08-11-2014, 09:11 PM | #1 |
Member#: 389555
Vehicle:2005 WRX Silver |
pin size hole in header
i just installed a set of aftermarket headers that were slightly used. it had aftermarket uppipe attached. after about 4 hours trying to install them due to corrosion and what not from snow and salt up here i finally got them on. no i have a small problem. i think i have a literally pin size hole in the uppipe right above the flex pipe. i have a buddy who works at a shop should i just get it welded to fix it or any other alternatives. love the headers not loving the faint smell of burnt oil nothing else leaks but out of that hole it does smoke a little. but oil levels/coolant levels ride and everything are find. pretty positive its just that leak in the header causing that small bit of smoke and whoofs of burnt oil. invidia turboback, cobb aP, stage 2 tune, also timing belt/waterpump/oil pump all serviced the day of the maintenance. any help to block the pin size hole would be appreciated
08-11-2014, 11:46 PM | #2 |
Member#: 167739
Vehicle:15 Forester NA dat gas mileage |
Get it welded fixed or get a new uppipe.
08-11-2014, 11:52 PM | #3 |
Vehicle:OK buy Nates beans westcoastroasting.com |
lemme guess....5w30??
08-12-2014, 02:36 AM | #4 |
Member#: 389555
Nope I run 10w-30 Castrol full synthetic with a k&n oil filter. I'll be getting it welded tomorrow just figured I get some help from some scoobie friends to confirm. I'm going in a 1700 mile round trip to SC and back so Wana make sure she is tip top shape.
08-12-2014, 02:54 AM | #5 |
Member#: 267339
BAIC
Vehicle:2002 0[[XXXXoXXXX]]0 MBP LongRoof |
You realize the "30" in Scotty's question and the "30" in your reponse are the same, right? Might wanna try some better oil, esp. with a trip to warmer lands. If you keep it, watch it every fill up. No joke.
08-12-2014, 03:01 AM | #6 |
keep ya 3 or 4qt oil in the car with ya...check it every time ya fill up or ya likely wont make the 1700 miles
08-12-2014, 06:00 AM | #7 |
Member#: 389555
So what oil should I be running then??
08-12-2014, 06:12 AM | #8 |
Member#: 389555
I mean I'll be stopping here and there for an hour or so. And I have no signs of a oil leak. I think the liquid in the headers is just condensation it's like a blackish brown and it's not as thick as oil
08-12-2014, 06:22 AM | #9 |
Member#: 389555
Also the weather here and there isn't much different might be a little more humid by 15% but Syracuse ain't a whole lot differ then South Carolina this time of year
08-12-2014, 09:47 PM | #10 |
Member#: 322963
Vehicle:04 wrx psm |
08-13-2014, 12:35 AM | #11 |
Member#: 267339
BAIC
08-13-2014, 12:38 AM | #12 | |
Member#: 267339
BAIC
Still, more better oil would serve you well, IMO. |
08-13-2014, 12:38 AM | #13 |
Member#: 389555
Weird I heard horror stories about that I've never had a problem with Castrol but you guys are typically right. I am leaving in am hour I'll be sure to monitor my levels once an hour and not drive harsh
Sent from my SM-G900P using NASIOC mobile app |
08-13-2014, 12:43 AM | #14 |
Member#: 267339
BAIC
Every fill up oughtta be fine... Find quarts of the Rotella T6.
08-13-2014, 12:44 AM | #15 |
Member#: 389555
08-13-2014, 01:31 PM | #16 |
Member#: 267339
BAIC
08-13-2014, 04:39 PM | #17 |
Member#: 389555
I made it one piece no oil burning no oil loss nothing. I'm gonna change it while in down here for the ride gone
08-14-2014, 07:52 PM | #18 |
Member#: 389555
What would be best oil to use on my trip back im gonna change it again before I leave
08-14-2014, 10:07 PM | #19 | |
Member#: 322963
Castillo isn't bad oil, our subaru motors are super picky though and they tend to like the rotella oil |
08-14-2014, 10:16 PM | #20 |
Member#: 389555
Yeah im deffinantly gonna run a oil change tomorrow with some rotella t6 thanks my friends!
08-15-2014, 11:04 AM | #21 |
Member#: 389555
Just put rotella 5w-40 full synthetic (dark blue jug) with the longer purolator filter
