Welcome to the North American Subaru Impreza Owners Club Wednesday December 1, 2021
Old 10-08-2021, 04:15 PM   #1
geezersmk
Member#: 282228
2011 STI Limited
Angry Bought STI w/ Fake STI Motor from dealership (legal advice)
On June 1st I purchased a 2011 Subaru STI with 40,000 miles from a dealership here in San Diego California. The check engine light came on the second day of ownership. In my DIY spirit I tried to fix all the problems myself. Fast forward a few months and no luck fixing my error codes I had the car towed to a Subaru Specialist here in SoCal. Here is what the mechanic is telling me.....
My car has a non turbo 2.5 EJ small block with STI everything else... hence the "Fake STI" in the title. I thought I was purchasing an STI and what I bought is not that. The mechanic says that the car would not/could not pass smog due to its compression rate so the only way to fix my check engine codes is to replace the small block. I've been quoted between $6,000-$7,000 to make this happen.
My question is, am I screwed? Do I have any recourse? I have not confronted the dealership yet and am curious if there is anything I could even do. CA Lemon Law? BAR (Bureau of Automotive Repair)? I've owned the car since June 1st and have only put a few hundred miles on the car. The car does not run anymore. Any idea's or help would be great.
geezersmk is offline   Reply With Quote
Old 10-08-2021, 04:26 PM   #2
K3rm1tth3fr0g
Member#: 508105
2002 WRX - Link ECU
being installed :)
Are you sure it's a non turbo block?
K3rm1tth3fr0g is online now   Reply With Quote
Old 10-08-2021, 04:32 PM   #3
geezersmk
Member#: 282228
2011 STI Limited
No - the Subaru Specialist could not tell me what it was, and Steve Johnson (subaru motor guy here in SoCal) thinks its a 2.5L non turbo small block.
I have not had the engine taken out to document but they have all confirmed its not an STI small block.
Old 10-08-2021, 04:32 PM   #4
vanman23
Member#: 519102
Does your title say itís an sti? If it does, I canít imagine a non turbo engine would run on your ecu.
vanman23 is offline   Reply With Quote
Old 10-08-2021, 04:39 PM   #5
K3rm1tth3fr0g
Member#: 508105
2002 WRX - Link ECU
being installed :)
Hmm that seems odd that he can't tell which block it is.
Did it run well when it was running?
Old 10-08-2021, 04:40 PM   #6
geezersmk
Member#: 282228
2011 STI Limited
No not really - check engine lights from the start of ownership, noticed it would not boost past 7PSI, and just felt slow generally. Then car broke down and now does not drive.
I've driven the miles maybe 500 miles since I purchased the car.
Old 10-08-2021, 04:45 PM   #7
designfate
Member#: 114502
Lawyer up instantly and watch how fast that dealership fixes its mistake.
designfate is offline   Reply With Quote
Old 10-08-2021, 05:34 PM   #8
Jedi03
Member#: 491095
2009 STi Blue
lemon law?
Jedi03 is offline   Reply With Quote
Old 10-08-2021, 05:47 PM   #9
xtremewlr
Member#: 525652
2006 STI
WR Blue
Originally Posted by Jedi03 View Post
lemon law?
This. Look up CA Lemon Law.
xtremewlr is offline   Reply With Quote
Old 10-08-2021, 06:59 PM   #10
iexcelr8
Member#: 386732
2019 STI
SBP
Post a picture of the engine bay from a few locations.
iexcelr8 is offline   Reply With Quote
Old 10-08-2021, 07:05 PM   #11
iexcelr8
Member#: 386732
2019 STI
SBP
So it ran like crap when you basically drove it off the lot? And actually boosting..
Something is not right here..
Why did you not bring it back right away?
Old 10-08-2021, 07:06 PM   #12
iexcelr8
Member#: 386732
2019 STI
SBP
Old 10-08-2021, 08:53 PM   #13
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Just what I was thinking...
Why did you buy it?
Dave D. is offline   Reply With Quote
Old 10-08-2021, 08:54 PM   #14
geezersmk
Member#: 282228
2011 STI Limited
The honest truth is I found a low mile STI, in the color and body style I wanted, and I was ready to tackle any DIY that came up, and there was a handful (missing lug nuts, loose screws, cracked tire, etc).
Anyways I got the car I wanted and was willing to sacrifice a little elbow grease for it.
I'll work on getting some images uploaded shortly.
Old 10-08-2021, 09:19 PM   #15
murrdogg24
Member#: 50586
64 Impala
doesnt the dealership have to provide you with the smog certification as part of the sale? how did it pass when they had it? something doesn't add up....I know someone in San Diego that could help you with the engine if you decide to keep it and it won't cost you near what that "specialist" is saying
murrdogg24 is online now   Reply With Quote
Old 10-08-2021, 09:21 PM   #16
geezersmk
Member#: 282228
2011 STI Limited
https://www.dropbox.com/sh/z65fnpay7...IZKXd23na?dl=0
Here is a dropbox link with a few images of the engine bay - I can take more apart if you think that would be helpful. In one of the images you can see that center breather port and how it connects to my PCV.
Old 10-08-2021, 09:30 PM   #17
geezersmk
Member#: 282228
2011 STI Limited
They did provide a smog certificate # SA482523C and I checked online and it checks out - says it was done on 4/27/2021 with 40,967 - it has 42,000 miles now. It does not tell me who performed the smog test.
Old 10-08-2021, 10:39 PM   #18
designfate
Member#: 114502
I would bypass the dealership and contact Subaru of North America directly
Old 10-09-2021, 03:25 AM   #19
moral hazard
Member#: 323759
2010 legacy GT
Out of curiosity, what was the error code?
moral hazard is offline   Reply With Quote
Old 10-09-2021, 07:17 AM   #20
iexcelr8
Member#: 386732
2019 STI
SBP
Clearly it has a turbo in it, intake, pitchstop
Iíll bet you have other issues not related to if it is an Sti. To me it clearly is. What codes are you getting? You mentioned you can only boost to 7 psi. Sounds like boost leak, or your running off wastegate pressure.
Take it to a well known tuner that can check the car over and tune it. Did it come with an access port?
Just trying to help
Old 10-09-2021, 07:19 AM   #21
iexcelr8
Member#: 386732
2019 STI
SBP
Also from your pictures you are missing bolts from the turbo to the down pipeÖ
Old 10-09-2021, 07:31 AM   #22
iexcelr8
Member#: 386732
2019 STI
SBP
Personally I would not trust whom ever told you it didnít have a turbo in it. From your pictures it clearly does. Also has some mods on it that you must be tuned for. Did it come with a Cobb access port? If not your issue is in leaks and tuning. I think whom you took it to was going to screw you on getting a whole new motor.
You need to find a reputable shop, ask on here for some shops that can tell you the truth.
Bring it to a well known Subaru tuner/ shop to go over the car spend some money to get it all fixed to save a bigger expense replacing the motor.
Just my opinionsÖ
Old 10-09-2021, 12:36 PM   #23
austin9888
Member#: 150974
2008 WRX STi
LRP
I don't think he said "doesn't have a turbo" just a Non Turbo block.
austin9888 is offline   Reply With Quote
Old 10-09-2021, 12:50 PM   #24
murrdogg24
Member#: 50586
64 Impala
you can't even see the block from your terrible pictures
Old 10-09-2021, 03:00 PM   #25
geezersmk
Member#: 282228
2011 STI Limited
I'll try and post better pictures with more parts removed this weekend.
The block is a non turbo according to everybody I've spoken to about it, obviously the car has a turbo.
