Welcome to the North American Subaru Impreza Owners Club Tuesday December 7, 2021
Old 10-09-2021, 03:07 PM   #26
geezersmk
Member#: 282228
2011 STI Limited
Originally Posted by iexcelr8 View Post
Personally I would not trust whom ever told you it didn't have a turbo in it. From your pictures it clearly does. Also has some mods on it that you must be tuned for. Did it come with a Cobb access port? If not your issue is in leaks and tuning. I think whom you took it to was going to screw you on getting a whole new motor.
You need to find a reputable shop, ask on here for some shops that can tell you the truth.
Bring it to a well known Subaru tuner/ shop to go over the car spend some money to get it all fixed to save a bigger expense replacing the motor.
Just my opinions***8230;
I've done a few mods under the hood, including the AP, Cobb SF Intake, Cobb Pitch Stop, Mishomoto Expansion Tank, Cobb AOS (not installed). Trying to put tasteful mods that are street legal in CA.
I just took it to a reputable shop and this is what they are telling me - they can't fix the codes because its not an STI block.
The codes I've been dealing with are below - the secondary air codes came on the second day of ownership followed by the PCV codes soon after. The P0123 started when the car broken down in its current state.
P0123 - Throttle/Pedal Position Sensor (newest code, gas pedal does not engage, I think maybe a throttle body sensor)
P1491 PCV Blow By
P2433 Secondary Air Injection (bank 1)
P2443 Secondary Air Injection (bank 2)
P0410 Secondary Air Injection
geezersmk is offline   Reply With Quote
Old 10-10-2021, 01:32 PM   #27
geezersmk
Member#: 282228
2011 STI Limited
https://www.dropbox.com/s/qan7izutay..._4928.jpg?dl=0
Here is an image of the area in question, does this look stock STI to anybody?
Old 10-10-2021, 01:48 PM   #28
murrdogg24
Member#: 50586
64 Impala
Yeah you definitely got screwed there should be two crankcase breather ports in that area of the block, I only see one there.
murrdogg24 is offline   Reply With Quote
Old 10-10-2021, 02:42 PM   #29
geezersmk
Member#: 282228
2011 STI Limited
The block does read EJ25 on it
Old 10-10-2021, 08:27 PM   #30
SoapBox
Member#: 204578
Contact the dealership, tell them you will be forced to get a lawyer involved if they don't make it right. Completely illegal.
SoapBox is offline   Reply With Quote
Old 10-11-2021, 12:50 PM   #31
geezersmk
Member#: 282228
2011 STI Limited
From another forum we confirmed that this is most definitely an EJ253. You can see the rear port under the turbo compressor housing is threaded which the EJ253s use a different threaded PCV valve installed there.
Which confirms its a short block from a non turbo SOHC Forester/Legacy Outback platform. I've reached out to a few lawyers and hope I can get traction. Surely this can't be legal...
Old 10-11-2021, 02:13 PM   #32
rtv900
Member#: 428511
2016 STI
I don't think there's any debate whether it's not legal. Probably a massive liability risk for that dealer above anything else.
Why don't you start with the dealer before going lawyer? Maybe the people who's heads will be on the line legitimately did not know and they'll cooperate immediately.
rtv900 is offline   Reply With Quote
Old 10-11-2021, 07:05 PM   #33
Mazinger15
Member#: 513643
2006 WRX
Curious if the smog was done by the previous owner or the dealer.
You have the date of the smog and you probably have a carfax with a date on when the title changed hands.
Dealer may not have know the block was replaced.
Mazinger15 is offline   Reply With Quote
Old 10-11-2021, 08:02 PM   #34
lefty o
Member#: 512654
2019 wrx
red
before contacting the dealer and trying to get them make it right, remove the stuff you put on the car. rule number 1 though, if it doesnt run right, dont hand over the money and take the car home.
lefty o is offline   Reply With Quote
Old 10-13-2021, 09:28 AM   #35
chrisd87
Member#: 344446
2012 00 GC8, 02 S202
sounds like the previous owner did some sneaky move before trading it in.
chrisd87 is offline   Reply With Quote
Old 10-13-2021, 05:18 PM   #36
Fndragn
Member#: 470845
2011 Sti
I canít see your pictures but it should be as easy as taking a picture of the timing belt cover. Does it have 2 bump outs per side or 1? Dohc or sohc, that should tell you turbo block or not.
Fndragn is offline   Reply With Quote
Old 10-13-2021, 06:22 PM   #37
Notbrick
Member#: 433072
2004 STI, Stock, 67K
Has 70s Big Block switcharoo written all over it. Bold move nowadays. Perhaps the dealer had no idea, or did and simply trying to dump their mistake.
Notbrick is offline   Reply With Quote
Old 10-16-2021, 06:00 PM   #38
bugeye829
Member#: 81995
2004 Scion xB
02 WRX 247k RIP
What is the VIN? i work at Subaru i can see what the car was originally
bugeye829 is offline   Reply With Quote
Old 10-25-2021, 12:27 AM   #39
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
There should be a serial number on the engine (back top of engine where the transmission mates up) - that should tell you what the block is, I think.
Old 10-25-2021, 02:01 PM   #40
shadowcompany
Member#: 189394
9994 Impreza LSX STi
AWD
The honest truth is I found a low mile STI, in the color and body style I wanted, and I was ready to tackle any DIY that came up, and there was a handful (missing lug nuts, loose screws, cracked tire, etc).
Hehe, a DIY on a subaru is replacing the engine. If you like the car and want to work on it yourself then it really doesn't matter what block it had, it was never going to last anyway.
Go pick up a EJ20X (~$1000) or EJ20Y (~$1500) and swap over all your STI accessories (turbo, accesories, manifolds, etc.) to the long block. The 2008+ USDM sti will run that engine, with a decent tune it will drive and feel way better than the USDM EJ257.
Do not waste money on rebuilding EJ engines either, its a lengthy process and the results are usually disappointing...it either blows up or doesn't make enough power.
shadowcompany is offline   Reply With Quote
Old 10-25-2021, 02:15 PM   #41
Nix_Evo
Member#: 131304
20 WRX PB Blue
19 Mustang Vert - GG
Ok,
I'm so beyond confused here... couple questions.
1) why were you willing to fix anything? you can force the dealership to do this using the lemon law
2) if the CEL came on, once again you can force the dealership to fix this
3) we're all assuming this is going to be some fight... its very possible the dealership would take full ownership and fix to avoid any bad reviews / press.
Please, stop doing this and call the dealership. Not sure how you've gone 4 months without picking up the phone. I'm on the fence of calling BS on this whole post at this point.
Nix_Evo is offline   Reply With Quote
Old 10-25-2021, 02:22 PM   #42
K3rm1tth3fr0g
Member#: 508105
2002 WRX - Link ECU
being installed :)
Hard disagree on the 20x.
You're losing displacement, and the higher CR doesn't help on pump gas...
K3rm1tth3fr0g is offline   Reply With Quote
Old 10-25-2021, 02:53 PM   #43
pearljam11
Member#: 113335
13 WRX Limited
05 STi OBP 320/352
My VF39d EJ205 wrx would not get out of it's own way until boost started to build around 3k. Agreed on the displacement
pearljam11 is offline   Reply With Quote
Old 10-26-2021, 03:15 AM   #44
Blindeye_03
Member#: 4418
2019 CTR
Originally Posted by Nix_Evo View Post
Ok,
Laughing because I am thinking the exact same things.
Blindeye_03 is offline   Reply With Quote
Old 10-26-2021, 08:15 AM   #45
rtv900
Member#: 428511
2016 STI
Ok,
Yeah there's something significant that he isn't telling us.
Old 10-26-2021, 09:53 AM   #46
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
There are a couple levels that are available here.
First, depending on the state, the car may be covered under the lemon law. This is cut and dry and easy on your end. My state (MA), you would absolutely be covered. You call the dealer and tell them you have a CEL and that your mechanic verified that the engine is a low cost, inappropriate engine for the car and is not an STi engine.
If there's flack on the above, you may need to get an attorney involved and hit the dealer with a fraud accusation.
As others have said, anything you have added to the car, remove it now. The car will be going away.
You also can certainly do an end run of the above and contact your state Attorney General. Some states (like mine) go after dealers like this and start by removing their heads. Other more business friendly states don't care that consumers are being ripped off and allow "as is" sales.
I would imagine that if CA is the state, the dealer will likely know that they're about to lose their neck.
Good luck. Don't try to solve this yourself. It sounds like this is a good car to sell outside the US for that dealer.
Old 10-26-2021, 12:52 PM   #47
mandkens
Member#: 516724
Hope you sort it out soon.
mandkens is offline   Reply With Quote
Old 10-30-2021, 04:37 AM   #48
kbtwofour
Member#: 402515
2002 Impreza WRX
Update?
Next time take the car to a Subaru specialist before buying a car and get a PPI done.
kbtwofour is offline   Reply With Quote
Old 10-30-2021, 06:43 PM   #49
FaastLegacy
Member#: 11671
Anyways I got the car I wanted and was willing to sacrifice a little elbow grease for it.
I'll work on getting some images uploaded shortly.
It was missing lug nuts and had bad tires and that didn't clue you into that maybe this wasn't a car you should be buying?
I'd contact the dealership and see if they want to make this right. You might be hosed on the amount of time it's taken you to bring this to their attention. They'll likely say, "Why has it taken you four months to figure this out and how do we know you didn't swap the engine yourself?"
If they blow you off, contact a lawyer because this is surely a breach of contract and fraud, i.e. they sold you something that wasn't as it was advertised.
My guess it the previous owner blew the engine, "fixed" it with this piece of garbage frankenstein motor, and then quickly dumped it on an unsuspecting dealer.
FaastLegacy is offline   Reply With Quote
Old 11-11-2021, 01:28 AM   #50
jjimpreza
Member#: 1269
2000 RS to WRX
to Forester to LGT to GF8
BS. Sorry Brah
jjimpreza is offline   Reply With Quote
