Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 10-28-2017, 11:18 AM   #1
Bigfx
Member#: 475679
Default Easy place to tap front speakers for a sub 2018 wrx base audio?
Hey Guys
Looking to just add an amp and a sub to my 18 wrx with base stereo, I really don’t want to pull the head unit bc it’s looks like a pita. Is there an easy place to just wire tap the front or rear speakers for an loc?
Bigfx is offline   Reply With Quote
Old 10-30-2017, 09:03 AM   #2
drewleague
Member#: 474642
Originally Posted by Bigfx View Post
Hey Guys
Pulling the headunit is really not that bad, all the speakers are in the door so I don't know how much easier they would be to tap. It took me 20 minutes to get the radio out
drewleague is offline   Reply With Quote
Old 10-30-2017, 12:51 PM   #3
phd12v
Member#: 432497
18 Sti
ISM
i did a video on youtube which shows how to pull the radio out....i did it one handed and some people were not liking the nonprofessional filming of it...... but i tried to make it as easy as possible to understand. I can have the radio out in about 8 minutes tops at this point....mine has been out so many friggin times already now. LOL
phd12v is offline   Reply With Quote
Old 11-01-2017, 09:11 PM   #4
NONZILLA
Member#: 477028
I'm fairly certain it's an easy task. The headunit is just hiding behind some plastic trim that snaps out, and a couple 10mm bolts. I would recommend doing it this way, it'll be the route with the least amount of problems.
NONZILLA is offline   Reply With Quote
Old 11-04-2017, 08:23 PM   #5
Bigfx
Member#: 475679
Can you link the video?
Old 11-04-2017, 08:28 PM   #6
Bigfx
Member#: 475679
Never mind I found it, I hate the airbag part.
Old 12-05-2017, 02:56 PM   #7
m3incorp
Member#: 478467
2018 WRX
Dark Gray Metallic
The head unit isn't that hard to remove but of course you have a long run of wire. The rear door panels come off in about 2 minutes and allow easy access for tapping into the speaker wire there and then a short wire run to your LOC or high/speaker level input equipped amplifier (Many amplifiers now offer this connection). Of course you would still have to run a wire to trigger the amp remote turn-on. IF ONLY ADDING A SUBWOOFER, I prefer just tapping into the rear speaker wires and not having to add a harness to the OEM radio or splicing into wires in a constrained area.
m3incorp is offline   Reply With Quote
Old 04-19-2018, 08:33 PM   #8
dricacho
Member#: 484614
2018 WRX Premium
I'd like to do the same on my 2018 WRX premium with 7" Starlink headunit. I read somewhere that this headunit somehow attenuates the bass frequencies from the rear speakers so they don't distort. So does this mean that it's ideal to tap off of the front speaker wires to connect a line level converter for a sub amp?
Also is this the correct speaker pin-outs for the 2018 7" Starlink headunit?
Click on link to see photo:
https://photos.app.goo.gl/n0VRRdB8NIG4uhJ92
dricacho is offline   Reply With Quote
Old 04-25-2018, 02:23 PM   #9
Jolty_eoN
Member#: 485159
Hey dricacho, that link didn't show a picture. In general, the rear speakers are factory tuned to be more likely to provide a wider range of bass frequencies than the fronts. If, however, your system is indeed built to cut the bass frequencies and there's no setting in the HU to allow a full-range of audio signal to the rears, I would definitely hook your LOC up to your fronts. If you run everything and discover there's not much signal getting to your sub, just tag the rear speaker wires instead of fronts behind radio. Easy fix.
Jolty_eoN is offline   Reply With Quote
Old 04-25-2018, 02:48 PM   #10
ontariotibv6
Member#: 306336
16 WRX
ISM
Just wanted to confirm about the front vs rear speakers for information sake. I have the base 6.2 starlink and added a sub and amp only. I first tried tapping the rear speakers for the LOC because it seemed like the easiest location to get to. There was a lot of low frequency missing from the signal to the amp/sub this way so I tried the front speakers for the LOC instead and received the full bass range back, much better sound.
If you have the 6.2 HU, definately use the fronts! As for the 7" im not really sure if this is the case or not.
ontariotibv6 is offline   Reply With Quote
Old 04-25-2018, 04:15 PM   #11
BHOD
Member#: 463264
2018 WRX sport, 6MT
crystal BLACK silica
Same here. Front signal feed the SUB
What I've done also, with Y rca cable, is to feed my Alpine 4x100 PDX-F4 with only the front signal as well. My rear Morel are sounding better.
I slightly use the gain to bias a little bit toward the front.
I have my NEX-4200 waiting to be installed since last fall. I received all the goodies too late and I missed time to do the installation before cold temperature coming.
I will then unplug the Y rca cable
BHOD is offline   Reply With Quote
Old 04-25-2018, 10:33 PM   #12
Jolty_eoN
Member#: 485159
man that is super weird. is it only 16-18 Imprezas with starlink that cut the bass to the rears...anyone know?
Old 04-26-2018, 12:16 AM   #13
BHOD
Member#: 463264
2018 WRX sport, 6MT
SVXdc told me that Clarion HU used to do that...
Old 04-27-2018, 04:18 PM   #14
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
To elaborate: All of the model year 2008-2015 Subaru non-navigation HUs in WRX, STi, and Forester; and MY 2008-2014 Impreza and Crosstrek were made by Clarion and have that issue (they attenuate bass frequencies sent to the rear channels). In all of those HUs, there are secret/hidden menus you can use to flatten the EQ. See this thread and this thread. That 2nd thread has some great pics with frequency response curves.
The 6.2" OEM HUs in 2016-2018 WRX, STi, and Forester are still made by Clarion. So it's no surprise those still have that issue. There's a good chance that they have a similar hidden menu option to flatten the EQ, but I haven't heard from anybody who has found it yet.
The recent OEM 7" HU models (and the 2012-2015 navigation models) are made by Fujitsu Ten. I don't know if any of those have the same issue.
It would be nice if someone could make similar EQ plots for some of these newer models.
SVXdc is offline   Reply With Quote
Old 04-27-2018, 05:04 PM   #15
phd12v
Member#: 432497
18 Sti
ISM
https://photos.app.goo.gl/wJnKtJTkYSCzvNil1
Old 04-27-2018, 05:05 PM   #16
phd12v
Member#: 432497
18 Sti
ISM
Front left at half volume, full volume on woofer and tweeter
also of note: 2 volt difference between Left and Right, right being the side with more voltage.
Subaru with Starlink - grab front signal AFTER Starlink box below radio. Front speaker passes through the box.
ADDED: wiring diagrams for starlink 7" unit without amp to the album
