Welcome to the North American Subaru Impreza Owners Club Friday January 24, 2020
Old 11-08-2018, 11:38 PM   #1
atbwrx
Member#: 447001
2014 WRX
Default 2014 WRX Alpine Tweeter & Amp /Kicker Speaker & Sub Install
Decided to upgrade the sound system in my 2014 WRX Hatch.
After looking at various posts on NASIOC and other sites, I decided to stick with OEM for ease of installation. I know there are better components for less, but I like the idea of keeping things looking stock, both inside and outside the car.
I'll post the install as it goes along.
Here's what I got:
Alpine SPR-10TW Tweeters (already stripped out of their casings when pic was taken)
OEM Kicker Speaker Upgrade
OEM Kicker Sub Woofer
Alpine KTP-445U Amp
ae64.com 20 pin breakout harness
Ballistic Sound Dampening
https://i.imgur.com/aamTKB6.jpg
atbwrx is offline   Reply With Quote
Old 11-10-2018, 01:12 PM   #2
atbwrx
Member#: 447001
2014 WRX
Here’s a quick comparison of components.
I went with the Alpine SPR-10TW Tweeters because they got great reviews, and they were about the same dimension as the stockers. Here’s the side by side comparison:
https://i.imgur.com/fmQgHyu.jpg
The Alpine has a larger magnet, and just holding in the hand weighs a lot more.
The stock system was actually pretty good. I didn’t buy the car new, but apparently it was ordered with the upgraded speaker system that was available at the time because the speakers are two-way like the Kickers.
https://i.imgur.com/O7Bmsxe.jpg
The Kickers have a lot larger magnets, and are rated at 100w. The stockers state on the magnet that they are 40W @ 4ohms. It looks like the cone material on the stockers is aluminum.
I installed the new components in one door so I could do a side by side comparison.
The stock tweeter didn’t stand a chance, the Alpine tweets are killers. The Alpine has so much more clarity and depth of sound – it was day and night. The Alpine tweeter was actually dominating the sound a bit (I haven’t installed the Alpine KTP-445U Amp or the Kicker sub yet), so I set them with a 4db cut which brought them back in balance.
The Kicker door speaker had a very tight, percussive mid bass response. The stocker had way more boom. I was surprised by this, but I can see where the Kicker door speaker would slot in well with the sub, where the stocker would be competing with it. (“Door speakers aren’t for bass”)
Side by side, at low to mid volumes, I’d say the stock set up provides decent highs and more low bass response. The Alpine/Kicker combo has a lot more clarity, and a lot more precision in its bass response, but it doesn’t boom like the stocker.
As you crank the volume, the stockers will start to distort, where the Alpine/Kicker combo has a lot more headroom. At high volumes the Alpine/Kicker combo starts to balance better (bass response catches up to those crystal clear highs) and you start getting that immersive sound experience, where with the stockers you are just listening to loud music. Can’t wait to do the sub and amp install and see how it sounds.
Old 11-11-2018, 01:04 AM   #3
atbwrx
Member#: 447001
2014 WRX
Tweeter Removal and Replacement
Removing the tweeters is pretty straight forward.
Using a pry tool, you can catch the seam between the plastic sail panel and the front door frame and start to separate the tweeter housing from the door.
https://i.imgur.com/Nj2Mk4n.jpg
I used the tool to create enough space to get my fingers inbetween the housing and the door and then pulled the housing off the door.
https://i.imgur.com/HaojTib.jpg
Disconnect the tweeter wire terminal and remove the tweeter housing from the door.
To remove the tweeter, just unscrew the three Philips head screws on the back of the housing. You can see them in the pic below, the bottom screw has been backed out.
https://i.imgur.com/6xdFBoM.jpg
Here’s the Alpine tweeter in its factory casing.
https://i.imgur.com/o2hDK7e.jpg
The screen and the backing plate on the casing twist/lock into place. Just twist them both like you’re opening a jar and they will come off.
https://i.imgur.com/PuwC9KJ.jpg
https://i.imgur.com/ekpgOqB.jpg
Here’s the Alpine tweeter sitting on the stock tweeter grill. I used a small bead of clear silicone on the inside of the speaker grill rim to help hold the tweeter in place. It cures in an hour, but I let it sit face down overnight to make sure the silicone fully dried. I didn’t want to risk any silicone getting on the tweeter dome.
https://i.imgur.com/cGDk2eZ.jpg
The next day, I put the stock backing back on. Because the Alpine tweeter is a little bit thicker than the stocker, the bottom screw wouldn’t totally bottom out. Don’t force it, it doesn’t need to be totally cranked down and if you try you will just strip out the plastic. Just turn it until it is snug, and don’t mind that the backing plate doesn’t sit flat against the tweeter grill.
I didn't take a picture, but I cut the wire terminal plugs off the stock tweeters and soldered them onto the Alpines so they could be plugged into the stock door harness.
Old 11-13-2018, 02:06 AM   #4
atbwrx
Member#: 447001
2014 WRX
Head unit removal
Use a pry tool to separate the HU / center vent trim surround from the dash.
https://i.imgur.com/9KsLiTg.jpg
The trim piece pulls straight off.
https://i.imgur.com/bZXF2N3.jpg
With the trim piece off, the HU mounting screws are exposed. For the 2014 model, there are four phillips screws, two on each side of the face of the HU.
https://i.imgur.com/wHBWw6k.jpg
I did the total happy dance when the HU pulled right out. I’d read about having to remove the glove box, and dash trim in order to access bolts that mount into the side of the head unit. Not the case with the 2014. The four screws from the front are all there is.
https://i.imgur.com/2XDdeha.jpg
With the HU out, I got a good look at the room behind the dash, I went ahead and removed the center vent tubes (two phillips screws, one on each side) to give better access to the center dash cavity.
https://i.imgur.com/hG6to8r.jpg
I’m hoping to mount the Alpine amp in the dash where it will be out of site. Lots of room back there.
https://i.imgur.com/YJ0EjgO.jpg
Old 11-13-2018, 03:33 AM   #5
atbwrx
Member#: 447001
2014 WRX
Alpine / ae64.com harness install
I donít do a lot of car audio work, so this thread is meant to be very basic and step by step to help those that donít do a lot of car audio work.
Iím working with four harnesses here, the OEM Subwoofer harness, the ae64.com 20 pin break out harness, and the two harnesses that come with the Alpine amp (input and output).
For me, step #1 was to mark the ends on ae64.com harness to help me keep track of which end of the harness I was working with. I lined it up with OEM Sub harness which was labeled, and marked which side was the car/harness side and which was the HU side.
https://i.imgur.com/D7cIzss.jpg
The ae64.com website has a complete wiring pin out, using that information I was able to identify which wires are the speaker wires on the ae64.com harness.
https://i.imgur.com/hEkiI7p.jpg
So with that information, I went to the ae64.com harness, and separated out the speaker wires (grn, grn/blk-gry,gry/blk-wht, wht/blk- vlt,vlt/blk).
https://i.imgur.com/dBeV0NI.jpg
Note that input (RCA) leads on Alpine Amp are much shorter than output leads.
https://i.imgur.com/mjwCqyo.jpg
So to provide working length to the input lead connection, I cut the speaker wires on the ae64.com harness closer to the car/harness plug.
https://i.imgur.com/J8jZF80.jpg
Whenever I do a big soldering project, I always forget to preload the heat shrink at some point. So this time I preloaded all 8 output leads first before starting. Just make sure to push the heat shrink far enough down the wire so it doesn't get exposed to heat from the soldering iron.
https://i.imgur.com/NQLUjMw.jpg
Be careful using the heat gun this close to the terminal plug. I (thought) I was being careful, but it still got hot to the touch. Donít want that to warp on you.
https://i.imgur.com/vkavEJ0.jpg
Cut off the female RCA plugs on the Alpine in preparation of soldering the leads from the HU side of the ae64.com harness to the amp. Another option is to solder Male RCA plugs on the HU side of the ae64.com harness, but I'm planning on leaving the amp with the car so I'm hard wiring it in.
https://i.imgur.com/Kwgshla.jpg
Ready to solder the Alpine input leads (RCA plugs cut off) to the HU side of the ae64.com harness.
Load up your heat shrink first.
https://i.imgur.com/UIx0rzC.jpg
Leads soldered up.
https://i.imgur.com/4TidMhv.jpg
Old 11-13-2018, 03:33 AM   #6
atbwrx
Member#: 447001
2014 WRX
Next, locate the yellow and the black T-branch wires in the ae64.com harness, and the yellow and black leads on the output side of the Alpine amp.
https://i.imgur.com/MHOpkML.jpg
These will be soldered together, don’t forget to load your heat shrink first.
https://i.imgur.com/UB78v2C.jpg
Find the red T-branch lead on the ae64.com harness and the blue/white lead coming out of the INPUT side of the Alpine Amp (same side as the RCA cables), solder together. There's a blue/white lead on the OUTPUT side, you will not be using that one.
https://i.imgur.com/cxcyYYy.jpg
https://i.imgur.com/Ma4UlhW.jpg
The blue and white lead on the OUTPUT side of the Alpine amp is not used. I taped up the exposed end and wrapped with heat shrink to insulate it.
https://i.imgur.com/VNW4WWP.jpg
https://i.imgur.com/Xxtneb7.jpg
With that, the harnesses are ready for installation.
This pic shows the order of installation: HU, then the OEM sub harness, then the ae64.com harness, and then the Alpine harness into the amp.
https://i.imgur.com/0MMwYkL.jpg
Old 11-13-2018, 04:16 AM   #7
atbwrx
Member#: 447001
2014 WRX
Adjusting / Installing the Alpine Amp
The access plug is a rubber flap on the bottom of the amp.
https://i.imgur.com/DEDLCHF.jpg
When removed it exposes 6 dip switches.
https://i.imgur.com/vBAtbQg.jpg
Going from left to right, the first two control the front High Pass Filter, and 3 and 4 control the rear HPF. They are turned off from the factory. Switch 5 is the 2 channel / 4 channel selector, and is set for 4 channel from the factory. The 6th switch is for the line level and is factory set for RCA.
https://i.imgur.com/yVzbk8C.jpg
Because the output from the HU is at speaker level, I flipped the 6th dip switch into the down position.
https://i.imgur.com/5V1pmwC.jpg
The gain controls are on the side of the amp. The directions say that when using speaker level inputs, that typical gain is set between minimum and 9 o'clock.
https://i.imgur.com/vAjoXZb.jpg
In reviewing posts on NASIOC, most seem to have their's set at the second mark which is closer to 10 o'clock, so that’s the setting I used.
https://i.imgur.com/ZGRLbfl.jpg
With the amp all set up, it was time to find it a home in the dash.
Power amp installed nicely in HU cavity below the center vents.
https://i.imgur.com/dly9qG1.jpg
Ghetto on the mounting job using three mondo zip ties to hold it in place, but no one is going to see it tucked away in the dash board. Its held down solid, and fore and aft. I can move it side to side for now, which will allow me to access the ports on the side to plug in the harnesses when I reinstall the HU.
https://i.imgur.com/K2aOnix.jpg
Old 11-17-2018, 02:31 PM   #8
atbwrx
Member#: 447001
2014 WRX
Installing Harnesses in the Dash.
First, I ran the OEM sub harness through the HU cavity. I ran it on top of the front crash bar with the factory harness already there, and let the sub end of the harness fall into the driver side foot well. The routing of the sub harness will follow in a later post. I left the input side hanging free in the dash cavity, we’ll get to that later.
https://i.imgur.com/B9qxjnO.jpg
https://i.imgur.com/kDfTSgb.jpg
I then connected the ae64.com harness (with the Alpine harnesses soldered onto it) to the Alpine amp. Because the Alpine amp is only secured in the center, I could slide it (with a little bit of force) to one side so I’d have room to plug in the amp input harness, and slide it to the other side to plug in the amp output harness, and then re-center when done.
https://i.imgur.com/xgO4WD4.jpg
I then connected the car/harness side of the OEM sub harness to the HU side of the ae64.com harness.
https://i.imgur.com/ZdU9uYO.jpg
Make sure that NONE OF THE WIRES are coming through the heater vent opening before connecting, otherwise you won’t be able to put the HU or heater vents back in.
https://i.imgur.com/6k96tBY.jpg
Next I connected the car/harness side of the ae64.com harness to the 20 pin plug that was originally plugged into the HU. A true sense of accomplishment plugging this connector together, knowing that the mess of wires that was all over the coffee table the day before was now connected to the car.
https://i.imgur.com/Mk9f5KT.jpg
With the harnesses all plugged in, I took a moment to tidy up the wires. The Alpine amp output harness forms this nice “U” shape, so I taped those wires together .
https://i.imgur.com/4oPinh8.jpg
I then bundled all of those wires together, and the input side I bundled separately, and pushed them all to the back of the dash cavity.
https://i.imgur.com/yQvVWcF.jpg
Old 11-17-2018, 02:34 PM   #9
atbwrx
Member#: 447001
2014 WRX
I then re-centered the Alpine amp on the zip ties and used electrical tape on the front and back of the amp to secure to the zip ties so it wouldn't be able to move laterally in its mounted position.
https://i.imgur.com/leaZgHW.jpg
Make sure you have unburied these 6 wires before you reinstall the HU.
https://i.imgur.com/SP8JjZM.jpg
Bring the HU up to the dash opening, and install the amp ground harness.
https://i.imgur.com/RCEMNuu.jpg
Plug in the remaining five connectors into the back of the head unit.
Slide the HU back into the dash, and reattach with 4 screws.
https://i.imgur.com/cUNUKgf.jpg
Re-install your heater vent tubes, center console trim surround, and your dash work is done.
Old 11-19-2018, 10:23 PM   #10
atbwrx
Member#: 447001
2014 WRX
Speaker and sound deadening install:
In order to remove the door panels, you first need to remove the tweeter sail panel.
https://i.imgur.com/lrHU3Xy.jpg
Use a pic to expose the screw heads under the door pull and the armrest and remove.
https://i.imgur.com/UQYd3RU.jpg
https://i.imgur.com/HbpIHF0.jpg
Use pry tool to separate control panel from arm rest, then reach under and lift off from the front.
https://i.imgur.com/p1MEHQR.jpg
https://i.imgur.com/98ro6Tj.jpg
Turn the control panel over and remove the two terminal plugs.
https://i.imgur.com/bJ4TJMd.jpg
https://i.imgur.com/4H65h50.jpg
Two screws are exposed after removal of the control panel, these need to be removed.
https://i.imgur.com/Fn78mee.jpg
Old 11-19-2018, 10:47 PM   #11
atbwrx
Member#: 447001
2014 WRX
Use a pry tool to separate the door panel from the door. The lower corner near the door speaker seems to be the favorite starting point.
https://i.imgur.com/bQDkSH1.jpg
Work your way around the panel, and pull it off the door. The panel will pull up to about 6" off the door, but will still be attached by the door pull and lock cables. These are snapped into the door panel, and with a good tug will pull free. By manipulating the door pull and interior manual lock switch, you call pull the ball end out of the top of the controls and separate the door panel from the door.
https://i.imgur.com/715ObMc.jpg
Unclip the door speaker terminal and unscrew the three screws to remove the door speaker.
https://i.imgur.com/CkdTEp7.jpg
Hereís the interior door skin with the door panel removed.
https://i.imgur.com/m4xmYtt.jpg
Before you can remove the weather barrier, youíll need to remove the harness anchors and unplug the terminal plugs.
https://i.imgur.com/lRiwfl7.jpg
https://i.imgur.com/oQMCf6b.jpg
https://i.imgur.com/BXgdD6Y.jpg
https://i.imgur.com/TtyOFOr.jpg
For most of the anchors, rather than prying from the top, you can reach from behind and pinch the stud closed and it will pop out the front.
https://i.imgur.com/yKs8u3a.jpg
https://i.imgur.com/E3Xtf2k.jpg
Old 11-20-2018, 01:07 AM   #12
atbwrx
Member#: 447001
2014 WRX
With all of the terminals unplugged and anchors removed, you can then pull off the weather barrier. Take a minute and mark all of the holes that something plugged in to, and where the harness came through the large openings in the door. You’ll need to refer to this pic later to know where the holes are once the door is covered with sound deadening.
https://i.imgur.com/8aAtkaE.jpg
So I wasn’t planning on going totally nuts with the sound deadening. Too much work, and, I don’t like the idea of putting so much weight into the car. The Ballistic Door Kit comes with six sheets of sound deadening, which is enough to do two interior door skins, but I wanted to do a half a sheet on each outer door skin so I bought two boxes. I may use the left over 5 sheets from the second box for the hatch floor. Instructions say to thoroughly clean the surface, so I put a spray bottle attachment on some rubbing alcohol and sprayed the lower portion of the outer door skin, and wiped with a shop towel.
https://i.imgur.com/q8VqDWt.jpg
Roll the sound deadening material into a “U” shape so it can be fed through the speaker hole.
https://i.imgur.com/707en7y.jpg
Peel off the paper backing and feed through the speaker hole. Because it is sticky, its easier if you reach through the opening to the right and keep the deadening from touching anything as you pull through with the right hand and push through with the left.
https://i.imgur.com/hYAMq5d.jpg
Press the sound deadening into place, then use a heat gun to heat it up and then roll it flat with a roller.
https://i.imgur.com/YISot26.jpg
https://i.imgur.com/37BsMmb.jpg
To cut the sound deadening for the inner door skin, layout out three sheets (two horizontal and one vertical) and lay the weather barrier over it as a pattern. Make sure that if your sound deadening is laying “sticky side” down, that your weather barrier has the same orientation ("sticky side" down) so you don’t end up cutting out a mirror image. I laid the speaker down in the general area of where it is located on the door, as a reminder to not cut out that portion of the sound deadening since unlike the weather barrier, the sound deadening will be extending over the speaker hole.
https://i.imgur.com/WV5nxPe.jpg
The front vertical piece of deadening material has to be cut to fit, you won’t use the vapor barrier as a pattern because the deadening material has to go beyond the reach of the weather barrier.
I pushed all the wiring harnesses into the door so they would be out of the way when measuring/applying the sound deadening material.
https://i.imgur.com/B11KBwQ.jpg
I then held up the vertical piece of deadening material and determined where I wanted the leading edge. You can see in this pic that the butyl tape residue from the weather barrier goes right along the edge of the top door opening, but when I measured where to have the edge of the sound deadening, I pulled it about an inch further to the left giving the deadening that much more contact area with the inner door skin.
https://i.imgur.com/jCCoU0t.jpg
Here’s the ultimate shape I made for the front piece of sound deadening.
https://i.imgur.com/U2KODcT.jpg
Old 11-20-2018, 01:52 AM   #13
atbwrx
Member#: 447001
2014 WRX
I marked along the edge of these two opening where the wiring harness came through.
https://i.imgur.com/it66qYp.jpg
I cut a flap over where I indicated the harness came through the weather barrier on the left hole, and pulled the harness through.
https://i.imgur.com/aTFkW3L.jpg
I then pulled the backing off and stuck the front piece of sound deadening against the front part of the inner door skin.
https://i.imgur.com/GiuxlZy.jpg
And then cut a flap over where I indicated on the door that the harness went back through the weather barrier.
https://i.imgur.com/p3cN0Mm.jpg
I then cut out the speaker opening using the pie cut method, and then folded the deadening material onto the back of the speaker opening.
https://i.imgur.com/zLrCqAZ.jpg
https://i.imgur.com/kYJV7W8.jpg
Cut out the remainder of the sound deadening material using the weather barrier as a pattern.
https://i.imgur.com/FtQ22z6.jpg
Hang the top piece of sound deadening and, referring back to that pic where I marked all the holes that are used and where wires came through the door, I cut a slit where I indicated the door cables came through the weather barrier.
https://i.imgur.com/rHl4Bos.jpg
Apply the bottom piece of sound deadening, and use the heat gun and roller to smooth it all out.
https://i.imgur.com/tlwAfzh.jpg
Mount and plug in the Kicker door speaker.
https://i.imgur.com/zx57JSf.jpg
Old 11-21-2018, 03:21 AM   #14
atbwrx
Member#: 447001
2014 WRX
Use the heat gun and the roller and roll out all of the sound deadening.
Refer back to the pic where you marked all of the holes on the inner door skin that had anchors plugged in, and use a dental pic to poke through the sound deadening and open up the holes. You can then rehang all of the wiring back onto the door and re-plug all of the wire terminals.
https://i.imgur.com/X1iolYk.jpg
Before putting the door panel back on the door, use electrical tape to prevent the mounting pegs from rattling in the panel. Fold the tape length-wise and cut a slit. Then insert the tape into the door panel mount, sticky side facing in, with the slit going horizontally across the opening. Then pop in the peg. The tape will cover the top and bottom surface of the mount and hold the peg in place.
https://i.imgur.com/mjGbZmg.jpg
Before snapping the door panel back onto the door, make sure to pull the armrest wiring harness through the armrest opening.
https://i.imgur.com/yItctuo.jpg
Use a dental pic to open the holes for the two mounting screws under the armrest and install.
https://i.imgur.com/qabTQKh.jpg
You can then plug in the armrest window/lock controls, and pop the armrest control panel back into place. Install the mounting screw that holds down the arm rest and the mounting screw under the door pull.
Re-install the tweeter sail panel, and the doors are done.
Old 12-18-2018, 07:33 PM   #15
atbwrx
Member#: 447001
2014 WRX
Installing / Wiring subwoofer.
Picking up where my prior post left off with the OEM subwoofer harness having been feed from the dash cavity down into the driver side footwell.
Zip tie the subwoofer harness to the factory wiring harness that runs under the steering wheel.
https://i.imgur.com/kEfZGk1.jpg
Remove the front doorway trim.
https://i.imgur.com/iymB8rC.jpg
Unscrew the black hold down screw for the front kick panel.
https://i.imgur.com/jyQ64BO.jpg
Remove front kick panel and run the subwoofer harness to the edge of the carpet.
https://i.imgur.com/hjtyn0U.jpg
https://i.imgur.com/CzHMaNs.jpg
Run the harness under the carpet toward the back of the car.
https://i.imgur.com/RGePPoN.jpg
Old 12-18-2018, 07:35 PM   #16
atbwrx
Member#: 447001
2014 WRX
Remove the rear seat, first lift up the center of the lower seat cushion with a firm pull upward.
https://i.imgur.com/Qn6m3Bt.jpg
Undo the latches under each side of the lower seat cushion.
First reach under the rear seat cushion with your thumb, about an inch back from the leading edge of the rear doorway trim.
https://i.imgur.com/ZltxLOA.jpg
Slide your thumb until you feel Ĺ of the ďTĒ handled release and pull your thumb toward the front of the car to actuate the release.
https://i.imgur.com/HjziQ2o.jpg
Hereís a pic of what you should be feeling for under the seat cushion.
https://i.imgur.com/OiZHVLR.jpg
Do the same on the other side and remove the lower seat cushion.
You can then remove the lower rear door trim.
https://i.imgur.com/ksqWh4Y.jpg
Next, remove the B pillar trim. Its easiest to get access by moving the front seat all the way forward, and then sitting in the back seat to remove the trim.
I created some space from the top, and then worked my way down the down the side with a trim tool.
https://i.imgur.com/i0TsLIX.jpg
Lastly, I gave a very hard pull on the bottom and the trim piece came away from the pillar.
https://i.imgur.com/atAxwkA.jpg
Run the harness under the seat belt spool.
https://i.imgur.com/BxBVYzW.jpg
Then under the carpet along the rear door opening.
https://i.imgur.com/BSOm5VN.jpg
Remove the hatch floor coverings, and then remove this rear seat back cover by pulling straight up.
https://i.imgur.com/nWb0WUH.jpg
You can run then run the harness to the hatch area.
Old 12-18-2018, 07:46 PM   #17
atbwrx
Member#: 447001
2014 WRX
It’s now time to install the subwoofer.
Reinstall all of the paneling you removed to run the harness through the cabin of the car, and put the hatch floor back in place. Mine has the factory plastic mud cover, so I re-installed that as well.
Lower the rear seat backs.
The subwoofer is held down by two mounting brackets, install the lower bracket and set the subwoofer onto the driver side (U.S.) of the hatch floor.
The lower mounting bracket will extend down inbetween the two rear seat back halves. If you pull the carpet away, you will see mounting hole. Slide the bracket to the left side of the mounting hole.
https://i.imgur.com/dURkl6l.jpg
Use the provided thumbscrew and secure the subwoofer into place.
https://i.imgur.com/mMjxdSv.jpg
Lock the rear seat backs into the upright position.
Then, position the subwoofer into the desired position. Even with the bottom bracket tightened down, the enclosure will be able to move, so push it back where you want it then scribe into the fender well panel where you’re going to bolt down the top bracket.
https://i.imgur.com/CWYeJdW.jpg
Remove the subwoofer to give yourself room to install the top mounting bracket.
The directions say to use a Ĺ” drill bit and only drill ľ” depth hole. I thought this was strange. I don’t have a Ĺ” drill bit, so before I went out and bought one I ran a small pilot hole. Then I discovered why only a ľ”. The top bracket only mounts to the plastic quarter trim piece, it doesn’t mount to the body of the car. I fed a probe down into the pilot hole, and there is a big space between the plastic quarter trim and the actual metal fender well.
Since I was only going to be drilling through plastic, I used the largest bit I had (3/8”) and reamed it to about Ĺ”.
https://i.imgur.com/1Sa0BAK.jpg
The mounting kit comes with a threaded plug to be put in the hole. To help guide the plug, I inserted the provided mounting bolt part way to use as a handle, and was able to push the plug into the hole.
https://i.imgur.com/DGgXM9v.jpg
https://i.imgur.com/qJ7Bgw2.jpg
I then bolted the top bracket to the plastic quarter panel.
https://i.imgur.com/TacpMGM.jpg
Put the subwoofer back into place and tighten down the top (and bottom) thumb screws to secure into position.
https://i.imgur.com/28nCQ5a.jpg
Plug in the harness and you are ready to thump!
I zip tied the excess wiring together, and leave it under the mud tray. With the rear seat back in up position the wiring is hidden from view.
https://i.imgur.com/RPpjr7f.jpg
Here’s what my completed install looked like.
https://i.imgur.com/7OcACJT.jpg
Old 12-18-2018, 08:15 PM   #18
atbwrx
Member#: 447001
2014 WRX
With the completed sound system fully installed, I'm very happy with the sound.
Stock volume at 30 is about the same as being at 15 now.
The thump of the sub is good, and integrates well with the overall sound. It doesn't put out the kind of bass that will part your hair, but will give a decent kick to your seat back when cranked up.
I do wonder if there is any bass response to be gained in mounting it differently. It doesn't have a firm attachment point to any body panel. On the top, its mounted to the plastic quarter panel. The enclosure itself has four legs, which are sitting on a plastic mud guard, which sits on the lightweight hatch floor insert. It just seems like if were fixed firmly to the body that it would transmit more thump, but maybe that's not how subwoofers work.
I would give this system a 9 out of 10 for daily listening quality. It is missing some mid lows for my tastes (the stock system was the same), and although the sub is great, I don't feel like I have any head room with it and have it maxed out for the sound I want.
A bonus was the relative ease of installation in using mostly factory parts, and even the the installation of the ae46.com break out harness was easy to follow with the excellent instructions. Big shout out to David Carter for his prompt and thorough responses to my newb questions about automotive wiring.
Overall I'd give the Kicker/Alpine combo a big thumbs up!
Old 12-20-2018, 03:52 PM   #19
fosmanc
Member#: 443999
2013 WRX
Plasma Blue Pearl
Great step-by-step instructions! Thinking about doing a new system in my '13 soon and this post definitely shed some light on the entire process.
fosmanc is offline   Reply With Quote
Old 12-21-2018, 05:25 PM   #20
atbwrx
Member#: 447001
2014 WRX
Glad the post was helpful.
You won't regret installing a new system. The best part is my stereo can actually drown out the Perrin Headers and Cobb turboback when I want to just hear the music.
Old 12-10-2019, 03:16 PM   #21
GoFrogs
Member#: 507317
2019 WRX
Pure Red
Thumbs up
Where's a "thank you" button when you need one...oh, right, that is on another forum.
Despite not having a 2018, I still read most of and looked at many of the pictures. thanks for putting this together as I'm sure it will help folks put a future system together or at least give them some tips/tricks when doing the work.
Any rattles to date from the doors? How well is the electrical tape holding up in the door panel clip locations?
Did you feel the need to wrap any of the plastic harnesses with a felt tape or other material to reduce noise?
GoFrogs is offline   Reply With Quote
