
If I buy a gasket set, and it comes with liquid gasket maker, that's not exactly a confidence booster...
09-16-2012, 10:27 PM | #473 |
Member#: 102895
Vehicle:'12 Forester '17 Outback |
09-17-2012, 12:38 AM | #474 |
Member#: 28685
09-17-2012, 12:54 AM | #475 |
Member#: 71092
Not to mention that there's a LOOOOONG history of using any sort of liquid gasket maker just resulting in rapid headgasket re-failure.
EDIT: I made a typo in that and wrote "hadgasket". I'm honestly not sure that's not more accurate... |
WRX/STi axle back exhaust bolt on to NA 2.5? | Kid Icarus | Normally Aspirated Powertrain | 10 | 09-04-2011 01:43 PM |
Which head gasket will be most reliable for 2.5 / 2.2 hybrid? | JoshP | Normally Aspirated Powertrain | 8 | 06-02-2006 03:27 PM |
APEXi S-AFC on a NA 2.5 | AngryBlueRS | New England Impreza Club Forum -- NESIC | 15 | 05-21-2004 10:07 AM |
Oxygen Sensor problems on 2000 Impreza 2.5 RS | knoffer | Warranty Issues & SOA Problems | 20 | 12-12-2001 05:04 PM |
Oxygen Sensor problems on 2000 Impreza 2.5 RS | knoffer | Normally Aspirated Powertrain | 11 | 12-03-2001 01:42 AM |
