Welcome to the North American Subaru Impreza Owners Club Tuesday December 7, 2021
Old 07-01-2021, 08:12 PM   #1951
De36
Member#: 475437
2018 WRX
Originally Posted by basyager View Post
You mean the fluid overheats cuz calipers can't dissipate the heat? If so, wouldnt it have to start boiling to have an effect? I just dont understand how calipers can overheat. Theyre just pieces of iron
Larger calipers & rotors = more mass = more heat (aka thermal energy) absorption. Which means the pad can take more thermal energy & stay cooler longer. Pads have a working-heat range that they have to stay within. Above this working heat range will cause brake fade.
Cooling comes from things like ducts, rotor fins, etc... You can use thermal paint to determine cooling: LINK
Fluid boiling is a function of fluid type (e.g. Motul 600 vs 660). Which causes a spongy pedal.
Hope I explained that clearly...
De36 is offline   Reply With Quote
Old 08-06-2021, 10:51 PM   #1952
milkywitness
Member#: 522156
Helps me at least lol
milkywitness is offline   Reply With Quote
