Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 05-26-2016, 01:50 PM   #51
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Could this be done with a 2012-2014? I think the wiring would be the same, you'd also need the new top center vent piece. My big concern would be the mounting bracket locations. Has anyone done this? Is there a thread about it?
foghelmut is offline   Reply With Quote
Old 05-27-2016, 11:11 PM   #52
Brown1428
Member#: 436456
2016 WRX LTD
CWP
Originally Posted by whiplash willy View Post
I ran across an Ebay Post for the FF667UM unit from a 2016 Forester. There were some decent pics of the units label and rear that might help some of you that want to swap.
I am curious if the backup camera feed will be choppy on this unit as it is on the 6.2. I would love to know once you figure out how to get it working!
This is the exact unit I purchased.
Brown1428 is offline   Reply With Quote
Old 05-27-2016, 11:13 PM   #53
Brown1428
Member#: 436456
2016 WRX LTD
CWP
Originally Posted by intence01 View Post
+1 on the 5 pin harness, is it easily available?
How's the sound quality compared to the Clarion unit?
I never could find it, so I had to improvise. A couple folks had harnesses made, which is definitely the way to go as long as that 5 pin housing remains elusive.
Old 06-01-2016, 08:21 PM   #54
intence01
Member#: 389409
2017 STI
WRB, '15 DGM WRX RIP.
Who made the harness, auto harness house or svxdc?
intence01 is offline   Reply With Quote
Old 06-01-2016, 08:25 PM   #55
rixcross
Member#: 424260
Brian at auto harness
rixcross is offline   Reply With Quote
Old 06-01-2016, 08:37 PM   #56
intence01
Member#: 389409
2017 STI
Thanks,
Reached out to Brian, he's going to need a lot of those.
Old 06-06-2016, 02:43 PM   #57
SoSlo2
Member#: 440579
'16 WRX Limited
I just stumbled upon this thread. I've been looking at options to throw in a 4 or 5 channel amp because the 6.2 unit is so stinking underpowered. This, however, might be the answer to my needs. Like others have asked, how does it compare in terms of sound quality to the stock 6.2" non-nav Clarion units in the 16's?
SoSlo2 is offline   Reply With Quote
Old 06-06-2016, 05:45 PM   #58
biserker1
Member#: 427273
2016 WRX Limited
Just picked this unit up and installed. I am also running the OEM Plus system. Just a few observations
This unit is about 10,000 times faster then the clarion 6.2. There is no delay in switching between stations, tracks etc.
The display is much clearer and more vibrant. The backup camera image is also much clearer.
Bluetooth connects instantaneously, downloads recent calls, contacts etc. On screen text messaging, voice recognition, etc.
iPod connects instantaneously, and begins playing directly where it left off. This works with the double USB port (sourced used).
sound - can't comment, running the OEM Plus system so it sounded awesome before the swap and still does sound great. The EQ on the new unit is set up differently.
Installations - Plug and play. The breakout harness is a must to keep the backup camera (Thanks Brian!) It took me longer to install the double usb hub since the wires were so short. The total install took under 1 hr.
I have to say, this unit is night and day compared to the 6.2. This is the unit the car should have come with. It's unbelievable how different the overall experience is with this unit compared to the original.
The total cost was under $225, far less then going aftermarket. All original controls were retained with the addition of the new options now offered in this unit. Overall, i am very happy with the outcome.
biserker1 is offline   Reply With Quote
Old 06-07-2016, 10:26 AM   #59
Nick_L
Member#: 420592
16 WRX Premium CVT
Where is the best place to source one of these units? You guys just checking eBay etc?
Nick_L is offline   Reply With Quote
Old 06-07-2016, 11:42 AM   #60
bji
Member#: 445904
Can someone tell me if there is more than one model of the 6.2 inch head units? I have a 2016 Impreza and from my reading, I believe that there was an improvement to the head units in either the 2015 or 2016 year, not sure which.
What I don't know is, if all of the complaints about speed and finickiness of bluetooth/usb connections were about the pre-2015/2016 versions of these head units, or the 2015/2016 as well. In my experience, while the 6.2 unit in my 2016 Impreza is annoyingly slow to connect to the usb drive on power-on, and similarly for bluetooth, once connected I have zero problems. The steering wheel controls function very quickly for changing volume, pause/play, and skipping forward and backward songs. I haven't used every feature though, so maybe there are some slow ones I missed.
Given the above, I don't know if the 7 inch unit described here would be a noticeable difference, except possibly in start-up times.
Does the 7 inch unit connect immediately on startup to bluetooth sources? Mine takes about 15 seconds.
Does the 7 inch unit connect immediately on startup to usb sources? Mine also takes about 15 seconds.
Those two things are pretty much the only things I find inadequate about the 2016 stock 6.2 head unit.
bji is offline   Reply With Quote
Old 06-07-2016, 12:19 PM   #61
SoSlo2
Member#: 440579
'16 WRX Limited
Can someone please weigh in on sound quality in comparison to the 6.2 unit? Also, I'd like to know if anyone has found another place to source these outside of waiting for them to pop up on eBay. Thanks!!
Old 06-07-2016, 01:35 PM   #62
intence01
Member#: 389409
2017 STI
Sound Quality seems better compared to the Clarion units. I don't have much experience with the 6.2 in the WRX, but did with the Forester, and had the older no-display unit in the '15 WRX.
Sound Quality on these new Fujitsu Ten units seems to be better with stock speakers. I'm sure a speaker upgrade will do wonders, and maybe a powerpak amp as well.
Old 06-07-2016, 03:10 PM   #63
SoSlo2
Member#: 440579
'16 WRX Limited
thanks for the info. I actually ended up stopping by my Subaru dealer today. (perfect weather for a free car wash) I talked with my sales guy and he was able to print off the 2017MY WRX and WRX STI Price Announcement. "The 2017 WRX Limited builds on its already impressive list of standard features with the addition of Subaru STARLINK Connected Services and the 7.0" Multimedia Audio System that incorporates voice activated controls, SiriusXM All Access Radio, SiriusXM Travel Link, Siri Eyes Free and MirrorLink, the leading industry standard for car-smartphone connectivity."
I was also able to sit in a 2016 Forester Premium and confirm that the interface is 100x better than on the 6.2" display. Audio quality also seemed better but we did not go on a test drive so I could not get the full experience there.
Old 06-07-2016, 07:58 PM   #64
Brown1428
Member#: 436456
2016 WRX LTD
CWP
I think the sound quality is marginally better, but if you're looking for a significant improvement you'll be better served going with another HU and/or upgraded speakers.
Old 06-07-2016, 08:01 PM   #65
Brown1428
Member#: 436456
2016 WRX LTD
CWP
Careful of the dealer car washes...the only swirls in my paint are from them
I'll be keeping an eye on the 2017 Starlink offerings. Was really hoping for CarPlay in the WRX, Crosstrek, or Forester but it looks like that isn't happening.
Old 06-07-2016, 11:05 PM   #66
biserker1
Member#: 427273
2016 WRX Limited
Default 2016 Forester to WRX HU Transplant...
Looks like mirror link is an option on these units but not supported by the iPhone.
Old 06-21-2016, 03:19 PM   #67
rixcross
Member#: 424260
I just plugged mine all together. All functions work except ipod usb. I get power from the splitter cable in the arm rest, but the ipod isn't identified on the radio. Did I not push a connector in fully on the back of the radio, or do I only get bluetooth from now on?
Old 06-22-2016, 11:23 AM   #68
biserker1
Member#: 427273
2016 WRX Limited
You either need to purchase a splitter (read a few posts back) or the dual USB port that comes standards on the forester.
Old 06-22-2016, 11:41 AM   #69
rixcross
Member#: 424260
Thx, I do have the splitter. Last night, I pulled the radio out and I did, in fact, forget to plug in the black square connector on the back of the radio. The radio was already powered thru the other connections so I just pushed it in. Unfortunately, it still doesn't recognize the USB in the armrest wtih the splitter plugged in with an iphone connected. I'm wondering if I have to power cycle the radio (pull the battery) to force the radio to reset and re-identify the connector. Thoughts?
Old 06-22-2016, 12:13 PM   #70
SoSlo2
Member#: 440579
'16 WRX Limited
Where are you guys finding these HU's? I've searched ebay over the past few weeks without much luck other than one out of a 2015 Impreza with a BIN of $750! No thanks..
Old 06-22-2016, 12:15 PM   #71
bjcolli1
Member#: 432828
Originally Posted by biserker1 View Post
I have a unit on the way. I am also running the OEM plus system which should just be a direct replacement. I reached out to them and have not heard back yet.
Did you hear back from OEM plus?
Just picked up the OEM plus system, but it would still be nice to have the faster working head unit.
Anyone know when I can source one of these for a reasonable price?
bjcolli1 is offline   Reply With Quote
Old 06-22-2016, 12:44 PM   #72
rixcross
Member#: 424260
SoSlo2 - I checked fleabay for "subaru starlink" and "2016 forester radio". 2015 and 2016 years were intemixed with new vs old style radios on the Forester, Crosstrek, and WRX. As far as I know, WRX and Crosstrek didn't come with a 7" non-nav radio or at least it wasn't very popular in those years. Mine came out of a wrecked Forester.
Old 06-22-2016, 01:06 PM   #73
biserker1
Member#: 427273
2016 WRX Limited
I didn't hear back from OEM. I plugged everything in and it works great. I imagine everything is the same as Subaru wouldn't run different harnesses between their vehicles, other then the HK systems.
Sounds the same.
Old 06-22-2016, 01:07 PM   #74
biserker1
Member#: 427273
2016 WRX Limited
It's worth a shot. That connector for the USB is really cheap. I know some people on the forum had issues with bent pins after pulling and reinserting the plug.
Old 06-23-2016, 08:11 AM   #75
rixcross
Member#: 424260
Pulled the whole radio out and checked the USB pins. Nothing bent and the connector locks in when re-inserted. I pulled the battery terminal to force a reboot of the system and that didn't work. The radio must have some internal battery or it stores settings as it remembered my phone connections and radio stations still. Couldn't find anywhere to reset to factory settings, only the default button which only resets check boxes under system settings. Anyone have any other ideas?
