#1 |
Member#: 436456
South East
Vehicle:2016 WRX LTD CWP |
![]() I've been doing quite a bit of research into the idea of transplanting a 7" Starlink HU from a 2016 Forester into my 2016 WRX. As has been discussed many times, the 6.2" unit is woefully inadequate.
I found a good price on a Forester unit, so I pulled the trigger and installed this weekend. Mechanically it is a perfect fit. Functionally, there are a few things to iron out: 1. USB doesn't seem to be working. The HU has a USB source feature, but it's greyed out. The connector on the rear of the unit is identical to the 6.2 unit. It may be wired differently (doubtful) or the 7" HU is expecting to detect a 2 port USB hub and not the single port in the WRX. I think the Foresters have 2 USB ports instead of one in the armrest, but I need to confirm that. UPDATE: SVXdc helped me quite a bit with the USB issue. All that is needed is a two port USB adaptor, which I will source soon. 2. Backup camera isn't working. The wires for the camera are located in the 28 pin connector for 6.2" applications but in the 7" unit they are relocated to a separate 5 pin connector. Its possible I mis-wired something when migrating the wires. Its also possible that the forester uses a different backup camera, although that seems less likely. UPDATE: This was indeed a mis-wire related issue. Camera now works, and the HU "maintainence" mode allows for on-screen guide line customization. Everything else seems to work perfectly. The 7" units have a much faster UI and do not seem to suffer from the BT connection delays/woes that afflict the 6.2" unit. The steering controls are also much more responsive. Text messaging on-screen notifications are nice. All told this project cost $375 to complete. I'm very pleased with the results. I expect the cost of second hand HUs will drop significantly as time goes on. ![]() ![]()
#2 |
Member#: 422427
RMIC
Vehicle:2015 subaru crystal white pearl |
![]() Nice, it looks good and good job
#3 |
Member#: 405633
NESIC
Vehicle:2015 Premium 4dr Dk gy |
![]() Thanks for this...I'm also pondering swapping out my 6.2 non xm impreza stereo to a 7" unit. So I know I'd have to add in the xm antenna but other than that... Pretty straight forward you're saying?
#4 |
Member#: 435405
SCIC
Vehicle:2016 WRX Limited WRB |
![]() Is the 7" unit made by Clarion also?
#5 | |
Member#: 436456
South East
![]() Quote:
It's important to note that this unit came out of a 16 Forester Premium. That's significant because it's the non-nav, non-HK 7" unit. The HK units will be much more difficult (perhaps even cost prohibitive) to integrate because they require the HK amp to work properly. My unit has FF667UM on the faceplate. This model is also easy to spot because it has a blank where the NAV SD card slot is supposed to be. |
#6 |
Member#: 436456
South East
![]() It's 90% plug and play. The backup camera wires need to be moved from one connector to a new one, the hard to find 5 pin connector that isn't on the 6.2 harness. Other than that it is a pin for pin, connector for connector match. I need to buy a two port USB AUX plate too. As I said the USB function isn't working atm.
#7 |
Member#: 436456
South East
#8 |
Member#: 14900
Vehicle:2016 WRX Limited LBP |
![]() Might have to pull the HU and check the pins on the USB connector. That connector is a terrible design, and the pins are easy to bend without realizing it.
Looks like another good option for the 2016 crowd! |
#9 |
Member#: 435405
SCIC
![]() It's an awesome option, all you have to do is find a HU from a 2016 Forester Premium.
#10 |
Member#: 436456
South East
![]() There is a 7" Impreza Starlink unit on eBay as we speak. Not affiliated with the seller, except it's the same chap I bought my Forester unit from.
#11 |
Member#: 425154
W. Canada
Vehicle:2016 WRX Sport Lapis Blue Pearl |
![]() Going along the same idea, would getting a JDM WRX head unit work? I got a brochure two years ago which listed head units for the Levorg and new WRX.
#12 |
Member#: 394477
Vehicle:2016 WRX Limited CWP |
![]() this looks good but damn wish there was a PnP alternative to the 6.2" bluetooth problems.. I have to close my spotify app my phone connects to the car which takes what feels like an eternity after starting the car. and from time to time, the quality cuts in and out. dont even know how subaru put out such a terrible head unit..
#13 | |
Member#: 436456
South East
![]() Quote:
Unfortunately this is about as PnP as you're gonna when it comes to switching out a HU. My experience with the 6.2" was identical. It is absolute garbage. The "insufficient network connectivity" Pandora message would drive me into fits of homicidal rage. What I don't get is why Subaru puts the 7" unit I have in a low trim Forester but won't put the same unit in a WRX Limited as standard equipment. I can't stress enough how much better this unit is than the 6.2", it's night and day. The only thing I'm not in love with is the white knob/button backlighting, which doesn't match the red WRX motif. |
#14 |
Member#: 436456
South East
![]() If anyone knows where to find the 5 pin connector that subaru uses for the 7" Starlink units, please let me know. I've been trying to find that sucker for a while now without success.
#15 | |
Member#: 54390
Vehicle:2016 Sti w/nav CWP |
![]() Quote:
Couple questions. Since the usb isn't working, I'm guessing you can't hookup an iPod, correct? If you could make a video on what functions work that would be awesome. I had thought about doing what you did but was afraid I'd be throwing away money based on the research I did. Awesome leap of faith man. You give a lot of people hope. Last edited by midwestmonster; 01-30-2016 at 09:05 AM. |
#16 | |
Member#: 436456
South East
![]() Quote:
Navigation controls? Like steering wheel controls? All buttons work as intended, because forester has the same button layout on the steering wheel. So right now everything works except the backup camera and USB. Both of these are easy fixes, it's just a matter of having the right parts. I'm waiting on a connector to come in before fixing the BU camera. Thanks for the positive words. I'll be sure to post an update once everything is working. |
#17 | |
Member#: 436456
South East
![]() Quote:
The dealer was probably thinking you wanted the 7" NAV+HK unit, which would be a huge pain to integrate. I too briefly looked into that unit as an option but quickly dismissed it after learning what would be involved. |
#18 |
Member#: 54390
![]() Yeah I didn't know there was a non navigation 7" unit.
#19 |
Member#: 427273
Vehicle:2016 WRX Limited |
![]() great job, do you happen to have any pictures of the back of this unit? Considering this as well...
#20 | |
Member#: 436456
South East
![]() Quote:
Absolutely. When this job is finished - hopefully by next weekend when my parts arrive - I'm going to put together a more thorough post, including pictures. As far as the "great job", it really is super easy to do so I can't take credit for much of anything ![]() |
#21 |
Member#: 427273
![]() thanks! appreciate it!
#22 |
Member#: 61296
#23 |
Member#: 332561
Vehicle:2015 GTI Autobahn White |
![]() Sorry, I think this is a waste. Just under $400 for still a junk unit. I had the 7" with Nav and HK in my legacy ltd and while better than this, still not worth any money. Easily could have put that money to something better and had real features.
For the record I upgraded my speakers and added an amp because I wanted to stay OEM, so I get it, but this seems crazy. |
#24 |
Member#: 61296
![]() I was able to source one for $150 so they can be had for less than $400. Definitely worth it given the cost.
#25 | |
Member#: 436456
South East
![]() Quote:
