Welcome to the North American Subaru Impreza Owners Club Friday August 17, 2018
Old 12-10-2017, 01:50 PM   #1
Elauder
Member#: 324914
Default 2015 WRX Foglight wired to headlights
I just bought a foglight kit that routes from a relay into the cabin for a switch. I was curious if I use an add a fuse that I could just tap into the headlights so they come on with them. Has anyone tried this?
Elauder is offline   Reply With Quote
Old 12-10-2017, 02:21 PM   #2
EricP350
Member#: 468253
Should work. Relay power on feed current is low, 1A.
EricP350 is offline   Reply With Quote
Old 12-10-2017, 08:22 PM   #3
Elauder
Member#: 324914
Ok I figured it should. Not sure if Iíll do that or just use the switch.
Old 12-10-2017, 08:51 PM   #4
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Or you could get a switch that is always off/on not one that resets to off after restart.
On the 2012 it's like that I just leave the fog light switch on all the time in the winter so when I turn my lights on they always come on too.
DieselDorf is offline   Reply With Quote
Old 12-11-2017, 08:49 AM   #5
Elauder
Member#: 324914
Very true. Biggest reason I donít want to do the switch is because I would never use them without the headlights and the color of the light in it doesnít match the rest of my cars lights l.
Old 12-11-2017, 06:12 PM   #6
Elauder
Member#: 324914
I can confirm that this works and saves the trouble of wiring through the firewall and using a switch.
