02-07-2019, 12:12 AM | #3551 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
I pulled out my EJ25D and put in the EZ30D without ever moving the 6MT (which has a 4EAT driveshaft behind it). What specifically is not working on yours? What brace to what frame? What is stuck in one position?
02-07-2019, 12:27 AM | #3552 | |
Member#: 480045
South East
Vehicle:2009 3.0L Impreza Dark grey/light black? |
https://photos.app.goo.gl/znP1avgTRNrHBPV66 The shifter is attached to two rods, one rod(lower) is bolted to a fixed mount on the transmission and to the chassis rear of the opening in the tunnel that the shifter sticks up through. Last edited by Kito818; 02-07-2019 at 01:20 AM. |
02-07-2019, 12:52 AM | #3553 |
Member#: 480045
South East
https://photos.app.goo.gl/5FyqaL5mZh1oDWQVA 98 RS
https://photos.app.goo.gl/c5xS4JhjBQdw1FBg8 03 STI https://photos.app.goo.gl/iz8fq8XvXAxS9Lgk7 09 WRX Guess I should have looked at this first. I would be really surprised to find out the distance between the end of the transmission and the differential had not changed even though the length of the cars has stretched 8 inches. Guess I'm looking for an 08-14 6MT driveshaft. Last edited by Kito818; 02-07-2019 at 11:21 AM. |
02-07-2019, 12:58 AM | #3554 |
Member#: 480045
South East
Curiosity, again, because I like to think of stupid things, what would happen if I made a block to makeup the distance between the differential and the driveshat, then got longer bolts that ran through the driveshaft holes, the block, and then a nut after the differential holes? Would the longer bolts flex too much, or snap from torque? Or would it hold together? for a week or so while a driveshaft was shipped? I'm not running any boost, and I'll be breaking in new head gaskets and clutch so its not like I'm going to get crazy leaving the line or anything.
02-07-2019, 03:06 PM | #3555 |
Member#: 480045
South East
https://photos.app.goo.gl/CVXzsvRHsvvEUMox8
that would be the brace/mount I was referencing, HOWEVER, while I noticed the issue after bolting that to the chassis, it was unrelated. This is the CORRECT orientation of the shifter, https://photos.app.goo.gl/ez27VuE5mePqonyj7 This is the INCORRECT orientation of the shifter, https://photos.app.goo.gl/QMacEArz5oe6PWVN7 I couldnt even reassemble it the way it was before, thats why the bolt was partially out, I tried to restage it for the picture. Needless to say fixed the shifting issue, found a driveshaft shop in town(ish), I'm sure they're going to kill me on price, but I'll hopefully have one sometime tomorrow, as well as the exhaust, which I have some interesting hopes and dreams about. Anyway, I'm going to put the tranny mounts back on and get the last few wires done, a fuel line, and bleed the clutch so I can start the car in a few hours. |
02-07-2019, 05:18 PM | #3556 | ||
Member#: 120
AKIC
'98 2.5RS - 99.2" '03 (?) STi - 99.4" (for a WRX, since we didn't have an STI here in '03). In 2004, the STI's wheelbase was 100" vs the WRX's 99.4", but the difference was all in the STI's caster-adding front control arms, which push the front wheels forward. '09 Impreza - 103.1" Or a vastly more common 4EAT driveshaft from an Impreza that is the same chassis/generation. I guess I should have explicitly stated that a couple of months ago when I said to get a 4EAT driveshaft from an Impreza - the Impreza has changed over time, so you need to have one from your chassis. |
02-07-2019, 06:04 PM | #3557 | |
Member#: 480045
South East
02-08-2019, 01:04 AM | #3558 |
Member#: 86559
BAIC
Vehicle:2005 RS Wagon |
Does anyone make A/C Compressor deletes for the EZ30? Also, with 6MT, do I use clutch/flywheel setup from 6MT/STi?
Thanks |
02-08-2019, 04:57 AM | #3559 |
Member#: 480045
South East
A/C delete I dont know about, however YES STI CLUTCH/FLYWHEEL!!! Do not try to buy a "Legacy clutch" you'll get a 5MT one, same with "Subaru 3.0 clutch", but you're looking for the STI clutch kit with a flywheel that has 9 mountains around the clutch surface, if its a flat flywheel its the 5MT clutch kit. If you don't need the flywheel you can get a basic clutch kit, pull-out barring, pilot barring, clutch, and preasure plate for about 85$, I THINK the same kit with a flywheel is 150$ but not sure.
02-08-2019, 05:32 AM | #3560 |
Member#: 480045
South East
damn I really wish this one had been available when I bought mine, complete wire harness and ECU. I could have got the plug-n-play harness for the Haltech, sad day.
02-08-2019, 10:31 AM | #3561 | |
Member#: 86559
BAIC
02-08-2019, 10:46 AM | #3562 |
Member#: 480045
South East
02-08-2019, 11:06 AM | #3563 | |||
Member#: 120
AKIC
That cars101 site shows the 4EAT continuing until the CVT was used across the board in 2014, so the '10 4EAT driveshaft should be correct. Thats a head-scratcher! Quote:
I've never seen an actual A/C delete. Many (most?) EZ30 swaps are running without A/C, so I'm guessing it can be done without a delete. I haven't paid much attention to how folks are routing the belts, but I'm guessing it's like this: The C/B/A part of the belt routing is normal, then straight across from A to F, down past E and back to C. I'm not sure you really need to leave the idler pulley (E) in there, but it looks like keeping the idler gives a little bit better belt wrap around the alternator pulley. |
02-08-2019, 11:32 AM | #3564 | |
Member#: 480045
South East
02-08-2019, 12:32 PM | #3565 | |
Member#: 120
AKIC
02-08-2019, 04:26 PM | #3566 |
Member#: 480045
South East
Does anyone know what the length of the diferential is from the bolt holes to the nose? I dont know, so I'm asking is there a difference in the length of the 5MT and 6MT differential?
02-09-2019, 01:10 AM | #3567 | |
Member#: 86559
BAIC
02-09-2019, 07:39 PM | #3568 | |
Member#: 120
AKIC
R180 on the left, R160 on the right |
02-09-2019, 09:28 PM | #3569 |
Member#: 480045
South East
damn, I was wondering if maybe there was a difference and thats why the driveshaft didn't reach, but oh well.
02-10-2019, 04:32 AM | #3570 |
Member#: 158864
Vehicle:2003 SOHC destroker |
the driveshafts are to suit the gearbox, not the diff. you just change the yoke.
i ran the a/c delete as pictured. |
02-13-2019, 07:25 PM | #3571 |
Member#: 480045
South East
https://photos.app.goo.gl/1AqbFeQ1Qh5UJk7v8
It is not all doom and gloom in the 08+ world, first gen EZ30D radiators WITH FANS fit. Only downside(not really?) is I had to drill new holes for the mounting brackets(which came from my 09 Impreza. I dont know if the 08+ has more room in the engine bay, or if this radiator and fan setup would fit earlier generations, but I thought I would try and contribute some more. |
02-13-2019, 07:27 PM | #3572 |
Member#: 290509
Vehicle:2000 Impreza |
I used a 2008 radiator with mine, I made a cross pipe to adapt it.
02-13-2019, 07:29 PM | #3573 |
Member#: 480045
South East
02-13-2019, 07:30 PM | #3574 |
Member#: 290509
It's an ez30r on an arm infinity
02-13-2019, 07:30 PM | #3575 |
Member#: 290509
Aem infinity
Vag-Com cable resource thread | cooleys04 | Open Source Reflashes | 284 | 04-30-2023 03:13 AM |
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! | Upscale_Automotive | Member's Car Gallery | 8 | 10-03-2007 04:56 AM |
The 2008 Impreza Photoshop thread...post them here | adizon | Member's Car Gallery | 307 | 09-19-2007 11:36 PM |
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) | wrxpeed | News & Rumors | 938 | 05-16-2005 11:11 PM |
Photo - Anders "loving on" the H6 Impreza | Fred | South East Region Forum | 8 | 02-23-2004 05:04 PM |
