Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 10-24-2008, 10:31 AM   #101
neilschelly
Member#: 94902
1989 Porsche 944S2
Beige
Originally Posted by DS1 Motorsports View Post
A new front diff offering
http://forums.nasioc.com/forums/show...1#post24192591
-Dylan @ DS1
Thread went away. Don't know why... I wish the error message you get when you go to a hidden/deleted thread or whatever said why it was hidden or deleted.
-N
neilschelly is offline   Reply With Quote
Old 10-24-2008, 11:53 AM   #102
DS1
Vendor
Member#: 111780
Link fixed
DS1 is offline   Reply With Quote
Old 12-02-2008, 10:20 AM   #103
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Anyone tried the new diff that out???
Old 12-05-2008, 05:16 PM   #104
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
link is not there anymore..
found on the previous page your link.
any layway plan with today's economy?
Old 12-06-2008, 01:00 AM   #105
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
My experience has been that there are adequate offerings in the front and rear to assemble a balanced program for whatever arena you are campaigning, however, the center diffs offered off the shelf leave a lot to be desired when it comes to building an extensible system that can scale well across environments. I run an S5 rear with the gold wrapped N11 center; this plays out pretty well in most environments. Notably it is the center diff that brings the system together, whether I am running Cusco tarmac, the Prodrive S5 or otherwise.
The N11 center makes use of extensive slip control functions in combination with gear-based mapping functions allowing the response of the center differential to be better tuned for both under-steer / over-steer control as well for corner speed.
The result is that the center diff control is optimized for a greater variation of corner types, i.e.
– being relatively free in slow corners to aid turn in but locking up quickly to aid traction out of the corner, having good response to over-steer/under-steer in medium speed corners and free again at high speed to reduce transmission drag on the engine ( this is an important conditional that has been missed by this thread thus far ).
The whole system is easily controlled, from the cabin, via a thumb wheel.
My current set up, per PD:
Position 1 (lowest ladder light – green)
· Road position - center diff free
Position 2 (second from bottom on ladder – green)
· Basic slip map equivalent to standard N11 position 4
Position 3,4 & 5 (3rd 4th 5th lights from bottom – orange)
· Gear based slip maps!!!
Position 6 (Top ladder light – orange)
· Center diff locked
The controller is a Pectel unit that can by managed independent of the Prodrive maps as well. A relatively inexpensive implementation would be a simple Cusco front and rear set up, stacked to your needs, and managed by an N10 or N11 center.
SLR-
SuicidalLabRat is offline   Reply With Quote
Old 03-09-2021, 08:20 PM   #106
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Made this a Sticky.. Outstanding information for those that are chasing Grip, Traction, and trying to understand what AWD with Diffs mean..
Bill
Old 03-31-2021, 04:27 PM   #107
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Holy cow, there IS still a moderator on NASIOC
Old 05-02-2021, 10:20 AM   #108
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
02' EJ205 20G 6MT wagon
Reading this thread physically enlarged my brain
K3rm1tth3fr0g is offline   Reply With Quote
Old 06-11-2021, 12:29 PM   #109
heypeck
Member#: 58695
2003 WRX
midnight blue
Hello
heypeck is offline   Reply With Quote
Old 09-01-2021, 10:57 AM   #110
AnnaMia
Member#: 526354
Originally Posted by Scooby South View Post
As I am venturing into getting all my Diffs done...I would like some input on what people think about certain kinds of diffs...not name brands...but Styles...I guess it would depend on what kind of car your building...a Tarmac (Autocross) car...or a Rally (Rallyx) Car...
I am looking into the options for specifically for a Street Prepared Subaru
What options are out there?
Guess it depends on what diff you want to replace....
for the front...there are Helical, Suretrac, 1.0, 1.5 and 2.0 LSD's out there...
What are the advantages of either???
As for the Center diff..I Know there are about 3 different choices for the 5 Speed and couple of more for the 6 spd...
there is the factory Viscous 5kg Center diff, there is a Viscous Gymkana 12Kg center and a OMG Viscous (rally) 20KG Center....there are also options for the DCCD... with different lock up points....minotaurfightstore | minotaurfightstore
The Rear also has alot of options....along with the factory viscous has a 1.0, 1.5 and 2 way option also....
What would be the ultimate setup for tarmac....
how about AutoX....
What would be the ultimate front/rear bias????
thanks...I hope this stimulates some good discussion......
right now...my SP Setup is:
-Helical Front diff
-Gymkana 12KG Center
-Factory Viscous Rear
Plan is to swap out the rear with a mechanical 1.5 way LSD...then I should be pretty close to where I want to be..
Bill
Really cool. You can make everything good. I LIKE THE Narration.
AnnaMia is offline   Reply With Quote
Old 10-14-2022, 09:52 AM   #111
EvanBoothe
Member#: 531768
Thanks
EvanBoothe is offline   Reply With Quote
Lets talk about headers JaMa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 04-22-2002 01:35 AM
Lets Talk About Sway Bars SillyAssKilby Brakes, Steering & Suspension 4 04-16-2002 02:49 PM
Ok lets talk about TEC III or II WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 04-04-2002 12:10 PM
Lets talk about brakes JaMa Brakes, Steering & Suspension 44 01-15-2002 08:40 AM
