#1 |
Member#: 97069
Vehicle:2016 Impreza Sport Blue |
![]() I'm going over my aftermarket alarm and remote starter installation and have a question about grounding. Almost everything I read says to not use factory ground locations. Well, I ended up grounding mine to a bolt in the drivers side kick panel that has other ground wires running to it.
Now part of me thinks it's OK because it's a good ground. But the other part of me thinks that for some reason, the remote starters/alarms don't want to share the ground. Should I look for something else?
#2 |
Member#: 432497
Vehicle:18 Sti ISM |
![]() i use pin #4 at the obd2 connector
#3 |
Member#: 97069
![]() I don't know, but I think that the OBD2 connector ground isn't the best place. The reason I say this is because a long time ago, I had engine whine from a head unit and amp I installed. Moved it from a ground wire to a bolt and everything was fine.
But if it works....why mess with it. |
#4 |
Member#: 352266
![]() your fine using a factory ground location for your remote start security system. your not really drawing any current for this application.
#5 | |
Member#: 432497
![]() Quote:
#6 |
Member#: 476291
SCIC
Vehicle:2018 WRX White |
![]() I always tap my own ground when doing a remote start/alarm. I dont like using factory ground points.
#7 |
Member#: 432497
