11-06-2017, 06:19 PM | #1 |
Member#: 466919
Help with two issues
First, I need help resetting the clock to the current time. I have 27 Sport.
Second, the mileage indicator keeps jumping between different numbers and won't settle down
11-06-2017, 07:20 PM | #2 |
moon moon
Moderator Member#: 86213
NWIC
What mileage indicator? If it's the current mpg one it is garbage and changes every 2 seconds or so based on exact current throttle position and engine load.
11-06-2017, 07:23 PM | #3 |
Member#: 310435
Vehicle:'12 Sport Limited Black - 255,685 miles |
First, Setting the clock in the '12 Impreza has to be the easiest of all the cars I've owned. You just press the + and - button. Does the '17 not have that now?
Second, that's what the mileage indicator is supposed to do, especially if you just reset it. It settles down as the miles accumulate. |
11-06-2017, 07:46 PM | #4 |
Member#: 421858
Vehicle:2012 Impreza |
11-06-2017, 08:01 PM | #5 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
You need to be more specific dude.
On the '12 there are 3 mpg gauges. Current mpg, average mpg, and the + - gauge on the cluster. Current mpg will always jump around unless cruise is on on a consistent grade with no wind(lol) Average will constantly jump around but jumps around slower the more miles you have before resetting. And the + - gauge on the cluster with a needle I believe shows how your current mpg is relative to your average mpg. So if your average mpg is at 30 mpg and you are flooring it up a hill getting 10mpg it will be reading all the way to the - side. If you are coasting downhill your current will be greater than 30 (avg) so it will be at the + |
11-28-2017, 08:54 PM | #6 | |
Member#: 478422
Vehicle:2017 Impreza Sport Black |
